Like Tree5Likes
Old 09-27-2011, 04:18 PM   #10126
Cool
Whip Racing Innovations make a carbon fiber driveshaft for the tc3/tc4 that does not bend or flex , and at (5.25g-5.5g) weighs a lot less than the aluminum shafts (9.9g-13.7g)...You should check them out if the aluminum shafts fail ...
bertrandsv87 is offline   Reply With Quote
Old 09-27-2011, 04:29 PM   #10127
The Whip carbon shafts work with the tc3 (#3917) cups, but not with the tc4(#31019) cups ! Just so you know.....
Old 09-28-2011, 01:17 AM   #10128
That is strange, so they must be different shape cups? I believed that the shaft fitted both cars??
I fitted one of my carbon shaft back on to see if it makes a difference, bearings etc...are fine, car was just rebuilt with new bearings too.
thinking abour making a "sleeve" over the drive cup so that the pieces stay put and are not under too much force, maybe a lightweight tube glued on.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-28-2011, 07:36 AM   #10129
The tc3 has no issues with whip shafts, the tc4 has fitment issues according to their website . I recommend using Irs aluminum cups front and rear with the carbon or titanium(if you can find one) shaft ! You won't need a sleeve on the aluminum cups though !
Old 09-28-2011, 08:52 AM   #10130
Does anyone know what the stock toe degree setting is in the manual, ie what does the 1.7" turnbuckle length equate to? I don't have a fancy setup kit, and I need a known starting point to work off of.
rcgerber is offline   Reply With Quote
Old 09-28-2011, 09:10 AM   #10131
In the manual , the turnbuckles should be 1.125" each for standard toe , but it does not specify what degree standard toe is , although I think it is as close to zero as possible, having built a few fttc4's to spec . Anyway you can get it as close to zero as possible using a board with two straight lines.....
Old 09-28-2011, 09:55 AM   #10132
1.125 is the turnbuckle physical length not the total length with ball cups. The RTR manual says total length center cup to center cup should be 1.7", although the FT manual doesn't state a length just gives a SO box, what ever that means.
Yeah I guess I give the two lines method a try. It's just harder to do with tires on the car.
Old 09-28-2011, 01:40 PM   #10133
IndyHobbies.com's Avatar
This is my Associated TC3 set up for VTA at our local track. www.RCARindy.com The body is HPI's '67 Corvette. If you run VTA, you know that the '67 Corvette body isn't a legal body in VTA, but most tracks are fine with it. It fits the era just fine, but it's not legal because no real '67 Corvette ever ran in VTA.
Paint is Faskolor FasRed. Windows outlined in silver and backed with white to make it pop and then a light coat of black.
Motor is a Novak 25.5 brushless. Futaba 9452 Steering servo. Great driving car!
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 09-28-2011, 03:53 PM   #10134
your link does not seem to work..
Old 09-28-2011, 03:59 PM   #10135
i have to get one
millertimepb is offline   Reply With Quote
Old 09-28-2011, 05:45 PM   #10136
Found Irs parts, really expensive! as for Whip, cannot find them, where do you buy your parts anyway?
Old 09-28-2011, 06:09 PM   #10137
Smile
I bought all the parts I needed in 2005 , and with parma bumpers in all my cars, I hardly break anything ! IRS has a clearance of tc3/tc4 parts, and whip racing might be out of business !!! As for the turnbuckles, sorry mate you're right, I read it wrong, but I only use the two lines method, I am not spending a dime on a hudy board, $250, give me a break !!!!! That's another car !!!! I try to put the least visible toe out in my cars, and that does well enough for me !!!
Old 09-29-2011, 07:21 AM   #10138
You do not need a Hudy board, I have a Titan setup which i paid 50 box and it works perfect on a piece of laminated MDF.
Old 09-30-2011, 11:40 PM   #10139
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default Team Associated TC4 Factory Team
Hi
I have a TC4 rolling Chassis with heap of spares if your interested, It's a Factory Team Edition Carbon Fibre Chassis.
Electrics, MotorReciever and P.T. Not Included
I finish Second in last year in Stock Class and currently running third at moment,
Comes with all the Manuals and Orginal Box
There would be around NZD$200 in Spares to many to list
also have coming from Associated for it
Diff Housing Case x 2
Diff Ball 3/32 x 1
Axle Shim set x 1
Diff Shim set x 1
Zero Toe Block x 1
Diff Housing Screws set x 2
Diff Gear and Pinion x 2
Might be some others stuff cant remember.
Looking around NZD$350ono
Looking at buying a TC6
Look forward to hearing from you
Jamie
DRECC
Team Associated TC4-dsc05084-2-.jpg   Team Associated TC4-dsc05085-2-.jpg   Team Associated TC4-dsc05086-2-.jpg   Team Associated TC4-dsc05065-2-.jpg   Team Associated TC4-dsc05066-2-.jpg
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 09-30-2011, 11:44 PM   #10140
more pics
Team Associated TC4-dsc05068-2-.jpg   Team Associated TC4-dsc05069-2-.jpg   Team Associated TC4-dsc05070-2-.jpg   Team Associated TC4-dsc05071-2-.jpg   Team Associated TC4-dsc05073-2-.jpg
Jamie Scott
O.R.C.C.C
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
