Like Tree59Likes
Old 09-23-2011, 08:04 AM   #10111
Trader Rating: 41 (100%+)
Yea they were from last year and most of the drivers are new to onroad. And the orange dots are nasty when you clip one
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 09-23-2011, 02:52 PM   #10112
Bubblehead's Avatar
With our rotating schedule between (on-road, off-road, drag racing) it will be a little while before I have anything to show. I have been working on my set-up and my car is getting better I didn't know that the RTR came with 0* of caster.
Bubblehead is offline   Reply With Quote
Old 09-23-2011, 09:30 PM   #10113
i going to get a tc4 because my e10 did handle brushless good my car is going to be for speed runs and drag racing i want to run 3s will a 3s pack fit the tray if so which packs
traxxas emaxx tacon 4074 2150kv 5s, slash 2wd tacon 3660 1800kv 4s
momogt is offline   Reply With Quote
Old 09-24-2011, 05:37 AM   #10114
Bubblehead's Avatar
You should visit Debbie's RC World they will be hosting Drag Race Nationals from Sept. 30 to 2 Oct.
http://debbiesrcworld.com/raceway.html
Old 09-26-2011, 07:12 PM   #10115
Momogt, I know you need to calculate the height of the battery tray, with the screws holding it backed out all the way. A normal 2S pack is about 24mm high, and with the screws backed out I think you can fit a 26mm high pack . The screws are 4-40, and you can get longer ones at mcmaster.com, and drill pinholes through, to fit a taller pack . I did that mod in my Hvtc4 , and I am currently running 30+mm high 4S packs, with the regular battery strap....
bertrandsv87 is offline   Reply With Quote
Old 09-26-2011, 07:22 PM   #10116
Momogt, the new thunderpower 3s tp3300 65c pack is the same dimension as the 2s pack of the same capacity (23.5mm high) !!! So you should be fine with the standard strap....Only 4S+ packs run into fitment issues....Good luck...
Old 09-27-2011, 02:55 AM   #10117
Bertrand are central shaft cups the same on TC4 than TC3 ? they use a different reference number but on picture they look similar.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-27-2011, 02:11 PM   #10118
Smile
Olly, you're right they do look similar eventhough they have different stock numbers: tc3(#3917), tc4(#31019) . I think the tc4 version is a bit beefier .They are both available out there , and it's best to get the one designed for your car because of possible shimming issues. I am sure they are interchangeable though.....
Old 09-27-2011, 02:32 PM   #10119
That's what I thought, the shafts are the same aren't they? and this is twice that one of my cups brake in two outtings, maybe the composite is getting weaker with time...especially if they were moulded 10 years ago, I have never heard of a stronger made cup, have you?
Cheers,
Olly
Old 09-27-2011, 03:02 PM   #10120
Thumbs up
They use the same input shaft (#3915), but I never had my tc4 cups break ! Make sure your shaft is not bending too much under acceleration. In my mod tc4's, I only use IRS aluminum shaft cups. I leave the plastic ones in my stock and 13.5t cars . I don't think the plastic ones will hold up well in mod, specially if you don't take the foam ends off, and don't grease them.......
Old 09-27-2011, 03:10 PM   #10121
Thumbs up
Also Olly, if it is your front cups breaking, I would suggest you get a pair of lcd's(#losa3344) ! The front input shaft and bearing need to be checked for excessive play.....
Old 09-27-2011, 03:15 PM   #10122
Olly, I also run Niftech titanium shafts in all my mod cars ! Aluminum shafts wobble too much in mod .Too bad niftech stopped making these shafts .
Old 09-27-2011, 03:16 PM   #10123
nope one rear and one front breaking and this is with a 10.5t boosted setup.
Funnily the cup package for TC4 is cheaper than the TC3.
I am going to try the TC4 anyway, if the shaft is the same, then the cups should fit.
thanks
Old 09-27-2011, 04:02 PM   #10124
The stock tc3 setup should handle a 10.5t boosted nicely . If both cups broke , I would change the input shafts, bearings, and maybe the main driveshaft , just to be safe ! Good luck...
Old 09-27-2011, 04:06 PM   #10125
Olly, I think the tc4 (#31021)main driveshaft is stronger than the tc3 (#3937)aluminum one !!!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
