Like Tree18Likes
Old 09-07-2011, 03:16 AM   #10066
Hey all,
I'm hoping to install the stock battery strap but I don't know the part number for the 2 posts in which the battery strap sits on (then u put the clips in to hold the battery).
Anyone could shed some light on this? I run the factory team chassis but it will still be fine. I've been using tape and its a bit crappy/messy.
tt01-demon is offline   Reply With Quote
Old 09-07-2011, 10:49 AM   #10067
Originally Posted by tt01-demon View Post
Hey all,
Look at AE site then manual then TC4, you will have all the ref numbers.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-07-2011, 01:28 PM   #10068
Bubblehead's Avatar
Hey all,
FT TC4 Battery Strap part #31126
http://www.teamassociated.com/cars_a...s_accessories/
Bubblehead is offline   Reply With Quote
Old 09-07-2011, 02:00 PM   #10069
Bubblehead's Avatar
Default Motor Fan
Olly986,
What type of fan are using? and what are motor temps?
I have a clamp type fan and when I temp my motor the top is around 170* but the bottom is over 200*.
Old 09-07-2011, 04:02 PM   #10070
The Ae ft team battery strap might still not hold lipos without modifications ! It was designed for Nimh packs, unless you guys have found a mod for it ! I use my own 4-40 screw system to brace my lipos, and the diggity design carbon Tc5 strap(#tc5-051) wide to keep my packs from sliding sideways and front to back . I would surely like to know how others make it all work though !!!
bertrandsv87 is offline   Reply With Quote
Old 09-08-2011, 03:07 PM   #10071
Well as you can see from my chassis above for the TC3 I reverse the original bar and use the sponge spacer to move my batteries forward or rear, have two smaller foams to set it in middle (one foam at each end) I guess this set up should work on the bathtub TC4 chassis?
Bubblehead, I hope you are talking in farenheit LOL I use a 10.5t X12 which runs quite hot normally and weather here is fairly hot too (25/35 celsius) hence the big fan, I bought a second hand battery (Nimh) cooling system that had 6 fans on, it was cheaper than buying one single fan, they are similar in size to the LRP/Nosram fans 30x30 and on the TC3 it is plugged in my receiver but on the TC6 it is directly on the Lipo (I am short on my receiver of one plug having the extra transponder on too and I do not like running a Y connection)
Temp runs around 75/85 celsius
Old 09-08-2011, 03:23 PM   #10072
Bubblehead's Avatar
It would have been nice if would have done the math for me (LOL), for my non-celsius friends 167*/185*. I will be ordering a 30x30 fan, is the fan mounted to the chassis or the motor? and are you measuring your temp on the bottom of the motor?
Old 09-08-2011, 07:07 PM   #10073
Bathtub tc4's are very good and straightfoward with lipo packs, it's the Fttc4 that needs modding . Also, the fan directly wired to the lipo must be alot more effective than the Bec ones ...nice....
Old 09-11-2011, 10:41 AM   #10074
I just fitted it with one screw and threadlock on a cheap motor clamp.
Not all fans will work long on 7.4v but so far have used mine all season without a problem, just one thing that I do is use a connector between the battery and fan.
Old 09-11-2011, 12:36 PM   #10075
Bubblehead's Avatar
Thanks, I'm going to switch back to 17.5 non-boosted I'm going to need a bigger fan. I just can't figure out boosted I tried last year when I got back into racing.
Old 09-11-2011, 07:12 PM   #10076
I am currently in the process of building a TC4 from ground up with new parts to work with a Castle Creations 1515 2200kv Neu Motor. I am hoping to run very high gearing and hope to crack some very decent speeds.
I need to try find some 6mm alloy to which I will make my mount out of, as the motor will have to sit a bit higher.
I am using a 150amp hobbyking ESC which will support 22v muhaha
Old 09-12-2011, 05:33 AM   #10077
SHOEADDICT's Avatar
Send a message via AIM to SHOEADDICT
Hey all,
I HAVE A MILLING MACHINE SO I PUT THE WHOLE CAR IN IT AND TOOK OUT THE TABS. NOW IT SITS FLAT RIGHT ON THE TUB. I USE A DENSE FOAM TAPE ON THE SIDE OF THE BATTERIES DEPENDING ON WHAT SIDE I NEED IT ON.
SHOEADDICT is offline   Reply With Quote
Old 09-12-2011, 09:11 AM   #10078
That's easy with a tub chassis, but who has a system for the Ft tc4 ?????
Old 09-12-2011, 06:39 PM   #10079
Trader Rating: 39 (100%+)
In My FT TC4 I didn;t have the posts for the stock battery strap so I made my own.
A little hokey but it works Took 2 steering posts from a bin of parts from my old T-maxx Cut them down a little bit and glued in a threaded piece ( the screw that holds the tmaxx out drives to the trasmission then just used a plastic nut to hold a custom battery strap I made out of scrap aluminum that I put a 90 degree bend into that stiffened it so I will clam the battery better
Then I coated it in liquid rubber to provide friction to the battery and it does not move one bit
My Phone is not taking clear pics here as the light is terrible so I'll find my point and shoot and get some better ones
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 09-13-2011, 12:41 AM   #10080
Will you be able to fit all this in your car?? can get top speed (90kmh+) with a "simple" 10.5t boosted and 7.4v pack 60C.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
