Like Tree18Likes
Old 08-14-2011, 12:05 AM   #9916
It is easy to switch cars to presumably go faster, but it is more rewarding to make so-called old cars faster than new ones !!!! Don't give up on your tc3/4 cars just yet, they have alot more speed in the tank than you think !!!!!!!
bertrandsv87 is offline   Reply With Quote
Old 08-14-2011, 04:36 AM   #9917
Bubblehead's Avatar
Originally Posted by bertrandsv87 View Post
Bubblehead , do you have a tc4 rtr ? You run stock 17.5???? What body???? What steering servo and speedo ?
It's a TC4 rtr, 17.5 boosted with Tekin Rs Pro, Mazda Speed 6, stock servo but it will be replaced, picked up a set of threaded shocks. Looking to get one more TC4 for blinky. I was racing Hot Bodies TCX and Cyclone which I'm looking sale.
Bubblehead is offline   Reply With Quote
Old 08-14-2011, 04:38 AM   #9918
Bubblehead's Avatar
Originally Posted by SHOEADDICT View Post
glad to see people in va have some love for the tc3 and 4. alot of people aroudn here only do x ray's. va beach!!!!!
Where are you racing? Debbies
Old 08-14-2011, 05:36 AM   #9919
What part of the Beach do you race at?? I see more Top cars than anything else.
flyintrtle is offline   Reply With Quote
Old 08-14-2011, 09:07 AM   #9920
Bubblehead, good combo in your RTR !!! If you have a digital 2.4ghz radio system, think savox digital servo (sv-1257tg) 0.07sec/139oz for only $63 WOW......If you think you were fast then, you will be amazed with the new servo !
Old 08-14-2011, 09:31 AM   #9921
SHOEADDICT's Avatar
Send a message via AIM to SHOEADDICT
WELL CONSIDERING I JUST GOT THE CAR ON FRIDAY WHEN I GOT BACK IN TO TOWN. I HAVE NOT RACED AT ALL YET. THE LAST TIME I RACED AT DEBBIES WAS WHEN THEY WERE ON GREATNECK ROAD. MANY MOONS AGO!
I AM ABOUT TO ORDER SOME LIPO BATTERIES NOW. THEN CHECK OUT SOME MOTOR ESC COMBOS. THE ONLY THINGS I GOT FOR IT SO FAR WAS A BLUE SCREW KIT AND SOME DRIFT TIRES.
COULDN'T BEET IT FOR $150 SHIPPED!
SHOEADDICT is offline   Reply With Quote
Old 08-14-2011, 02:11 PM   #9922
If you can't run digital, the futaba s9402 is the next best thing ! By the way, is $150 for the rtr or the fttc4 ???
Old 08-14-2011, 05:42 PM   #9923
SHOEADDICT's Avatar
RTR!
Old 08-14-2011, 07:39 PM   #9924
Very well ! The rtr responds very well to smooth shocks(trf) .I have three of them , one with a Co27, one with a 7t cobalt, and another one with a novak HV4.5R for fun !!!! It handles them all flawlessly , and is easier to work on than the two Ft versions I also own !
Old 08-14-2011, 11:04 PM   #9925
DaveW's Avatar
I need to post my Tc3/4 stuff for sale. Its just going to waste in the closet.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 08-15-2011, 04:54 AM   #9926
Bubblehead's Avatar
Originally Posted by DaveW View Post
spur / pinion x 2.5 = FDR
Thats at the axle... not including the tire.
If you were taking tire size into account then your answer would be whats called rollout. Thats different.
Are you planning on staying with 48 pitch gears? 64 pitch would serve you better in the pursuit of the best ratio.
The motor cam wont rotate enough for you to fit a 45 tooth 48 pitch pinion on your 72 tooth spur. You need to go much smaller on the spur.
Your ratio of choice will vary as well by motor type, speedo type, and physical motor or ESC timing advance, track size, etc. Telling you to throw on what equates to a 4.0 FDR is a guess at being right.
For my personal 17.5 setup at our local outdoor medium sized track, i mostly use a 64 pitch 81 spur and 41 pinion for an FDR of 4.939. The 64 pitch spurs i use range from 78 to 88 teeth. Pinions range from 38 to 46 teeth.
In your search for the right gearing, try to use the smallest spur possible to place the motor as close to the center of the chassis as you can. The better the car balance, the easier it will be to drive consistently and fast.
No wonder my car seemed slow yesterday my FDR 6. Thanks Dave for being so detailed.
Old 08-15-2011, 07:34 AM   #9927
AM03GT's Avatar
On a tub chassis you can grind the "webbing" under the pinion to allow for larger pinions and also cut down the motor mount cam to allow for more rotation. I am running a 48P 65T Spur and 40T pinion to get 4.06 FDR for 17.5 "blinky"...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 08-15-2011, 08:32 AM   #9928
Guys , even though the 64p gears will give you closer gear ratios, they don't last as long as 48p gears ! Changing the spur on a tc4 is not as easy as in a belt car ! So the next best thing is to go to the Robinson gears website and buy their new 48p spur gears that come with 49teeth, 52teeth, 55teeth, 60teeth, 66teeth ,etc, for outstandingly high ratios , and durability !!!! I will never run 64p with these gears out !!!!!!!
Old 08-15-2011, 08:39 AM   #9929
Also, I forgot to mention the new Robinson 48p pinion gears that come 41teeth, 43teeth, and 47teeth , for even higher gear ratios !!! Whatever you do, visit Robinson Racing website for more details, you won't have to dump your set of 48p pinions and spurs !!!!!!!
Old 08-15-2011, 08:49 AM   #9930
Buckaroo's Avatar
Just be aware, in TC these days, with the new generation of motors running cooler than ever, ratios of 3.2 or lower are becoming very common.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
