Like Tree26Likes
Old 08-11-2011, 09:51 AM   #9901
DaveW's Avatar
I dont remember the Losi drives being available when i ran the Tc3/4? Ill have to refresh my memory on that.
I havent touched my Tc4 since last October. I like A LOT of steering. My EPA was in the 60's as well but i rarely dipped into the wheel that much once i changed caster and added the Tc3 steering rack.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 08-11-2011, 09:58 AM   #9902
Those lcd drive came out with the jrx-s type R, a good three years or more now , and are a direct fit on the tc4 if you widen Ae caster blocks a bit ! They offer a lot of advantages, specially when using Irs aluminum spools !!!!
bertrandsv87 is offline   Reply With Quote
Old 08-11-2011, 10:06 AM   #9903
Another advantage of those lcd's , apart from being cheap$35 a set of two , is that they increase driveline efficiency by a mile !!!
Old 08-11-2011, 10:07 AM   #9904
DaveW's Avatar
Ahh i gotya. You can keep those IRS spools. Steel for me. Need the weight up front.
Old 08-11-2011, 10:55 PM   #9905
Steel spool is fine up front as long as you run lcd's ! Even if you run a diff, you still need lcd's to protect the balls and diff bolts ! I feel these changes will bring the tc3/4 car back on the rc scene!!!!!
Old 08-12-2011, 12:06 AM   #9906
so you telling me if i get these lcd's they are a direct fit??..but i may have to widen the caster block & this get rid of the chatter & binding up from runing a spool....if so i need these badly
starrx is offline   Reply With Quote
Old 08-12-2011, 01:44 PM   #9907
Bubblehead's Avatar
[QUOTE=bertrandsv87;9512024]Those lcd drive came out with the jrx-s type R, a good three years or more now , and are a direct fit on the tc4 if you widen Ae caster blocks a bit ! They offer a lot of advantages, specially when using Irs aluminum spools !!!![/QUOTE
Have you tried using Losi caster blocks?, but all I have to do widen AE blocks a little?
Bubblehead is offline   Reply With Quote
Old 08-12-2011, 04:45 PM   #9908
Bubblehead's Avatar
Dave, Losi rear hubs long or short?
Old 08-12-2011, 05:30 PM   #9909
Other than the Lcd's ,I only run tc4 parts . I never tried losi caster blocks . To fit the lcd's in the tc4 you only need to widen the Ae caster blocks just enough so the lcd won't touch anything at full wheel lock ! You don't have to worry about length, axle size or bone fitting the outdrives ! It will almost feel like they were designed for the tc4 !!! I have been running my tc4 for years with no visible wear on the aluminum outdrives ! I also grease my outdrives a bit ........
Old 08-12-2011, 07:05 PM   #9910
Bubblehead's Avatar
I'll see if my LHS has them in stock. I figured it out "short".
Old 08-12-2011, 09:57 PM   #9911
DaveW's Avatar
Yeah short rear hubs Ron... sorry i dont get on here everyday like i used to. Ill PM ya my new cell #. Texting is always fastest.
You also wanna run a circle and X 3.0 hingepin blocks in the rear. This will widen the rear a touch to add stability and steering, and reduce rear toe a bit. The Tc4 aint like some belt cars that 'need' 4 degrees of rear toe in to keep heat in the tires.
One of the last things i found that worked on that hot asphalt was running a firmer compound up front. Like 36's up front and 32's out back (even did 40's front and 36's rear). If i pushed the car hard the front tires would get too hot and fade after 4 minutes (spool). Heating the fronts to track surface temp, and the rears to ambient air temp just prior to the run gave me predictable traction from the start... instead of having to wait for the fronts to 'come in' 3 laps later.
Old 08-13-2011, 06:56 PM   #9912
I kind of ran into the same type of problem , but with the front tires (sweep40) biting too much . I had to only sauce the rear tires, and put some dust up front ! The tc4 is very capable, but needs to be made ready every time it steps on the track. Do not assume that everything is ok at race day because it was fine the day before ! Constant attention to details is crucial....
Old 08-13-2011, 07:18 PM   #9913
Bubblehead's Avatar
Put my car on track today felt okay even though I had the wrong tires (28's) need to work on ESC and set-up it went from box to track just changed ESC and receiver. Next weekend is on-road so I have time to get it right.
Old 08-13-2011, 08:15 PM   #9914
Bubblehead , do you have a tc4 rtr ? You run stock 17.5???? What body???? What steering servo and speedo ?
Old 08-13-2011, 11:33 PM   #9915
SHOEADDICT's Avatar
Send a message via AIM to SHOEADDICT
glad to see people in va have some love for the tc3 and 4. alot of people aroudn here only do x ray's. va beach!!!!!
SHOEADDICT is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
