Like Tree18Likes
Old 10-25-2004, 01:18 PM   #976
I believe the TC4 uses the NTC3 bumper configurations so I think the larger RPM NTC3 bumper will fit.
Don't quote me but they look the same....
Andy M is offline   Reply With Quote
Old 10-25-2004, 01:23 PM   #977
its shaped the same with the three posts, but the ntc3 foam is not as tall.
there might be a way to make it work tho...if someone really puts time into it using the rpm bumper, and the rubber gromits(sp?)
punkboy is offline   Reply With Quote
Old 10-25-2004, 01:42 PM   #978
Default I tried that RPM bumper...
and it always bent down with the stock TC3 bottom bumper. I hated it! I used a penguin bumper and it never bent down again. I still have a new one laying around, I'll try to find it and see if I can mod it to fit. I let you know how it works, when I get those arms.
Nightbreed is offline   Reply With Quote
Old 10-25-2004, 01:46 PM   #979
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally posted by Chazz
speedtechrc ship to the UK raving-monkey, the tc4 including shipping is about 150 pound (that's were i might get my tc4 if i decide to get one )
Chazz
thanks, ill drop him a PM for an exact price..
raving-monkey is offline   Reply With Quote
Old 10-25-2004, 01:47 PM   #980
Default A tip for those who...
don't know. Try the HPI Pro 2 telescoping body mounts. They are great for the TC4's new bumper style. You can replaced the AE front ones with the bigger beefer HPI ones. The body is more stable, much stronger and they flex very little. If you look at my previous pics you can see them.
Old 10-25-2004, 02:52 PM   #981
AMGRacer's Avatar
Just built my TC4 and in my opinion it is a massive imprvement over the TC3. The only problem i had with my car is that the silver ballstuds i found to be really soft and i stripped a few out during the build.
My shocks built with absolutely no problems and no leaks.
AMGRacer is offline   Reply With Quote
Old 10-25-2004, 03:01 PM   #982
AMGRacer's Avatar
Originally posted by TPhalen
Loctite. For what? We have no plans on including any.
The instructions call for loctite on the small grubscrews in the MIP driveshafts...............
Old 10-25-2004, 03:06 PM   #983
JimmyMac's Avatar
Brandon, I didn't need to dremel down my spindles for the foams to clear the front. I used some Tamiya wheel shims. If you'd like I'll order some for ya. The car is still within the 190mm limit.
Dave, yeah I have the Team Bomber main shaft, K-Factory NTC3 front brace, and Square input shafts. I had to use 1 less shims for the input shaft than what the directions call for. The car is free!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-25-2004, 03:25 PM   #984
Send a message via Yahoo to LILROBBY
does anyone know what hobby shops or online store has tc4 parts in stock?
If rubbin is racin' then I'm rubbin harder than ever!!
The team Hoopty comeback tour is coming to a track near you!!
Associated T4
Associated Rc8 electric?
Associated TC5
LILROBBY is offline   Reply With Quote
Old 10-25-2004, 03:37 PM   #985
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Default Re: Brandon Melton, are you using the
[QUOTE]Originally posted by Nightbreed
[B]stock ballstud shims? I don't know where to start on carpet for low rollcenter. So far the stock setup is working good, so I guess I stick with that. Other than I need less rear toe and better on power steering into the corners. I put a 1mm shim in each wheel and I used a buttonhead screw for the shock mount instead of the ballstuds. This way I could still use the outside hole on the front arm. I'm using 26mm foams. It works without grinding anything.
I ran the car like you see on the supplement sheet with 2 washer under the ball studs front and rear. For carpet there probably is something better than this, but to be honest I was kinda impressed with how it ran out of the box, so I saved that to test another day.
lilrobby- I got my kit locally, but KT hobbies had about everything I needed but the front arms, give them a try, my stuff shipped same day. They have a thread in the retail section of this website.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 10-25-2004, 04:01 PM   #986
Bob Nilsen's Avatar
My Jaco foams are touching my steering arms as well... :/
Bob Nilsen is offline   Reply With Quote
Old 10-25-2004, 04:55 PM   #987
try putting the alum asc hexes on the tc4.they spaced out my 28mm tires so they didnt the steering blocks
Associated T4
Associated TC5
Old 10-25-2004, 04:57 PM   #988
hmmm, i might have to try to get my spacers back...
Old 10-25-2004, 05:44 PM   #989
TPhalen's Avatar
R/C Tech Charter Subscriber
Interesting that people are having drivetrain issues....one thing to try is to back off the screws slightly that hold the #31019 Input Bearing Housing in place. Try not to crank them down...
On a side note:
If you feel your diff gears or arm mounts (as described earlier in this thread) are defective, please call our Customer Service Rep at 714.850.9342, x124, and we will replace them for you. You MUST have a receipt of purchase for this to be in effect, though. This is mainly for parts that you feel don't build or feel correct, not for parts you've broken because you hit a wall.
Hope this helps out all our loyal AE customers.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-25-2004, 05:50 PM   #990
Oasis's Avatar
Trader Rating: 36 (100%+)
Really..how about if I just tapped the wall..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
