Like Tree59Likes
Old 10-09-2010, 04:32 PM   #9781
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
I've got a FT TC4 with the rubber topdeck and chassis. Im thinking of selling it. Its well used, but no more play than day 1. The rear underside of the chassis is down to about 1.5mm.
I have a buttload of spares, and two one ways to go with it.
How much do you guys think I could sell it for?
It used to be my racer, but I just turned it into my drifter for kicks.
I love the associated tc3/4 design, I just wish they made a new shaft car
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-25-2010, 08:34 PM   #9782
Subydude2010's Avatar
Trader Rating: 7 (89%+)
Been into off-road electric for a while now. Just decided to pick up a Touring car because there are alot of nice tracks around me. I bought the rtr tc4. Is there anything i must replace or should replace in order to race? I know its an older truck. But i wanted a quality rtr to start learning on. Later on i can get a kit and build.
Subydude2010 is offline   Reply With Quote
Old 10-26-2010, 07:54 AM   #9783
DaveW's Avatar
As far as the car mechanically... threaded shock bodies and a steel front diff (if it doesnt come with one). Threaded shock bodies make suspension setup MUCH easier. A front steel diff is more durable. You can add titanium turnbuckles if ya like... but they arent really needed at first.
Buy good racing tires for track use (practice or race). Tires are 90% of how a car handles, and a crappy handling car is an unhappy driver.
As far as electronics go... upgrade them as you wish. Some tracks have class restrictions, which may make you upgrade them sooner than you wanted to... if racing is your goal. But im sure you can practice with what you have and have no problems.
The Tc4 is an older chassis... but it is capable.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 10-31-2010, 02:21 AM   #9784
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Default TC4 Factory Team NZ
Hi Boys and Girls
Just thought I post some pics of my TC4FT and setup sheet.
I managed to get 2nd Overall for our Touring Stock Session here in our local Championship here in Dunedin, NZ.
We are still running Tamiya 540j motor in this class, but we are about to move to Lipo cells instead of Nicad batteries.
Bring on the New Session.
Team Associated TC4-p1000361.jpg   Team Associated TC4-p1000362.jpg   Team Associated TC4-p1000363.jpg   Team Associated TC4-p1000364.jpg
Jamie Scott
Onroad Race Director
O.R.C.C.C
Titan ARC R10 2013 / Blitz / Sweep / Team Titan
Titan ARC R10 Upgrade / Blitz / Sweep / Team Titan
ScottyTC4NZ is offline   Reply With Quote
Old 10-31-2010, 04:08 AM   #9785
peter george's Avatar
Trader Rating: 352 (100%+)
Originally Posted by ScottyTC4NZ View Post
Hi Boys and Girls
awesome job mate.
Team Underdog - Team UPURZ -
peter george is offline   Reply With Quote
Old 11-14-2010, 08:40 AM   #9786
Buckaroo's Avatar
Anyone have a pic of the factory part with forced air cooling with the two fans? Anyone ever use it with a brushed motor? Make any difference? How does it compare to a clamp/fan cooler? Adaptable to a TC3?
Thanks.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-14-2010, 04:46 PM   #9787
Thanks.
Unless you cut out the chassis & drill the hole for the 2 mounting screws, it will not work on the tc3, since it will be sucking air from a closed space. If I make it to the track this weekend I'll show it to you. It keeps the endbell of a brushed motor real cool.
flyintrtle is offline   Reply With Quote
Old 11-14-2010, 05:07 PM   #9788
Buckaroo's Avatar
Just the ticket I was looking for! Thanks.
Tom
Tom Keith
Old 11-14-2010, 08:28 PM   #9789
Trader Rating: 20 (100%+)
What do you guys run in the diffs? As in, I have a one-way, a ball diff, and a solid axle. Should I run the ball diff in front and the one way in the back? WHat do you guys do? thanks
Gyr0 is offline   Reply With Quote
Old 11-15-2010, 06:50 AM   #9790
Run the ball diff in the rear. For the front, it's really up to you. If your indoor on carpet & the track is tight, then you might want to try a ball diff up front as well.
Old 11-15-2010, 01:33 PM   #9791
Thanks man appreciate it. What would you reccomend for the front? (Small tight carpet track) Dont know any of the pros and cons really.
Old 11-15-2010, 03:10 PM   #9792
DaveW's Avatar
Steel front diff, HD CVD's.
Old 11-16-2010, 08:08 PM   #9793
Airflow's Avatar
Hi, can I use xray spur gears (48P) in my tub TC4?
Airflow is offline   Reply With Quote
Old 12-03-2010, 09:47 PM   #9794
Firefox's Avatar
Hi all.
I picked up a used FT TC4 that needs a little work and would appreciate any info you might have to share.
1. Any up grades recommended ?
2. What are you using for a battery tie down ?
3 Where is a good place to order wheels/tires from, both rubber and foam ?
4. Recommended tires for asphalt and carpet ?
thanks
Firefox is offline   Reply With Quote
Old 12-04-2010, 05:37 AM   #9795
Originally Posted by Firefox View Post
Hi all.
thanks
1. Parma front bumper, and also I found myself breaking a lot of C-hubs, so I have aftermarket aluminum ones(Idk where they're from) and that fixed a lot of problems.
2. I've just been using thin strips of gorilla tape. Just because I haven't found some real tape. It works...
3. Amain, Tower, any of the big names. Though I can only talk for rubber, Idk about foams. Plus I get most my tires at my lhs.
4. Really depends on the tracks you go to. I've found that TakeOff CS27s are among the best for me. It may be different for you.
Hope that helps.
Dan Fowler
Getting out of the hobby... Check out my for sale thread.
TC4Racer123 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
