Like Tree19Likes
Old 10-25-2004, 11:37 AM   #961
wannabee's Avatar
Originally posted by raving-monkey
just a quick Q....where you peeps getting your TC4's from?
cheapest place i found is pacific coast hobbies at $220 with $40 shipping to the UK...
thanks
Matt
http://search.ebay.com/tc4_Radio-Con...sortpropertyZ1
wannabee is offline   Reply With Quote
Old 10-25-2004, 11:40 AM   #962
Default Chazz, yes the IRS gear...
adapter works and the input shafts. Just heads up with the gear adapter you will need to add a shim between the IRS diff adapter and the e-clip. Too much play without it. One shim snugs it up perfect and it runs true. Keep the flat side of the shim next to the IRS gear adp. Just my 2- cents
Nightbreed is offline   Reply With Quote
Old 10-25-2004, 11:52 AM   #963
Default Brandon Melton, are you using the
stock ballstud shims? I don't know where to start on carpet for low rollcenter. So far the stock setup is working good, so I guess I stick with that. Other than I need less rear toe and better on power steering into the corners. I put a 1mm shim in each wheel and I used a buttonhead screw for the shock mount instead of the ballstuds. This way I could still use the outside hole on the front arm. I'm using 26mm foams. It works without grinding anything.
RPM ballcup? I'm using them all around with no rubbing anywhere.
I need front arms before I'm back in the game.
The drivetrain is great out of the box. Other than the front input shaft nag. I wonder why people are having problems with that? No degreasing for me and it's as free as any well worn in TC3.
Old 10-25-2004, 12:03 PM   #964
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
night breed you may not be having rubbing cause the size tire i run 28mm jacos. as far as how free the drivetrain is i think i may have to work on the shimming of the input shafts. btw has anyone broken any thing other than front arms
Javen13 is offline   Reply With Quote
Old 10-25-2004, 12:14 PM   #965
raving-monkey's Avatar
Send a message via MSN to raving-monkey
but some of them don't ship to the UK..the only people that ship to the UK there are pacific coast hobbies and rcboyz.
thanks anyway...and ultimatehobbies.com...i will drop them ane mail about shipping.
raving-monkey is offline   Reply With Quote
Old 10-25-2004, 12:21 PM   #966
Why not order it from a UK shop and support the UK industry? You can pick them up for 189.99.
Andy M is offline   Reply With Quote
Old 10-25-2004, 12:25 PM   #967
the car i built has 28 mm jaco foams on it, and the drive is free...i just put some wheel spacers from tamiya behind the wheels, and they just clear by a hair....no rubbing in corners or nothing
punkboy is offline   Reply With Quote
Old 10-25-2004, 12:47 PM   #968
speedtechrc ship to the UK raving-monkey, the tc4 including shipping is about 150 pound (that's were i might get my tc4 if i decide to get one )
Chazz
Chazz is offline   Reply With Quote
Old 10-25-2004, 12:48 PM   #969
DJM75's Avatar
Default TC4 or TC3????
Hello,
I'm pretty new to the TC scene and I want to get into it and I have a question. Should I get a used TC3 now for cheap on ebay and then get a new FT TC4 when they come out some time next year? I know I'm not good enough to drive the old TC3 to it's limits let alone the TC4. So I thought I'd get a used TC3 get my skills up then move on to the TC4. What do you guys think?
Thanks,
Don
DJM75 is offline   Reply With Quote
Old 10-25-2004, 12:50 PM   #970
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
buy a tc4 and build your skills from there. my opinion!
Roberto Falcon is offline   Reply With Quote
Old 10-25-2004, 12:50 PM   #971
Sounds like a great idea to me. The TC3 is a great car. If you can get one cheap and learn to use it well you will fly when you upgrade to your TC4 and you will be familiar with setting it up (TC4 and TC3 setups are similar).
HTH
Andy
Old 10-25-2004, 12:54 PM   #972
go with the tc4. It has been beefed up so it doesnt break, drive train has been upgraded, and is overall better which will make it easier to drive.
mtc3od is offline   Reply With Quote
Old 10-25-2004, 01:06 PM   #973
Tc3 is good but the Tc4 is better as it's beefed up and it's newer
Chazz
Old 10-25-2004, 01:09 PM   #974
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Default Re: Brandon Melton, are you using the
Youre not the only one
I also broke an arm when I first ran the tc4. The bumper provides no protection to the wheels.
Paul_TC4 is offline   Reply With Quote
Old 10-25-2004, 01:14 PM   #975
Peter Busch's Avatar
R/C Tech Charter Subscriber
The TC3 was the same way untill the RPM bumper came out, hopefully the new one will be here soon or you could probably fabricate something for now.
Peter Busch is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
