Like Tree38Likes
Old 01-12-2010, 09:31 AM   #9646
slolx50's Avatar
Originally Posted by DaveW View Post
I see you have the spine plate marked as used. If youre bored one day, mod it like this...
... and try moving it all the way forward. It works well like this with more adjustability.
Where exactly are you using the Spine Brace on the Tub Chassis?
slolx50 is offline   Reply With Quote
Old 01-13-2010, 08:42 AM   #9647
There is no place to mount a spine plate in a tub TC4
____________________
www.RCActionPics.com
Rojna is offline   Reply With Quote
Old 01-13-2010, 11:55 AM   #9648
slolx50's Avatar
I know this, but he runs a tub car so I was curious where he was using it.
www.TheRCShack.com <----Check them out!
Old 01-13-2010, 03:46 PM   #9649
I think you will find Dave W posted that to show me the spine plate mod he used on his FTTC4.
Toolmannz2 is offline   Reply With Quote
Old 01-13-2010, 06:52 PM   #9650
slolx50's Avatar
Thanks!
Sorry for the confusion.
Old 01-14-2010, 10:17 PM   #9651
Originally Posted by ScottyTC4NZ View Post
Hi All
I'm Currently runing a TC4 ex Toolmannz2 it is the best car i have as it my second car, it makes my Kyosho TF-5 look like sh8t
I was considering either a TF-5 or used TC4 (hard to find used TC4 in NZ)
Is the TC4 really that much better ??
Im after a shaft drive, sick of belt/pulley damage, local track has quite a few small stones (Albany, Ak)
Is the TC4 fairly immune to stone damage ? (I'm running on a RC track, NO bashing)
1101 is offline   Reply With Quote
Old 01-14-2010, 11:13 PM   #9652
DaveW's Avatar
Yeah, the modded spine was for the FTTc4. There is no way it will fit the tubbie.
Last weeks race was bad for my Tc4. Track layout was changed for the start of the points season, which is a good thing in the interest of being fair... but my car was a pile of garbage. I got very frustrated, and it showed in my results.
The car DID pull off fast laps, and carried a ton of speed in the infield, but it was difficult to remain consistent. The biggest mistake i made was going back to the bladder shock caps instead of the screw bleeder shock caps. The o-rings i used to rebuild the shocks with grabbed the shafts so tight that the car slid around corners when pushed hard. The bladders just amplified this problem. This will be addressed before my next race, one set of shocks WITH bladders and another without... both rebuilt. AGAIN. lol
Speaking of screw bleeder shock caps. I saw on the Tower Hobbies website that AE is finally releasing their own version of this cap. They fit all shocks found on the Tc3/Tc4 and T4/B4 platforms... NOT the Tc5.
School started back this week, and im moving to a new house, so i wont be back on the track till NEXT weekend. Everything i own is packed in boxes and waiting to be moved this Saturday. Im itchin to get some laps in...
DaveW is offline   Reply With Quote
Old 01-14-2010, 11:16 PM   #9653
DaveW's Avatar
The spur and pinion will be "magnets" for small debris. The gearboxes will stay fairly clean for many weeks of racing. Its a good car to start with though...
Old 01-15-2010, 01:02 AM   #9654
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
I got lucky to find a TC4 here in Dunedin, it was Toolmannz2 from our club, and he had won one of last years club championships with it, so it was proven winner and i would of be silly to let it go.
The Kyosho TF-5 is a good car to start with and it could be a better car if the time and effort was put into it, might sell it but dont know yet.
But have changed to a TC4, I found with practising with the TC4 the handling is better and getting the power down seems to be more responsive, but i've got my first race with the TC4 this weekend, will let you know how I get on.
The other differnces is the TF-5 is a plastic tub chasis and the TC4 is what I call a flat carbon chasis.
With your question about stone damage? I've had next to no damage in seven months of racing with my pinions and spur gears think I slightly damage one spur.
ScottyTC4NZ is offline   Reply With Quote
Old 01-19-2010, 11:33 PM   #9655
The car was great in the weekend but it was my ESC was playing up.
It was much quicker and faster thru the corners than my competitors but they were running me down on the main straight , then we had a problem with the transponters and it miss laps off my time which bugger the day up for me, but never mind the car was great.
Old 01-24-2010, 09:48 PM   #9656
Exille's Avatar
Does anyone know where i can buy part #31105? its the motormount/bulkhead for the FT TC4, i cant seem to find one anywhere!
Exille is offline   Reply With Quote
Old 01-25-2010, 01:45 PM   #9657
As long as you have your gear mesh right, you won't have a problem with the rocks or anything. But if you have the gears just bearly touching, you'll strip the spur. don't push them together though or you'll rob efficiency from the motor. You want it in the middle.
Dan Fowler
Getting out of the hobby... Check out my for sale thread.
TC4Racer123 is offline   Reply With Quote
Old 01-25-2010, 02:27 PM   #9658
Foxxrocket's Avatar
No, I've mawled a number a of spur gears by rocks. So, you should use fine mesh screen wire over the rear of the car. Also tape the bottom slot to keep from rocks jumping up under the car.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 01-25-2010, 06:01 PM   #9659
trerc's Avatar
Trader Rating: 89 (100%+)
I always just tape the bottom slot. I run 64p all summer long racing on an asphalt parking lot and have never lost a spur.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-15-2010, 01:52 PM   #9660
I just got my FT TC4, i've had my tub tc4 for a while now. I have everything working now, but is there an easier way to adjust the position of the motor? i had a hard time wedging my screwdriver in between the bottom plate and the a arm. i ended up just taking out the entire right rear assembly. Is there an easier way to do this or is just a pain?
Dan
Dan Fowler
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
rvrslt1
