Like Tree33Likes
Old 01-03-2010, 02:58 PM   #9631
DaveW's Avatar
Yah, the info isnt new or anything. I ran these parts on my Tc3 WAAAAYYY back when. Just posting it up for those that ask...
DaveW is offline   Reply With Quote
Old 01-03-2010, 03:31 PM   #9632
trerc's Avatar
Trader Rating: 89 (100%+)
Real nice TC4 DaveW, Makes me miss my tubby. You tried the car without the top plate, I know it reduces a lot of flex. What tie rod ends are you using?
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-03-2010, 04:41 PM   #9633
Originally Posted by DaveW View Post
Just curius, but why the added chassis brace ?? most of the newer designs have a lot of chassis flex for rubber racing ... you took a stiff tub chassis and made it even stiffer.
Rojna is offline   Reply With Quote
Old 01-03-2010, 04:42 PM   #9634
Sure can, but some of the most recent changes wont get tested till mid week... maybe Tuesday or Wednesday tho.
I focused on the speedo setup first part of yesterday's practice (throttle response/timing with the 17.5/VFS-1), and then the chassis afterwards. I ran out of time to make my last set of chassis changes at the track, so im doing them now at home for next week.
XRAY springs are still on the car, i gave all my AE springs to a friend for his Tc3. I was running white and yellow(XRAY) with the sways. Ive settled on the 20 and 25lb springs(XRAY) for the new setup. They made a big difference in chicane transition and overall response. Are you still on the large outdoor track you sent pix of? Were indoor on carpet/rubber tires now. Too cold for asphalt.
Snag those Losi parts. Its worth the effort.
Yea Dave i am still running on that track ,I remember a while ago you posted about using the 6deg caster blocks,and now see a couple in your pics.So how did that go for you? also in your pm to me you said the higher speeds will change shock spring/oil choice and likely change the front camber link position. Ive addressed the spring and oil but unsure where to go with the camber link position.
Cheers Dave
Toolmannz2 is offline   Reply With Quote
Old 01-03-2010, 10:52 PM   #9635
DaveW's Avatar
I will retry it w/o the plate again Wednesday. Before, w/o the plate on foam tires, the car would "hit a wall" and just wouldnt go any faster. Didnt matter what was done, lap times stayed the same. I added the top deck and made a few changes and found almost two laps. It does so well for what it is... id hate to give up on it.
The turnbuckles are Lunsford Titanium, and the ballcups are Schuie ballgrippas.
The Tc4 tub has quite a bit of flex in it. It flexes more than the Tc3 tub for sure. The top plate has worked out so far. My only complaint is i cant seem to get rid of enough rear grip now.
Cheers Dave
I tried the 6 deg caster blocks and they worked really well with the heavier NiMh and brushed 19t setup (weighed in around 1665 if i remember correctly). The car had gobs of on power steering and went wherever i put it. With the LiPo and brushless setup it seems to like around 5 degrees of caster (weighs in real close to 1400 now). As far as the shims and links, ill send pix once i get the car back together, and after i hit the track Wednesday. Im sure it will change quite a bit before Saturdays race.
Old 01-04-2010, 03:57 AM   #9636
trerc's Avatar
Yes the stiff top plate is great for foam tires, but I think if you were to remove it with the rubber tires you'll find that extra rear grip your looking for. With the newer cars all rubber spec car have a good amount of chassis flex which helps the chassis absorb the track a much better. Foam cars still run stiff chassis as grip is not usually an issue with foam tires but too much grip often is.
You can definitely use the top plate as a tuning tool when switching between foam and rubber tires. Keep us informed on how the testing goes without the top plate. I think you'll be pleasantly surprised with the difference in handling.
Old 01-04-2010, 08:06 AM   #9637
balistic's Avatar
Trader Rating: 113 (100%+)
Maybe two to plates?
Hyper 10SC
Hyper 9E
Hyper 9 2.0
balistic is offline   Reply With Quote
Old 01-04-2010, 12:54 PM   #9638
Dusttt's Avatar
Trader Rating: 121 (100%+)
Losi on the left, AE on the right.
The Losi rear hub is 0 degree toe, and no axle offset. It also uses vertical ballstuds. There are two Ackerman positions on the Losi front steering knuckle. You will never use the furthest one out, i just cut them off. You can also see more clearance for the dogbone to go though the Losi caster block, and its definitely chunkier than the AE offerings. Using both front and rear Losi assemblies also widens the car, and aids in stability.
Do you have part numbers on these?
Dusttt is offline   Reply With Quote
Old 01-06-2010, 07:50 PM   #9639
Dusttt's Avatar
What pinion/spur do you guys recommend with an lrp stock spec x-12 13.5?
Old 01-08-2010, 08:51 AM   #9640
Dusttt's Avatar
Anyone?
Old 01-08-2010, 09:07 AM   #9641
trerc's Avatar
On a track??? How big is the track??? You question lacks information...
Old 01-08-2010, 01:40 PM   #9642
Dusttt's Avatar
sorry 7500 square feet... good size
West Coast Rc
Old 01-09-2010, 05:43 PM   #9643
ScottyTC4NZ's Avatar
Send a message via MSN to ScottyTC4NZ
Cool New to RC
Hi All
I'm Currently runing a TC4 ex Toolmannz2 it is the best car i have as it my second car, it makes my Kyosho TF-5 look like shit.
What ESC is the best to use for stock class (silver can motors,1300ma batteries NiCad)?
What is a good hi-speed servo for use to give me quicker turning?
If anyone can help it would be great
Jamie
Dunedin Onroad Club
New Zealand
ScottyTC4NZ is offline   Reply With Quote
Old 01-11-2010, 08:59 AM   #9644
Dusttt's Avatar
Old 01-12-2010, 06:51 AM   #9645
TEKIN FX Pro
____________________
www.RCActionPics.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
