Like Tree38Likes
Old 10-25-2004, 09:40 AM   #946
koabich's Avatar
Send a message via Yahoo to koabich
Personally, I don't see any problem if we, the consumer, have to "do more work than necessary" to free up the drivetrain. 1)I enjoy this stuff, 2) it seperates the men from the boys 3) there is not 1 single car out there that is perfect out of the box (all cars need some sort of work or modification). 4) we all have different tastes (some like things one way and some like it another).
koabich is offline   Reply With Quote
Old 10-25-2004, 09:54 AM   #947
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Originally posted by LoSi xXx S
for me the drivetrain is not that free when i spin the wheels it doesnt keep spining like my pro 4 does.
the only thing i did to mine is spray out the bearings and remove the seals.. spins better than my old FTTC3, which had HOURS of work into it.
this is before i even put motor through it.
OUT
Keith Billanti is offline   Reply With Quote
Old 10-25-2004, 09:57 AM   #948
wannabee's Avatar
Default Drive train
If you shim the diffs, input shafts per the instruction the car isn't free at all, I had to pull 98% of the shims out to free it up, also pulled the shields off of the bearings and sprayed the heck out of them.
Now the car is as free as any TC3's I've owned...The diff. cases are new, the diff. w-bearings just drop down in.
IMHO AE has done their homework and have made a good car even better!!!
wannabee is offline   Reply With Quote
Old 10-25-2004, 10:13 AM   #949
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Which bearings are you removing the shields off of? Also, what is the easiest way to do this? When you are spraying the insides of the bearings, I am assuming that you are using bearing oil or is that incorrect?
cpatel529 is offline   Reply With Quote
Old 10-25-2004, 10:16 AM   #950
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
you remove the shields of the big diff bearings they are only 2. right?
Roberto Falcon is offline   Reply With Quote
Old 10-25-2004, 10:17 AM   #951
I use a scalpel to prise off the metal clip then pull out the seal.
Then I blast the bearing with a load of motor cleaner before re-applying some light weight bearing oil.
Andy M is offline   Reply With Quote
Old 10-25-2004, 10:18 AM   #952
well i cant do nothing to my tc4 cause it has been sold. im just gonna wait till the release the FT kit. the team kit is nice and all but its just to heavy. or not ill just go and buy the jrxs .
Old 10-25-2004, 10:26 AM   #953
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
Default Re: TC4 Ball Cups??
Originally posted by cpatel529
Anyone using the RPM Ballcups on their TC4? I know that people were using them on their TC3 and wanted to see if it was used for the new car as well.
yes they work everywere except for the cup that connects the steering rack to the carrier the rpm are too be and rub against the wheel
Javen13 is offline   Reply With Quote
Old 10-25-2004, 10:39 AM   #954
Originally posted by Chazz
Hi, i was just wondering does the irs gear adater work on the tc4
Chazz
Anyone
Chazz
Chazz is offline   Reply With Quote
Old 10-25-2004, 10:40 AM   #955
wannabee's Avatar
Default Bearing shields
Remove the shields from all the bearings, then when you install them into the car put the non-shielded side in so that way the shielded side is facing out, this will help keep them clean.
Removing the shields will leave them exposed so you'll need to pull them every few weeks and blow them out and relube..
Good luck!
Kevin
Old 10-25-2004, 10:41 AM   #956
wannabee's Avatar
Anyone
Chazz
The lay shafts appear to all be the same as the TC3, so I would say yes, they will work...
Old 10-25-2004, 10:43 AM   #957
Thanks wannabee
Chazz
Old 10-25-2004, 10:59 AM   #958
raving-monkey's Avatar
Send a message via MSN to raving-monkey
just a quick Q....where you peeps getting your TC4's from?
cheapest place i found is pacific coast hobbies at $220 with $40 shipping to the UK...
thanks
Matt
raving-monkey is offline   Reply With Quote
Old 10-25-2004, 11:10 AM   #959
both cars that i have seen built were very free...in fact, the one i built, without any work to the bearings, was just as free as my pro4, without any work to the bearings, and i think my pro4 rolls really free....
punkboy is offline   Reply With Quote
Old 10-25-2004, 11:11 AM   #960
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
www.ultimatehobbies.com has them cheap. Not sure about shipping.
Local shop here is selling them for $210.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
Life is hard; it's harder if you're stupid. - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
