Like Tree26Likes
Old 07-12-2009, 05:54 PM   #9541
DaveW's Avatar
Originally Posted by Hooligan_ View Post
Where in the hell do you find the ball grippas online! I've been googling them now for about 20 minutes with nothing. it doesnt help that my internet connection is super gimped right now. Think you could hook me up with a link or a part number?
She Schuie part# for the ones i have is U1704, they come in a pack of 8 for $6.99.
You can also find them combined with Schuie ballstuds. Those are the more expensive packs ($12.99+), but the studs are metric.
Type U1704 into the small search bar on the left after you click the link.
http://www.racing-cars.com/usa/search.asp
DaveW is offline   Reply With Quote
Old 07-12-2009, 06:33 PM   #9542
Hooligan_'s Avatar
Trader Rating: 17 (100%+)
Thanks Dave, I appreciate the #
Dee & Mee Hobbies Topeka, Ks.
Dee & Mee On Road Racing Club
Hooligan_ is offline   Reply With Quote
Old 07-12-2009, 06:48 PM   #9543
DaveW's Avatar
No problem, anytime.
Old 07-12-2009, 07:03 PM   #9544
tazz888's Avatar
Trader Rating: 22 (100%+)
What tires and compound? I can give you a good baseline setup to start with.
All that is allowed in VTA are HPI vintage racing tires in D compound.
Ron DePoto
Express Motorsports
Pin Shop Hobbies
tazz888 is offline   Reply With Quote
Old 07-17-2009, 12:56 PM   #9545
Kajman's Avatar
Does anyone know if rear and front arms from tc3 will suit tc4?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-17-2009, 12:58 PM   #9546
The sway-bar mounts are different.
Tiger72 is offline   Reply With Quote
Old 07-17-2009, 01:00 PM   #9547
Kajman's Avatar
Yeah, but if I won't use them? I like idea of tc3 200mm arms and bones for rally...
Old 07-17-2009, 01:07 PM   #9548
The TC3 arms are longer and the inner hinge pin is smaller than the TC4. The TC4 A-arm mounts are wider than the TC3, that's why the arms are shorter. You may run into an issue with the dog bones coming out of the outdrives b/c of this.
LJae is offline   Reply With Quote
Old 07-17-2009, 01:09 PM   #9549
Kajman's Avatar
Are there any 200mm conversions for tc4?
Old 07-17-2009, 01:17 PM   #9550
None that I know of.
Old 07-17-2009, 01:19 PM   #9551
Kajman's Avatar
Well, rear is simple, losi xxx-s rear hubs with offset fit just like they were meant to be there, but front ist bigger problem...
Old 07-23-2009, 05:09 PM   #9552
mlight13's Avatar
Trader Rating: 40 (100%+)
Is the TC4 RTR still competitive? I am on a limited budget and I was also thinking of the Hot Bodies Cyclone S, but I don't want to buy a new chassis after it breaks every race day. I will be mainly running in the 17.5 stock class while I learn to drive a 1/10 Touring Car and I will probably move down to 13.5 max car so will the TC4 be ok? 90% of the cars at my local tracks are high end TC5's, Cyclone's, and XRay's which are all belt driven and too expensive for me right now. Thanks for any input...
Mark
mlight13 is offline   Reply With Quote
Old 07-23-2009, 05:57 PM   #9553
The TC4 will be fine in Stock (17.5bl/27t) I've had always been at the pointy end of the field against high end TC's. If you're running 17.5 on a very large track you'll run into problems when it comes to gearing, which is one reason why I got a TC5 now.
With torque steer apparently it isn't much of a problem in Super Stock (10.5bl/19t) so a 13.5 won't be as severe but in Mod it becomes a problem.
With the TC4 RTR for Stock, you can just put in a 27t with a different pinion and you'll be able to race Stock, the RTR comes with a 17t motor so it can safely handle brushed Stock and Super Stock Motors.
You should also note that AM radio gear can't handle brushless (I found out the hard way), so you'll have to upgrade your radio gear to use a brushless setup.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 07-23-2009, 06:23 PM   #9554
mlight13's Avatar
I have the same AM XPS2 Radio for my 18T and I have been using brushless just fine. Maybe it just depends on brand of brushless system. By the way...thanks for the info on the TC4. I probably won't be going past 13.5 anyway. It will be my first TC so I don't know if I will like it or be good at it so I didn't want to dump a lot of money into a car at first.
Mark
Old 07-24-2009, 07:35 AM   #9555
Foxxrocket's Avatar
The TC4 is good for stock racing. Super stock might be a little harder with the car's torque steer. But if you'er a novice, amongst novice racers, then it shouldn't matter. Nor should it matter what the other guys are racing.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
