Like Tree18Likes
Old 06-26-2009, 11:58 PM   #9511
Originally Posted by Ride1226 View Post
Hmm well I will have to look into doing that. I would imagine it would probably be the best idea to do that with steel outdrives... Ill still try it with plastics though just because I have some lying around.
Only reason why I'm using plastic diff is that I didn't have enough spares to make one that was steel. I put the 3rd diff ring on the toothed side of the ring gear. The reason why I use the 3rd diif ring was to make the lost space from the lack of balls and it ended up the same length as my steel ball diff.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-27-2009, 10:13 AM   #9512
DaveW's Avatar
If you use the AL or steel CVD's with the plastic outdrives in a spool configuration... they will pop out and chew the plastic outdrives up in no time. Steel outdrives up front are the way to go. The steel diff up front helps with a litte more initial steering too... the added weight over the front axle helps weight transfer and plants the front end fast.
You can get away with using the plastic outdrives in the rear. I personally use some old school Niftech bones in the back with the pins out of the composite AE dogbones. They help the plastic outdrives last a good while because the pin is thick and beefy, unlike the pin cushion setup the Niftech bones originally came with. And believe it or not they are lighter than the AE composite bones!
DaveW is offline   Reply With Quote
Old 06-30-2009, 08:00 PM   #9513
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
im looking to buy a tc4 ft, please pm me
Jonnydb is offline   Reply With Quote
Old 06-30-2009, 10:31 PM   #9514
Kajman's Avatar
Can anyone suggest me some setup for tc4ft for medium grip medium size asphalt track?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-01-2009, 08:06 AM   #9515
Foxxrocket's Avatar
The first thing you could do is, set your camber. I have mine set at -2, all around.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-01-2009, 08:22 AM   #9516
CL
CL's Avatar
Trader Rating: 32 (100%+)
Try Ebay.
Believe in yourself!
CL is offline   Reply With Quote
Old 07-01-2009, 08:53 AM   #9517
Jonnydb's Avatar
Originally Posted by CL View Post
Try Ebay.
i tried
Old 07-01-2009, 10:30 AM   #9518
CL
CL's Avatar
i tried
Here's one:
http://cgi.ebay.com/team-associated-...%3A1|294%3A100
and another:
http://cgi.ebay.com/Factory-Team-TC4...%3A1|294%3A100
Good Luck bidding.
Old 07-01-2009, 10:40 AM   #9519
Jonnydb's Avatar
thanks
i tried contact the seller before but they didnt answer
Old 07-01-2009, 05:28 PM   #9520
hi all i like to know will any tc4 parts fit yokomo sd ?
please help
racingkids is offline   Reply With Quote
Old 07-01-2009, 06:32 PM   #9521
DaveW's Avatar
Anyone have pix of a FT Tc4 with LiPo and brushless setup installed?
Old 07-01-2009, 07:11 PM   #9522
pakk's Avatar
Trader Rating: 79 (100%+)
This is a BMI tc4. Very similar as far as electronics go compared to a FT tc4.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-02-2009, 10:19 PM   #9523
kokti06's Avatar
Send a message via Yahoo to kokti06
Default share my ft-tc4
my ft-tc4 hope u like it guys
Team Associated TC4-dsc01185.jpg   Team Associated TC4-dsc01179.jpg   Team Associated TC4-dsc01182.jpg   Team Associated TC4-dsc01183.jpg   Team Associated TC4-dsc01184.jpg
kokti06 is offline   Reply With Quote
Old 07-02-2009, 10:50 PM   #9524
Here was how mine was setup, all of this is now in my TC5.
This car is now just sitting on my shelf awaiting new drift tyres, and the chassis is twisted.
Old 07-03-2009, 07:54 AM   #9525
Suspended
I see some of you guys are using duct tape to hold your lipo packs in the tc4 but, DIGGITY DESIGNS makes a WIDE LIPO MOUNTING BRACE for both the TC4 AND TC5 ITEM #TC5-051 for $21 ; CHECK IT OUT, IT'S AWESOME !!!
bertran is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
