Old 06-12-2009, 10:36 PM   #9481
Foxxrocket's Avatar
You adjust shock preload height to affect ride height. I had always thought droop was what you'ed adjust to change ride height, but one of the guys at the track showed me that it was though the shocks that you change ride height.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 06-12-2009, 11:00 PM   #9482
Hooligan_'s Avatar
Trader Rating: 17 (100%+)
Thanks Fox. For the last 3 months now I have just threaded the collar on the shock body down till it just begins to put pressure on the spring with out compressing it. Time to buy a gauge and get to tinkering.
Dee & Mee Hobbies Topeka, Ks.
Dee & Mee On Road Racing Club
Hooligan_ is offline   Reply With Quote
Old 06-13-2009, 12:23 AM   #9483
TomTomTuning's Avatar
Trader Rating: 19 (100%+)
Ive been searching and searching... So many people ask, but no img links seem to still be working. I want to see a picture of the AE Fan Kit on the TC4... Anyone have a picture?
I have the FT Heatsink on my MambaMax 5700k.
Ive thought about taking it off and replacing it for a heatsink + Fan combo.
Or just finding a way to put a fan in front or on the current heasink
Here is a picture of the current heatsink...
Any feedback would be great.
TomTomTuning is offline   Reply With Quote
Old 06-13-2009, 12:35 AM   #9484
Hooligan_'s Avatar
Tom Tom, I have seen the fan setup for sale but I have never seen a pic of it actually installed bud. I can tell ya what though. I don't see how I would have room for it My TC4 chassis is stuffed.
Old 06-13-2009, 03:26 AM   #9485
Foxxrocket's Avatar
I have my shocks set to 4.3mm rear and 4.1mm front.
Old 06-13-2009, 03:34 AM   #9486
wow thats low, what surface do you drive it on? I have mine set to 5-6mm front and rear.
I turned my TC4 into a drifter, with the rear spool and front one-way it's possible to effectivaly do handbrake type manuvers. Oddly enough doing reverse J-turns requires forward throttle to make the car spin from reversing. Going forward it's 4WD going backward it's 2WD.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-13-2009, 11:18 AM   #9487
marvin2.5s's Avatar
Smile
I have a TC3 RTR & TC4 RTR. i have had my TC3 since i was 11yrs old & have won many races with it but now i retired it & put my TC4 RTR back on the track. i use a 7 yr old motor & old lrp v.71 speed control & have beaten much newer cars. it all depends on driving & setup. i don't use lipos lol & still use the stock AM radio that came with TC4 RTR. The TC4 is a good reliable car if u set it up good u will do good.
TC5R
Ofna JL10E
Team Associated TC3 RTR / TC4 RTR / SC10
NISSAN/NISMO
MB racing technology
marvin2.5s is offline   Reply With Quote
Old 06-13-2009, 11:48 AM   #9488
Hooligan_'s Avatar
Thanks again Fox I just got a Hudy Ultra Fine Chassis Ride Height Gauge, Hudy Ultra Fine Chassis Droop Gauge (4.0-6.6mm), and Hudy Chassis Droop Gauge Support Blocks. Can's wait to get things a little more fine tuned.
Minus the ride height you just posted... are these the settings your still using?
Toe:
1.0 toe-out front
2.0 toe-in rear
Camber:
-1.5 front
-2.0 rear
Caster:
3 front
2 rear
Springs:
pistion #2, 40W, Blue front
pistion #2, 40W, Blue rear
Ride height:
4.5mm front
4.5mm rear
Droop:
4.5mm front
4.5mm rear
Sway-bars:
black front
black rear
Differentials:
Spool front
Ball Diff rear
Tires:
28R front
28R rear
Just a side note. I have my shocks laid down three holes in the front and one hole in the rear.
Old 06-15-2009, 07:19 PM   #9489
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Dont do this to yours...
http://www.youtube.com/watch?v=sqD5b...eature=related
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 06-15-2009, 10:41 PM   #9490
Holy @#$%, things is you can even see that the driver is turning the car to avoid that barrier but at those speeds alot can happen with small of amounts of steering.
Old 06-16-2009, 08:43 AM   #9491
Foxxrocket's Avatar
Toe:
1.0 toe-out front
2.0 toe-in rear
Camber:
-1.5 front
-2.0 rear
Caster:
3 front
2 rear
Springs:
Ride height:
4.5mm front
4.5mm rear
Droop:
4.5mm front
4.5mm rear
Sway-bars:
black front
black rear
Differentials:
Spool front
Ball Diff rear
Tires:
28R front
28R rear
I changed the sway bars to blue, use 30R tires, and run 6 of caster in the front. The car tracks stright, but seems to flot to the left on the back stretch. I can never seem to get rid of that, no matter what I change.
Old 06-16-2009, 09:26 AM   #9492
speedsterblade's Avatar
maybe that is just the torque steer of the shaft drivetrain? mine pulls to the left on WOT. I just try to adjust the trim so it tracks straight down the straight.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 06-16-2009, 09:35 AM   #9493
pakk's Avatar
Trader Rating: 79 (100%+)
My car tends to pull to the left slightly at low speeds WOT, but I think it is more of a traction issue. Once it gets going, it is strait. Even when I had a 2 way and would brake, the back end would come out to the right(making the car go left). I never could get it to brake strait with a 2 way.
I don't know what motors you guys are running, but with a 17.5, I don't sense the torque steer people talk about. I think my issues are purely due to the car not being balanced. I really need to get some scales and get that done.
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 06-16-2009, 09:52 AM   #9494
Trader Rating: 14 (100%+)
Default Need a little advice
I am buying a couple of TC-4's from a freind of mine. He said he will go through them before I purchase them. I need some advice on some "must" items I need to purchase before I hit the track. My plans are to run a 13.5 brushless system on the better of the two cars. What would you all recommend to set the car up correctly?
The worse of the 2 I plan on using in the Vintage Tran-Am class. Since there is more room for error there. Any suggestions?? Love to hear them.
O....BTW... My home track in carpet-smooth- around 45x50???close..
SwampDog32 is offline   Reply With Quote
Old 06-16-2009, 01:09 PM   #9495
Foxxrocket's Avatar
torque steer is going to be your biggest issue with the TC4 when running 13.5.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 59 (2 members and 57 guests)
DARKSIDE, PJRacer
SEO by vBSEO 3.5.0
