Like Tree33Likes
Old 02-09-2009, 12:19 PM   #9316
TeamGoodwrench's Avatar
Anyone have a good TC4 setup for USVTA ?
Thanks !
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 02-09-2009, 12:24 PM   #9317
Here is my birds set-up, very easy to drive ... on carpet.
http://www.rcactionpics.com/trash/20...wbirds2009.pdf
Rojna is offline   Reply With Quote
Old 02-18-2009, 02:35 AM   #9318
Blind's Avatar
just got my used tc4, took it apart because I noticed some horrible grinding in the drivetrain, the diffs feel bad, but more than that the drivetrain is binding and gritty with no wheels or motor.
diff gears look fine, is there some flashing from molding process that need to be removed that's grinding away at the diff cases? Would the diff casing being over-tightened cause this?
Took it apart, blasted the whole car out with compressed air and removed all the damn carpet fibers from the drivetrain as it was a carpet racer, but it feels incredibly gritty to me
http://www.blindbatteries.com
http://www.ebay.com/usr/blind_batteries <-My eBay Feedback
Blind is offline   Reply With Quote
Old 02-18-2009, 03:05 AM   #9319
Blind's Avatar
also I'm trying to set this car up for outdoor asphalt VTA, looking at what pinion and spur I need to get for a 4.2 FDR with a 21.5 BL/ lipo setup.
I found a tamiya 42t/43t pinion kit on TH, but will that mesh with the stock 72t spur (should make a 4.286 fdr)?
Is there a way to get that ratio with 64p gears? I'd prefer to run them for the extra smoothness (if I can ever work the grittiness out of the diffs!).
a 96/56 would give me 4.286 frd also, are the PRS touring spur gears found on the bottom of this page -
http://ashfordhobby.com/detail.aspx?ID=4389
compatible with the tc4 setup?
Thanks for any pointers
Old 02-18-2009, 03:32 AM   #9320
Foxxrocket's Avatar
It could be the diff bearings. I would suggest getting them replaced. And maybe the drive pinion and diff gear, just in case. There should be no grittyness in the drive shaft or diffs.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-18-2009, 04:58 AM   #9321
M-Technic's Avatar
Trader Rating: 15 (100%+)
I don't believe 96/56 will be able to mesh with 64p. The cam for adjusting the motor won't move far enough to the left. I would recommend 80/47 (4.26). You will probably still have to Dremel down the area on the chassis that is right beneath the pinion gear to keep it from grinding on the chassis.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-18-2009, 11:40 AM   #9322
Blind's Avatar
the diffs spin smoothly on their bearings with the driveshaft/cvd's and pinions removed and the diff casings apart (so the diffs just sittings in the bottom of the casing)
it's when I drop in the pinion gears and bolt the diff casing together it gets crunchy, so I think it has to do with the mesh of the gears, or the gears hitting something in the case, but I can't really see any signs of that...
Old 02-18-2009, 06:50 PM   #9323
Thanks for the setup sheet. I am giong to try it next week. One question I haveis on the camber. why do most guys run positive camber? I would think negative (tire leaning in) would be better to get the tire to flatten the contact patch inthe corners. I ah\\have yet to run my car in VTA so I am trying to learn all I can. One setup I put on it had 2 degrees positive camber but that made the tires look bowlegged because they leaned out so far. Any guidance on the camber would be greatly appreciated.
Part Timer is offline   Reply With Quote
Old 02-18-2009, 06:50 PM   #9324
There is a lot a slop in my steering link to the steering rack. Is there anything, or way I can tighten it up?
Same on mine, anyone got any ideas how to fix it?
Old 02-18-2009, 07:28 PM   #9325
Originally Posted by Part Timer View Post
... why do most guys run positive camber?
I have never seen anybody run positive camber You will always run zero or negative ( top of tire leaning inside ).
I guess not puting the - before the 1 threw you off ...
Old 02-18-2009, 09:29 PM   #9326
Foxxrocket's Avatar
I did a search on this thread and found if you put shims under the neck of the steering bellcrank, and swing rack pivot posts, it takes away alot of the slop. It seems to work, because I have vary little slop in my steering rack.
Old 02-19-2009, 02:16 PM   #9327
Thanks,
I couldn't figure out why you would run positive. I guess it is from my days doing alignments in a Pontiac/Cadillac dealership. I had a teacher in auto school tell us the way to remember camber and caster is the out house theory. "You have to go out back to get a positive reaction"
Thanks again
Old 02-19-2009, 02:55 PM   #9328
liljohn1064's Avatar
Trader Rating: 16 (100%+)
too many shims causing the gears to bind?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-19-2009, 08:37 PM   #9329
gentleman81's Avatar
sup fellas, to those of u who run this car. with the same equipment, will this car hold up against the tc5, cyclone (budget model), and t2s???
want to get a car in the next month or so. i know im not gonna be the top dog. but there are guys around here that can flat out drive. no matter the equipment
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 02-19-2009, 09:42 PM   #9330
Foxxrocket's Avatar
If you can drive, yes. I've even seen some experts driver the older TC3. So, your limited only to your driving abillity.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
desertraton, Lone Drifter
