Like Tree18Likes
Old 04-16-2008, 08:42 PM   #9226
Send a message via AIM to fender_guy
Is the top-deck a drop in for the the Team Kit? I have been having some trouble with my steering as well, the car turns more in one direction then the other but I suspect that its a servo problem more or less.
fender_guy is offline   Reply With Quote
Old 04-16-2008, 09:11 PM   #9227
Scottrik's Avatar
Trader Rating: 241 (100%+)
A VERY common reason for this is if you missed the addendum that tells you to NOT set the servo horn straight vertical at "center" on steering but actually tip it about 1/8" (iir) toward the left side of the car (kinda like steering right) when your wheel is centered and the wheels are straight ahead.
Or if your radio settings are off, but check the above closely.
And no, the FT top deck isn't a drop-on for the Team car. The FT main plate is drilled for standoffs to support the top deck. FT's are available pretty reasonably, in fact I've got one I'd sell that's pretty nice. PM me if interested.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 04-16-2008, 09:19 PM   #9228
I'm not really looking for a new car but if you have parts then that I really need. I'm also pretty sure the servo horn is set up correctly (slightly off-center) but it still doesn't steer right. Maybe its the ball-joint being too stiff as I am not using the Associated Ball joint.
Old 04-17-2008, 08:36 AM   #9229
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Can you tell what it's binding on? What is limiting its steering one direction to the other?
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 04-17-2008, 08:50 AM   #9230
M-Technic's Avatar
Trader Rating: 15 (100%+)
In order to get equal steering travel left to right on my RTR TC4 I had to adjust the EPA on my Futuba transmitter to limit some of the travel in one direction, and to add some travel in the other direction. This is with the servo arm installed correctly, partially rotated to one side.
M-Technic is offline   Reply With Quote
Old 04-17-2008, 02:45 PM   #9231
I actually took a closer look and noticed that the servo mounts were cracked and when the servo arm moved it moved the whole servo so I went ahead and ordered some of the carbon mounts. Hopefully that will fix my problem. Thanks for the help guys!
Old 04-20-2008, 08:34 PM   #9232
Gain Time's Avatar
I have looked and there are several setups for the TC4. Can someone tell me on the best for running on carpet with foam tires? thanks.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 04-23-2008, 03:06 PM   #9233
Gain Time's Avatar
anyone? thanks.
Old 04-23-2008, 07:06 PM   #9234
British Menace's Avatar
Try this.
http://www.teamassociated.com/racerh...r_iic_2005.pdf
Regards,
British Menace
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 04-24-2008, 06:21 AM   #9235
Gain Time's Avatar
Thanks.
Old 04-29-2008, 01:53 PM   #9236
nutsisneat's Avatar
Default Issues with optional steel diff
I had my first run with my TC4. I wanted to have a spare car to my TC5.
I was only about 0.5 sec slower. So far so good.
I melted my rear diff. I had spare steel outdrives but the diff rings don't
fit due to the "D"-form of the rings. I hope you guys understand what i mean.
The shop on the track had rings from the NTC3 but they don't fit due to the
smaller dia. I ended up dremeling the rings to make them fit.
Surprisingly it worked. Does someone know the item# for the rings?
And also the # of the plastic part where the 2-56 locknut comes in?
(because there is no hex in the steel outdrives)
Thanks for your help...
nutsisneat is offline   Reply With Quote
Old 05-22-2008, 08:39 AM   #9237
mayhem3x's Avatar
Default Front Diff
Hey guys what are you running in your front diff. I run stock and always use a front one way but it seems spools and solid axles have been becoming more popular.
I always loved the how the one way worked in the stock rubber class but was wondering what expriences everyone else has.
mayhem3x is offline   Reply With Quote
Old 05-22-2008, 02:44 PM   #9238
M-Technic's Avatar
I run a spool for stock 27t as well as 19t. All the guys with TC4/TC5's at our track run spools in the front, and fairly loose ball diffs in the rear.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
Old 05-22-2008, 06:33 PM   #9239
mayhem3x's Avatar
That's the same thing i see around here. mostly everyone doing spools. That's why i was curious. I'm thinking about trying a spool and checking to see which is going to give me better results. When you go to the team associated setup sheets you see more spools on there setups also.
Old 05-22-2008, 06:43 PM   #9240
M-Technic's Avatar
It took some getting used to when a local racer handed me a spool and said go to town. The car had a lot more turn in and a lot more steering overall. I didn't like it at first but after adjusting, I loved it.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
