Like Tree59Likes
Old 09-07-2007, 05:35 PM   #9136
daveaustin5's Avatar
Originally Posted by Kraig View Post
Yes you can. There should be no difference between the two cars. Pay attention to the shims on them though. You may have to add or remove depending on how tight the gear mesh is.
Thanks, I'll try it out tomorrow. Saves me having to get some more balls. I thought they were the same but wasn't sure as the gear is a different colour (it's white on TC4, grey on TC3).
daveaustin5 is offline   Reply With Quote
Old 09-08-2007, 05:14 AM   #9137
Mitchell's Avatar
Trader Rating: 15 (100%+)
[QUOTE=AssocRacer;3646349]those are for aluminum posts if you ever decide to run foam. they make the chassis stiffer.[/QUOTE
i meen the ones directly above the drive shaft. sorry about not being specific
___ _________________________
___ |__|__|__|__|__|__|__|_____\
____ |__T Associated fan bus _|_| __\_
____ |_________________ |_| ____|
____ |_(@"@)____________|_|(@)__|
HOP ON BOARD!!
Mitchell is offline   Reply With Quote
Old 09-20-2007, 09:30 AM   #9138
straightspeed's Avatar
They're for the spline.
LEIGHTON BUZZARD MODEL CAR CLUB
straightspeed is offline   Reply With Quote
Old 09-20-2007, 01:24 PM   #9139
im upgrading to a 10.5 BL setup what spur and pinion should i be running?
Technik is offline   Reply With Quote
Old 09-20-2007, 01:28 PM   #9140
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
yeah, the holes in the middle are for a carbon fiber spine that goes around the driveshaft to add stiffness to the chassis.
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 09-27-2007, 07:45 PM   #9141
Just started racing on-road again, got my old TC3 and just got a TC4
When would I want to use the spool ?? I run the TC3 in 19t with a 10.5 BL , and the TC4 in 27t. What will the spool give me ??
Rojna is offline   Reply With Quote
Old 09-28-2007, 08:56 AM   #9142
pete68's Avatar
Default tc4
hi guy's just bought a team tc4 i need a good set-up for carpet racing
cs27 frt cs-22 rear
thanks
pete68
pete68 is offline   Reply With Quote
Old 10-20-2007, 05:55 PM   #9143
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody ever run a TC4 in a oval class? Since I'm only being able to race my TC5 only a couple of times a month. I'm thinking of doing oval at my local track out of boredom. I think it would make a better oval car than the TC5 since the batts are on the left side.
Dasupacat1 is offline   Reply With Quote
Old 10-20-2007, 10:46 PM   #9144
Send a message via AIM to airborn
hey dave..
yeah man Marshall just got a tc5 and is running it on saturdays with us in nastruck and he did pretty good. but he used lipo and stacked the lead up on the left side. I used a F/T TC4 for oval and it worked great. Hey you should really consider running this winter with us nastruck guys you have every thing you need hear is the rule page I made
http://www.geocities.com/yeahbutitsm...Cup_Rules.html
we will be running a ten race series with big troghys and door prizes even.
let me know what you think.
seth
airborn is offline   Reply With Quote
Old 12-19-2007, 10:14 PM   #9145
DRAG_ON's Avatar
spool will give you front and rear brake......with spool car will be easier to drive compare to one way front drive.
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 01-10-2008, 10:59 PM   #9146
I'm a little behind the times here grabbing my TC4 now, but can someone tell me if I'm on glue.
It looks as though if you follow factory directions for steel diff
that it's not going to be able to locate the cvd very well as per below
I 'crushed the spring' with pliers... should I be putting it in a vice, or should it be turned around? like so...
TeamCK is offline   Reply With Quote
Old 01-11-2008, 12:08 AM   #9147
DRAG_ON's Avatar
i think you should put the T-Nuts on the longer side of the steel outdrive not the short one..............it have been revised by associated
Old 01-11-2008, 03:14 AM   #9148
I happen to think the tc4 is still a good ride. Just switched back to two of them running the tub chassis. I just couldn't follow through and get the tc5s as i am just too used to this ride.
WingZero is offline   Reply With Quote
Old 01-17-2008, 06:12 PM   #9149
paul73rc's Avatar
Trader Rating: 5 (78%+)
Is the TC4 a good drift car?
paul73rc
paul73rc is offline   Reply With Quote
Old 01-17-2008, 09:43 PM   #9150
majicman's Avatar
I got a ss17.5 pro to run this weekend at my club race (parking lot track). Any idea how I should/can gear this thing in my tc4?
The instructions out of the package say two teeth up from a brushed 27t, the tc4 instructions recommend you to run a 28t on a 27 turn motor which would put the starting point at a 30t does that seem a bit undergeared for a motor that only puts out 2,200kv?
I am planning to run LIPO with this, I can geared it as high as 69/32 with my available pinoin selection which puts it at 5.39 FDR.
Any advise would be greatly appreciated.
majicman is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
