Like Tree5Likes
Old 10-24-2004, 02:59 PM   #886
bubbles's Avatar
Originally posted by diskostew
Chris, where did you get the blocks? i need to go pick some up... Did tony say when the swaybars will be out???
see ya at SoCal soon... I couldn't get off work in time yesterday...
Remember about a week ago, I posted that I had given my parts list to Mas, and said we might have parts at SoCal in the coming week? Well, we got them... Apperently, we had Triangle, Circle, Square, and three different X blocks. The X blocks were, 2, 2.5, and the original 3. When I showed up on Saturday morning, we had already sold out of the 2.5 X block. So hopefully, we should have more in stock this coming week...
I did not ask Tony about the sway bars, I figure: Everyone and their mother has been asking the same things, so why pester the poor guy even more? hahaha.
Chad told me that the sway bars are almost the same. The only difference, is that for the TC4, you have to cut the bars shorter. I thought, that was some valuable information.
Side Note: Mas talked with Kurt lastnight about the outter hingepins being bent upon time of purchase. He said that they were from a bad batch of hingepins, and that this upcoming batch should be error free...
Losi xxxs, are you using the Factory Team TC3 hingepins on the outter locations?(I thought about installing the Factory Team hingepins fromt the TC3) I have not had a chance to measure, but I am thinking that the TC4 has a slightly larger pin diameter... Using the stock hingepins, I don't have much play at all...
bubbles is offline   Reply With Quote
Old 10-24-2004, 03:16 PM   #887
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally posted by LoSi xXx S
have you guys notice that the rear castor blocks wabble like crazy? what can i do to get rid of some of that ?
Rear castor clocks?? One thing I did notice is that my front ones have alot of play for a brand new car. What is actually happening is that the hinge pin is tilting back and forth inside the A-arm where the small .050 retaining screw is. Anyone else's car do this? Was just wondering if maybe I got some that were a few thousands too small (diameter). No screws or ball studs are loose, it's actually the pin moving like a see-saw.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 10-24-2004, 05:06 PM   #888
i personally thought the arms had some play in them sliding on the pins...not quite enough shimming??
also, ive seen two built now where the batwings, where the camber links mount, when you tighten the ball studs, you cant tighten them, but instead 'snug' them, as the batwing cracks when you tighten them...
punkboy is offline   Reply With Quote
Old 10-24-2004, 05:08 PM   #889
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
yeah tap the holes forst to reduce the likelyhood of cracking
myclod is offline   Reply With Quote
Old 10-24-2004, 05:17 PM   #890
I built one, then Daniel built one, and we both had that problem...he hates that car already...lol, but he's gonna run it anyway...it will still be fast as hell thats just Daniel
Old 10-24-2004, 05:20 PM   #891
Sposed to get my TC4 last Friday but due to Associated only sending a limited number over we decided not to reserve any for our staff and instead send them all out to the UK stores we supply
Gotta wait another week or so for the next batch.
Still better late than never....
Just wondering.....does the blue TC3 alloy screw set fit? I presume it mostly will even if there are a few out
Andy M is offline   Reply With Quote
Old 10-24-2004, 05:24 PM   #892
myclod's Avatar
for the most part the screw set is pretty close, there are a couple of new screws but they are ones i don't think i would want to change anyway
Old 10-24-2004, 05:58 PM   #893
TPhalen's Avatar
R/C Tech Charter Subscriber
To answer some questions:
Yes, the TC3 caster blocks will fit the TC4....only difference is the TC4 are now symmetrical on BOTH sides of the block, whereas the TC3 were not.
Bubbles: ask away, dood. That's what I'm here for!!!! On a side note to the swaybars; you should NOT have to shorten them. If Chad is, he is doing that for who-knows what reason.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-24-2004, 06:13 PM   #894
Default Punkkboy, Branson Melton, Losi XXXS...
I have the same problem with mine. Lots of play in those locations. I hope Ae will tighten up the tolerances. Otherwise it's a great car.
Nightbreed is offline   Reply With Quote
Old 10-24-2004, 06:25 PM   #895
for the play in the arms, motor shims work well...
Old 10-24-2004, 06:29 PM   #896
tc3 racer sc's Avatar
Default got my kit
got my kit not going to put it toghter yet because im waiting on my carbon kit to come i see my friend brandon melton had a good run yesterdy way to also kilruf cya soon will be in orlando this weekend watchng the touring race thur/ sat
tc3 racer sc is offline   Reply With Quote
Old 10-24-2004, 06:29 PM   #897
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
why didnt associated make alum. arm mounts and tit. hingpins i think associated is getting cheap and the bumber has really no use the bumber dont even cover atleast some of the wheels. so if you guys are taking a turn and hit the wall say bye to that a-arm . but that car is still nice.
Roberto Falcon is offline   Reply With Quote
Old 10-24-2004, 06:37 PM   #898
they hve the aluminum arm mounts part#31064/ thru31069 and factory hinge pins too call associate to place ur order
Old 10-24-2004, 06:40 PM   #899
Arm Shimming..... why not use:
AS31010 - TC4 Arm Mount Shims?
Or are these different?
Old 10-24-2004, 06:40 PM   #900
oh opps well nvm lol
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Coyoteh, patorz31
