Like Tree1Likes
Old 01-15-2007, 08:55 PM   #8971
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally Posted by DaveW
Its good to see ya come back to your roots Brandon. Have ya talked to KT lately?
I got his new number but have yet to call, I need to though, was worried at first he didn't make it back or something after all the numbers were changed and his IM didn't work. Good to know he's back safe, just hate he's not racing anymore.
Brandon Melton is offline   Reply With Quote
Old 01-15-2007, 09:03 PM   #8972
It makes the buzzing sound all the time. If its the potentionmeter's problem, how do I get it replaced?
Does it make the buzzing sound when attached to the steering linkage, or does it buzz all the time with no servo horn attached? If it is NOT attached to the steering linkage and it buzzes all the time, then the potentiometer is most likely shot in the servo, and it should be replaced or repaired. If it only buzzes when it is attached to the steering linkage then either something is binding in your steering linkage and/or it IS a weak servo and it just doesnt have the strength to move the linkage completely to neutral, again, check to be sure your steering linkage moves freely back and forth without the servo attached. If everything moves fine with minimal binding, and the servo still buzzes, you might want to check into a better servo. Something in your price range with a minimum of 75oz/in of torque, and a transit speed of your choice would be a wise investment. One of the first and best upgrades to your TC, next to driving/practice time, it a good solid servo.
kytan is offline   Reply With Quote
Old 01-16-2007, 01:18 PM   #8973
MleedM's Avatar
Default Front Suspension Tuning
Hi,
When I'm coming off the straight at my local club (foam on carpet) and into the sweeper, I can see that the inside front wheel is up off the ground.
What adjustment would help keep it down best?
I have 4mm of droop and Purple springs up front (3rd stiffest).
I'm thinking 1 - 1.5 mm of added droop and maybe Gold springs.
Not sure that it's having much of an effect, but I cannot see how having a wheel off the ground helps.
MleedM is offline   Reply With Quote
Old 01-16-2007, 01:29 PM   #8974
I am looking for a good rollout for a TC4 on Oval, Also I was wondering if I am calculating the rollout correctly...What I was told to do by a person at the track is
(tire diameter(inches)x(3.14)x(pinion) all divided by the spur.But from other rollout formulas I have seen they were using the transmission ratio...Can you guys point me in the right direction, thank you Jeff
jeffbhhs is offline   Reply With Quote
Old 01-16-2007, 01:54 PM   #8975
adamge's Avatar
4mm droop?!?! That's way more than usual. Most carpet foam setups use 0-2.5mm droop.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 01-16-2007, 04:13 PM   #8976
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
I was gonna say, wow...that is ALOT of droop....i run 2mm max.
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 01-16-2007, 04:16 PM   #8977
He is probably reffering to the reading on the droop gauge, not the actual amount of up travel in the car. Just like when looking at an AE setup sheet it gives droop, that is the gauge reading when it says 4mm.
Old 01-17-2007, 08:31 AM   #8978
MleedM's Avatar
Default Transmission ratio
Hi,
What is the transmission gearing ratio for a FT TC4? 2.5 like the TC3 or is it different. AE has nothing on it's site (that I can see).
Oh, yes, the droop I'm reading is the 4 on the droop gauge.
Mike
Old 01-17-2007, 08:38 AM   #8979
ShaunMac's Avatar
Originally Posted by MleedM
Hi,
Mike
FT TC4 transmission ratio is 2.5
ShaunMac is offline   Reply With Quote
Old 01-17-2007, 08:43 AM   #8980
MleedM's Avatar
Default Ratio
So using "R/C Car Gear Ratio Calculator", I have a Gearbox ratio of 2.5, Spur of 72 (right??), Pinion of 27, RPM around 20,500 and I'm guessing tire diameter of 2.2" (slightly worn GQ's ... what typically is the diameter of new tires? I don't have access to them right now). It says that my to speed is 20mph? Would this be about right then?
thanks
Old 01-17-2007, 09:37 AM   #8981
I am still looking for a good rollout to start at and a good way to calculate it. Any help would be greatly appretiated
Old 01-17-2007, 09:42 AM   #8982
MleedM's Avatar
use this calculator "R/C Car Gear Ratio Calculator" www.waits.net
It gives you rollout
What is rollout?
Old 01-17-2007, 11:29 AM   #8983
I wasent really having the trouble finding the sites to calculate it, but rather I was looking for what a good starting point would be to try and get my rollout to...I am racing oval carpet on a fairly large track...I was also looking for the real formula to work with, since I do not have the computer at the track with me...Thanks again Jeff
Old 01-17-2007, 12:51 PM   #8984
ShaunMac's Avatar
Tire Diameter x 3.14/FinalDriveRatio = Rollout........FDR = Spur/Pinion x Transmission Ratio(2.5 on TC4)
example: 57mm x 3.14/7.0 = 25.57mm
Rollout = 25.57mm
Rollout is the distance the car will travel with one revolution of the motor.
Old 01-17-2007, 01:33 PM   #8985
thank you, Do you have any suggestions on what a good starting point for rollout would be though? right now I am running a 29t/72t with a stock motor (epic)
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
