Team Associated TC4
#8941
Originally Posted by AssocRacer
my guess would be slow as hell. Dont have any 4 cell packs anyways, and have no interest in running one with 4 cells. Even if roar makes it a rule, you'll find most club races will still use 6 cell packs. I mean, that's the main reason why people come to TC, the speed. I think it would be a major mistake if they actually go to 4 cells because TC is already not near as popular as off road because it's so much more expensive to be competitive then it is in off road.
In the stock and 19t classes, you can make a car go an equivalent speed simply by using a lower turn motor. A friend of mine spent the best part of a year using 4 cells only in his touring car, motor wear is considerably lower and his car was hard to keep up with through the tight sections because of the lower weight.
#8942
FT TC4 cannot go straight.
I'm pretty new to this hobby and have problems with my FT TC4's as it always sway to the right. Had my car setup today and the toe and camber settings are all ok. But when I put it on track, it seems to go right. What could be wrong?
Regards.
Regards.
#8943
Regards.
Regards.
#8944
is it possible to use the yokomo one way with the tc3 / tc5? if so, what bearings are required as the associated dont fit over the yoke unit?
thanks, john
thanks, john
#8945
thanks, john
thanks, john
#8946
Thanks for the quick tip LJae.
Some question for you:
1. Is there a recommend length for the steering rack turnbuckles? I've turned mine to the shortest just to get the steering rack centered. Am I doing the right thing?
2. Could the steering trim solve the problem of the car swaying right under hard acceleration?
3. According to the manual, the servo horn should be turned 3mm clockwise. That would mean that the steering actually move more clockwise as compared to turning the steering the other direction. Am I correct?
Excuse me for all these queries. I don't know if I'm doing the right thing with the steering.
Cheers.
Cheers.
Originally Posted by LJae
The first thing that comes to mind is to adjust your steering trim on your radio. As hard as I try to get my servo centered and the servo horn positioned correctly, I still have to adjust the steering trim on my radio to get the car to track straight. Hope that helps.
#8947
kytan - Are you running a modified motor in your TC4? You might be experiencing some Torque Steer. It's not really noticable with stock motors, but with Mod and Brushless motors it becomes more of an issue. The only 100% cure all for Torque Steer is a belt driven car. That's one of the reasons so many AE fans can't wait for the new TC5.
Trim will only solve your problem if the car always pulls to the left at any speed. If it only occurs during acceleration it's most likely Torque Steer or Tweak.
Set up your steering the way stated in the manual. When the wheels are centered the steering horn should be pointing to 1 o'clock. This will make the steering more balanced from right to left.
#8949
Super Moderator
thanks, john
thanks, john
#8951
Regards.
Regards.
... a stock servo can be underpowered to center your steering... but it usually will wander in the last direction turned... wandering BOTH directions... also check to be sure your servo doesnt move... if you hit a board or wall and that force is transferred to the servo and the servo moves then you will have to recenter your radio again to make up for how much the servo moved in the mounts... also, check your servo saver to be sure it is tight.
#8953
Originally Posted by RCpurplecow
I'm pretty sure no parts will be shared between the tc5 and the tc4.
#8954
#8955
The parts ShaunMac posted are what someone working at Associated said in the 'Rumours of an AE touring car' thread. The diff outputs a definately different, and seeing as they werent mentioned I'd say its pretty definate that the CVD's will be different too. Looks like AE have started from the ground up with this one
