Like Tree38Likes
Old 12-06-2006, 03:23 PM   #8851
Can you post your setup. Also, is the car doing that on left AND right turns or just in one direction?
DOTMAN is offline   Reply With Quote
Old 12-06-2006, 04:30 PM   #8852
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default set up sheet
Thanks dotman
our track is a fast flowing, low to med traction asphalt.
its slowest corners are off camber as its situated on a slight hill..
the car steps out exiting a corner off power...(using 4 deg blocks with +3 front kick up wich is 7 deg castor)..tried castor to neg.(went 4mm spacers both front arm arm mounts) .and it stepped out into the corner off power...
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 12-06-2006, 04:49 PM   #8853
AM03GT's Avatar
mikecatts, post your full setup and it might help everyone give you more solid advice...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 12-06-2006, 05:01 PM   #8854
Originally Posted by mikecatts
Thanks dotman
There are plenty more adjustments to check to see if it is OK. I would suggest putting it back to the kit setup, it works nearly everywhere. Then adjust slightly from there.
Fill out the set up sheet from the AE website, and people will have more idea to help you.
Matt Dall is offline   Reply With Quote
Old 12-06-2006, 05:27 PM   #8855
mikecatts's Avatar
here it is.
Old 12-06-2006, 05:50 PM   #8856
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
That's almost the same setup i have. Except, change to 30 wt oil front and back and put blue springs on the front, 2 circle shims in the front, 2 washers under ball stud, square and x both 4 for the shims and no anti roll bar in the rear. the front suspension should be alittle stiffer than the rear. i would start with the oil and springs.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 12-07-2006, 02:46 AM   #8857
here it is.
Mike, I see you are from SA, I'm in NSW. With respect to the guys in USA, they would rarely run on tracks like ours. They refer to our level of grip and surface quality as parking lot style racing.
You seem to have radically stiffened the front of your car compared to the rear, only ever on foam tyres with good grip did I run that stiff.
Is the suspension balanced out? eg tweaked?
If you are struggling to get grip with 27's then take the 1 way out and run the diff instead, it will allow you to drive much harder into the corners. Also consider that you might be "cooking" the rear tyres, as it has been bloody hot recently. I've been using Sorex 36 and wanted to go to 40's.
I will send you a set up that I've been using at SMA in Sydney, also a low grip tight and twisty asphalt track sometimes quite dusty. My car is hooked up.
Old 12-07-2006, 03:16 AM   #8858
By the way, any of you guys got any photos of a TC4FT chassis set up with the factory team ducted cooling fans?
Regards,
Old 12-07-2006, 07:07 AM   #8859
Default TC4 into a TC3
hi there
I need some help figuring this thing out. Can below TC4 parts fit onto a TC3 chassis?
1. front and rear Shock towers
2. diff case
3. front and rear chasis braces
rcfordummies is offline   Reply With Quote
Old 12-07-2006, 07:37 AM   #8860
S_fender's Avatar
Originally Posted by rcfordummies
hi there
2. diff case
Yes they all fit onto the tc3
S_fender is offline   Reply With Quote
Old 12-07-2006, 09:06 AM   #8861
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Thanks dotman
If you oversteer during a transition to off-power (in other words as soon as you let go of the trigger), then you should think about slowing that transition of weight transfer down which means shock oil in the front - go up 5-10lbs.
If you oversteer after the transition to off-power (in other words a split second AFTER you let go of the trigger), then you should think about lessening the AMOUNT of transition which means going up a step on spring rate in the front.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-07-2006, 03:21 PM   #8862
adamge's Avatar
Boomer, I'm grateful for your post. If you write a large collection of similar setup tips, please publish it well enough for me to find.
-Adam
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-07-2006, 03:29 PM   #8863
I think that a Yellow 35lb spring and 60 weight oil is a bit too stiff for a bumpy, outdoors aussie style track. From my experience anyhow.
This is what I have been using at our track, also have tested it with the Novak 3.5 Motor and it is still quite good. I have tried it with the 1-way diff and it has more turn in but you cannot stab the brakes into the tight corners as hard.
Sorry the PDF is too large?? PM if you want it.
Regards,
Old 12-07-2006, 04:07 PM   #8864
RCpurplecow's Avatar
New question,
I'm thinking of getting Acer Racing bearings for my FT TC4. Do you think they will fit on the AE Beltcar? If only some fit, does Acer sell individual bearings?
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 12-07-2006, 07:18 PM   #8865
Mr.Maim's Avatar
Trader Rating: 36 (100%+)
rcfordummies: F.Y.I. TC4 front steering blocks and rear hub carriers also fit on the TC3. The TC4 front steering blocks give you a second steering link mount location for more agressive ackermann settnigs, something that the TC3 steering blocks don't offer. The TC4 rear hub carriers don't have the hole for the grub screw that locks the hub carrier pivot bar, but a 1/2 drop of CA on the front and rear of the rear arm where the pivot enters and exits the axle is more than enough to keep it in place.
I run a TC3 and these parts and tricks work for me daily.
Best of luck! Mr.Maim
hi there
2. diff case
Mr.Maim is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
