Like Tree38Likes
Old 09-09-2006, 12:55 AM   #8746
S_fender's Avatar
With Cyanoacrylate (CA) glue
S_fender is offline   Reply With Quote
Old 09-09-2006, 01:26 AM   #8747
ford_racing's Avatar
Send a message via MSN to ford_racing
very interesting, ive never seen that before
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 09-09-2006, 04:13 AM   #8748
gofastrlbrown's Avatar
Send a message via Yahoo to gofastrlbrown
You may want to take it to your LHS, sometimes just a fresh set of eyes will find something silly that you were looking at the whole time. That is the way it usually works for me!LOL! RB
gofastrlbrown is offline   Reply With Quote
Old 09-10-2006, 11:00 PM   #8749
juhn X's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to juhn X Send a message via Yahoo to juhn X
Default Diff Problem on my Tc4
HELP! I have a problem on my diff. After the race as I feel/turn the wheel the diff lock/tight. Then about 5-7 min if i turn them it gets loss/smooth again.... I rebuild them so many times but they keep locking/tight after the race.
juhn X is offline   Reply With Quote
Old 09-11-2006, 01:00 AM   #8750
sounds like a seized bearing or you are assebling them the wrong way, there are different ways to assemble the diffs from the steel and plastic diff halves
ARC R11
Yokomo YRF001
AE B5m
Old 09-11-2006, 09:23 AM   #8751
Just built my TC4, there is too much play on the steering, how can I improve it? Do you have the same problem?
ioxqq is offline   Reply With Quote
Old 09-11-2006, 09:36 AM   #8752
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by bigair78
Team Associated just replied to my problem with this:
Make sure that your servo is not over-steering the steering block. This would cause a slight binding in the driveline as the CVDs are at an extreme angle.
Now how do I do this? By turning down my epa on my controller?
Turn down your dual rate on the radio...
I have my epa set to full 125% Left and Right, but my dual rate (set to my thumb button, so I can change it on the fly...) is set to 60% on a open track it is less then this, on a tight track I have had it as high as 74%....
bvoltz is offline   Reply With Quote
Old 09-11-2006, 03:06 PM   #8753
Default TC 4
I had a lot of problems with mine and finally I bought a RTR and upgraded the car with the parts that I wanted to upgrade.
RB
Old 09-11-2006, 03:18 PM   #8754
Send a message via Yahoo to apexraceway
Default Hey Barry...
How did the FT chassis work out for you???
Are any of your group gonna be at Regionals?
I heard about the Big Chill race...you can count on the Louisiana boys to be there!
laissez les bon temps rouler!!
apexraceway is offline   Reply With Quote
Old 09-11-2006, 03:22 PM   #8755
Default hey gofast...
Did you ever try that setup I sent ya?
Jeff
Old 09-11-2006, 03:27 PM   #8756
Use this: http://home.sc.rr.com/mlufaso/rc/FTTC4/index.html to set up your radio properly. The bit you want is near the bottom of the page...
ralph_c is offline   Reply With Quote
Old 09-11-2006, 07:34 PM   #8757
Default Setup Sheet
Hey Jeff,
I have it set up according to sheet, but I have not been to track to check out lap times. It feels good running on the street at the house. I really do appreciate it and I will keep you informed. I may be at the track tomorrow to do some pratice with my touring car and my oval on the round track. Lately, I been trying to learn how to fly a helicopter with very little success. I need to get back on the ground. RB
Old 09-13-2006, 12:21 PM   #8758
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
I would like to get everyones opinion on this. I have been looking at setup sheets and I have an issue with how the arm spacing is noted on the sheet. for this sheet as an example:
http://www.rc10.com/racerhub/setup/r...o_dhi_2006.pdf
Does the setup show the front arm arm all the way to the front of the car or all the way to the rear. Also is the Rear arm all the way to the front or all the way rear?
For the front suspension there is the "Arm Spacing" section which have four dots and "Back" at the top and "Fwd" at the bottom. lets say that the third dot from the top is left blank. That is where the arm is supposed to go with 2 shims in front of the arm and 1 behind, right? The most confusing part is that it says "Back" and "Fwd" and for the rear it has "fwd" at the top of the box and "back" at the bottom.
Wouldn't it be more clear to change the "Back, Fwd" with "front of arm" and "Rear of arm".
Whats everyone think.
Corey
RoachRacing is offline   Reply With Quote
Old 09-13-2006, 01:05 PM   #8759
scottwk1's Avatar
Roach,
My understanding on the spacing is there are 3 spacers behind the arm on the front and 3 spacers in front of the arm on the rear, so the front arm is all the way forward, and the rear arm is all the way back.
scottwk1 is offline   Reply With Quote
Old 09-13-2006, 07:40 PM   #8760
Default hi all
hey every body im brand new to this site. Not new to the game though. i just bought a AE tc4 and this is the largest and best forum for this car. this will be my first electric touring car. i used to drive nitro touring cars like hpi rs3 and an hpi nitro MT racer. I currently have a duratrax evader ST pro modded heavily very fast. brushless and all.. anyway just wanted to tell you all that i plan to race this car. I plan to race in the 19 t limit class. I do have a few questions.
1- stock out of the box with a 19t motor can this car win races?.
2- do i have to do any neccassary modding before entering a race? Does anyone have any suggestions.
3- what 19 t motor do you guys like.
If theres anything im missing, right now i cant think of anything else, but i guess as with any new hobby you get into trial and error will always take affect. please dont hesitate to let me know either here or message me... thank you and look forward to knowing you guys better in this forum.
cheech4 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
