Old 10-23-2004, 09:24 AM   #856
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Michael Lufasos Website
Hes got a carpet TC4 setup.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 10-23-2004, 10:02 AM   #857
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
well...just like they say with real cars...Chrome don't make it go....
myclod is offline   Reply With Quote
Old 10-23-2004, 10:26 AM   #858
Bob Nilsen's Avatar
Thanks for the Lufaso links... I'll check 'em out.
I'm about halfway done building the car... and I think it's a nice improvement from the TC3 racer I built a few months ago.
Indeed, the transmission is much more free out of the box than the TC3 was, which was great.
Built tips (from a novice :
- I felt I had to "take the edge off" that little hole in the chassis that provides access to the servo saver tensioning bolt to get completely free steering arm movement.
- The rubber bearing *are* pretty packed with grease... and move much more freely after removing it and replacing with bearing oil. I also left several of the rubber bearing seals off of most of the sides of bearings that were not likely to be exposed to dirt. Without having been broken in, the drivetrain moves about as freely as my broken-in TC3.
Bob Nilsen is offline   Reply With Quote
Old 10-23-2004, 10:26 AM   #859
Trader Rating: 4 (83%+)
Send a message via AIM to letitroll
Default Caster?
I called associated last week to see if the old TC3 caster blocks will work on the new car. They firmly said NO! I somehow didn't believe this so I got a set of 4 degree TC3 caster blocks and put them on my car. I have to say I think they work! There appears to be no rubbing or grinding and the dimensions are the same. My question is, Why did associated tell me the old blocks wouldn't work? and is there a chance I'm missing something and the blocks really don't work on the new car?
Allso, even with the old caster blocks and pollished hingepins my suspension seems to be binding. How do you solve this? is there a way to polish the hinge pin mounts?
letitroll is offline   Reply With Quote
Old 10-23-2004, 10:35 AM   #860
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
well the only thing to find out is test it out . which one feels better the tc4 tc3 or no difference.
Awesomatix USA - Speed Passion - Superior Hobbies
Roberto Falcon is offline   Reply With Quote
Old 10-23-2004, 11:07 AM   #861
diskostew's Avatar
Send a message via Yahoo to diskostew
Originally posted by Peter Busch
Has anyone figured out an alternative to the steel turnbuckles yet?
BTW, this is a nice car with lots of good improvements, can't wait to run it.
The Factory Team turnbuckles are all ready out... i used them when i built my car...
diskostew is offline   Reply With Quote
Old 10-23-2004, 11:22 AM   #862
TPhalen's Avatar
R/C Tech Charter Subscriber
letitroll: Not sure who you talked to, but the caster blocks will fit from the TC3 to the TC4.
Ti Turnbuckles: A kit should be out already, but you can adapt your TC3 ones to fit the TC4.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 10-23-2004, 11:27 AM   #863
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Tony, thanks for clearing that up for all of us. That is one of the things I was wondering, as well.
Do you know when front arms will be available? That is one of the few things shops seem not to have. Being that front arms are one of the most likely parts to break in a crash (for any car), I would think you guys at AE would want to get those out quick.
FT parts look sweet, how would you rate those hard ano'd shock bodies vs. the blue besides the bling factor?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-23-2004, 12:57 PM   #864
TPhalen's Avatar
Arms should be available now. Not sure why they aren't at your LHS. Might check with them. 9 times out of 10 is the LHS hasn't ordered them....not that we don't have them in stock.
Shocks. Blue anodized work great. Most of us have moved to the hard anodized because it wears better....the blue anodize is for looks.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 10-23-2004, 01:19 PM   #865
what you guys think my local hobby shop has the tc4 for 219.95 plus tax?
Old 10-23-2004, 01:27 PM   #866
I figured that was the reason for going to the hard ones. Although I'd have to say I think they look just as good if not better than the blue, IMO. I know the blue ones are smooth, I've built them many times.
USVTA Member #211
Old 10-23-2004, 03:33 PM   #867
Default Boomer, when did I ever complain about...
the shock fit? I was saying there are much better shocks on the market. In terms of "Better' well, that's up to the individual. For me, it's easy building, smooth, and longer performace.
Nightbreed is offline   Reply With Quote
Old 10-23-2004, 03:49 PM   #868
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Thumbs up PM
Nightbreed you have a PM
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-23-2004, 11:20 PM   #869
Default TPhalen...
are the TC3 caster blocks exactly the same as the TC4? If not, what are the differences? I have not got a chance to pull out the caliper.
Old 10-23-2004, 11:28 PM   #870
Default I think there is a weak spot on the front
arms. There may not enough material around the outer hole. I'm still waiting for replacements arms from my Hobby store.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Firefox
SEO by vBSEO 3.5.0
