Like Tree19Likes
Old 07-21-2006, 03:49 PM   #8626
The TC4 aluminium threaded shocks (standard on ft) are great if you buy the VCS2 kit so they use bladders/diaphragms instead of the weird foam system thats standard. If you're running stock or 19t get the IRS (irrgang) composite CVD dogbones, then use the standard outer cvd part (which the hex goes onto). The wear with these CVD's is almost non-existent (none where the pin goes through the dogbone in about 6 months of racing) and they're a lot lighter too.
ralph_c is offline   Reply With Quote
Old 07-21-2006, 04:35 PM   #8627
vic2367's Avatar
Trader Rating: 14 (94%+)
Send a message via AIM to vic2367 Send a message via Yahoo to vic2367
am running brushless with lipo battery,,,tired of breaking those dogbones,,,want something stronger that will last,,,as for the shocks am looking 4 something already built,,,will the hot bodies blue shocks for the hpi work ..they are already built,,,they are the hbs 24001 at southeast rc ....
vic2367 is offline   Reply With Quote
Old 07-24-2006, 12:47 AM   #8628
Wasabi's Avatar
It's probably in here somewhere, but does anyone have a good set-up for a med-bite, tight, small track? Also gearing for stock and 19t motors (64p gears). Thanks.
Wasabi is offline   Reply With Quote
Old 07-24-2006, 01:21 AM   #8629
ford_racing's Avatar
Send a message via MSN to ford_racing
For setups
http://www.rc10.com/racerhub/setup/0setups_onroad.htm
I suggest using a Barry Baker one, they work very well for me.
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 07-24-2006, 06:37 PM   #8630
Wasabi's Avatar
Which one? Will it work for or a med-bite, tight, small track?
Old 07-24-2006, 08:21 PM   #8631
corradopsi's Avatar
Send a message via AIM to corradopsi
selling my BMI tc4:
silver bmi chassis. lots of tuning parts. HD one-way. 3 complete diffs and parts for 3 more just need balls and rings. lots of spares. 8 shocks for easy swaps from asphalt to carpet.
email me for pics and more specs at corradopsi (at) comcast (dot) net
thanks guys.
Mine: Nomadio Sensor; T2'007, Keyence, Express; ZX-5 SP, Mamba Max; XB8, OS V-spec and NR P5; ProBoat Shockwave 36
My Son: Futaba 3PM; T4 RS; Clodbuster; TT-01;Zig-Zag racer
corradopsi is offline   Reply With Quote
Old 07-26-2006, 01:55 AM   #8632
gofastrlbrown's Avatar
Send a message via Yahoo to gofastrlbrown
Default TC 4 Rocks!!!
I cannot wait to put a 4.5 novak brushless in one of mine as I have two to run with. Gofastrlbrown
gofastrlbrown is offline   Reply With Quote
Old 07-26-2006, 09:27 AM   #8633
vic2367's Avatar
i have the 6.5 on mine...i find it extremely fast..
Old 07-26-2006, 06:18 PM   #8634
Wasabi's Avatar
Originally Posted by ford_racing
For setups
Cool. I'll try his Novak set-up for 2006 as a starting point. Thanks.
Old 07-30-2006, 06:21 PM   #8635
Send a message via Yahoo to apexraceway
Default shocks for the TC4
I am looking at getting another set of shocks for my TC4. I have read that the Yok shocks are great...and some say go with Tamiya.
Does anyone have the part numbers for both companies? I know Yok makes two different lengths.
Thanks in advance for the info.
Jeff
apexraceway is offline   Reply With Quote
Old 07-30-2006, 07:53 PM   #8636
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Hi,I find out that the ae shock are bit long,need to put limited spacer 2mm at inner,so that the shock piston is working at the center of the shock when at car right height
James khoo is offline   Reply With Quote
Old 07-30-2006, 08:47 PM   #8637
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can anyone tell me were I can get a center one way for the TC4?
bvoltz is offline   Reply With Quote
Old 07-31-2006, 06:03 AM   #8638
frog racing's Avatar
Send a message via AIM to frog racing
I am confused with a "center" oneway. If you are looking for a front oneway I have a brand new one available for sale along with several other items for my FT TC4 I have up for sale
FS: FT TC4
The front oneway for the TC3 fits the TC4. The front oneway I have is packaged for the TC3 but is the same part according to Associated Parts listing on their site - rc10.com
Email an offer for the Oneway.
Frogracer -
8IGHT-E 4.0 KIT: 1/8 4WD ELECTRIC BUGGY
Tekin RX8, Tekin 1900kv
Hitec HSB-9370T
www.whf-texas.org
frog racing is offline   Reply With Quote
Old 07-31-2006, 08:33 AM   #8639
bvoltz's Avatar
No, there is a center on-way for the TC4. I know this because a buddy has one, and it works like a dream... It is not so touchy with the brakes. The one-way bearing is located on the spur end of the shaft.
I have two front one-way and do not like them....
Old 07-31-2006, 08:36 AM   #8640
dr_hfuhuhurr's Avatar
Trader Rating: 71 (100%+)
GPM used to make a center one-way for the TC3. If you can find one it would fit the TC4 as well.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
