Like Tree18Likes
Old 06-28-2006, 09:05 AM   #8611
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally Posted by DaveW
Shoe Goo the mounts and servo... just mock mount the servo in its place with the mounts... take the servo out of the car with the mounts attached to the servo and ready to go in place... add a dime sized glob of shoe goo from the underside of the servo between each mount and the side of the servo casing, making sure there is some that will come in contact with the chassis when you add the servo to the car... screw it in place and let it dry till the next day. The idea is the Shoe Goo will harden and not only hold the servo to the chassis, but keep the mounts from wiggling loose in any direction through normal use. Removal, if neccessary, is quite simple... take both screws out of the bottom of the chassis and use a flatblade screwdriver to carefully remove the servo from the chassis. Its ALOT cheaper than an IRS transponder/servo mount.
mmmmm, shoe goo fix all. . ..
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-28-2006, 03:51 PM   #8612
cyclone's Avatar
sorry to ask this cus i bet its on here alot...
could anybody give me spring rates for the 9 standard ft spring set...?
cheers
cyclone is offline   Reply With Quote
Old 06-28-2006, 06:28 PM   #8613
ford_racing's Avatar
Send a message via MSN to ford_racing
cheers
I happen to have one of those sitting right behind me
Colour Lbs. p i
Green 12
Silver 14.5
Blue 17
Gold 19.5
Red 22
Copper 25
Purple 30
Yellow 35
White 40
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-28-2006, 08:44 PM   #8614
DRAG_ON's Avatar
anyone of you guys knows what is the bigest 48 pitch spur gear that can be fitted in FTTC4 before touching the botom chasis. Thanks in advance
DRAG_ON is offline   Reply With Quote
Old 06-28-2006, 08:46 PM   #8615
I believe it is 75 or 76 teeth
ARC R11
Yokomo YRF001
AE B5m
Old 06-28-2006, 08:52 PM   #8616
DRAG_ON's Avatar
thanks for your info mate.....
Old 06-29-2006, 12:56 AM   #8617
cyclone's Avatar
Colour Lbs. p i
Green 12
Silver 14.5
Blue 17
Gold 19.5
Red 22
Copper 25
Purple 30
Yellow 35
White 40
thanks alot mate
Old 06-29-2006, 08:34 AM   #8618
AM03GT's Avatar
actually you can fit a 77.
you have to bevel the underside of the top plate slot just a little, but it does work. i was running 77/33 for awhile but had to yank the spur cause i couldnt fit a 34 pinion in there haha...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 07-03-2006, 08:00 PM   #8619
volracer's Avatar
Send a message via ICQ to volracer
I am running an FT TC$ in a sportsman class, Johnson motor. I need to run a 5:1 ratio, so my spur/pinion gears have to be 2:1. I know this is an extreme ratio. Last weekend, I used a 68/32. My smallest spur and largest pinion, which barely meshed since I could not get the motor closer. Does anyone have suggestionfor 64 and 48 pitch combinations? Thanks.
volracer is offline   Reply With Quote
Old 07-04-2006, 01:49 AM   #8620
Hugh Jazz's Avatar
I had the a similar problem with my team tc4 but my problem was that i counldn't get the motor away from the spur when using the 72t spur. So i used a 48 pitch 65 tooth spur gear and a 33 tooth pinion but i didn't have a problem with the ft tc4. On my ft at the moment i am using a 48p 69/37 to get a ratio of 4.6.
Hope that helps
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 07-04-2006, 06:30 AM   #8621
volracer's Avatar
Thank Hugh,
Iknow it sounds strange running an FT in a class lower than stock, but I need to figure this car out. I run on a smalltrack, tennis court. t just seems stock motors are too much this small track.
Old 07-06-2006, 04:52 PM   #8622
B4Bandit's Avatar
Default Team Drivers in Italy?
Hey all,
I've been in Scotland for the past ten days and haven't been able to keep up to speed with the worlds stuff that much. Can anyone tell me the names of the Associated drivers who are competing so I can follow the team now I'm back in Oz? ________
B4Bandit is offline   Reply With Quote
Old 07-10-2006, 04:00 PM   #8623
Hey Killer Hobbies is doing a blow out sell on the TC4 parts.
http://www.killerhobbies.com/Browse_...Associated_TC4
ChrisR40 is offline   Reply With Quote
Old 07-10-2006, 05:02 PM   #8624
Most of the nice bits option bits are gone, looks like only screws and Associated parts remain
ARC R11
Yokomo YRF001
AE B5m
Old 07-21-2006, 03:04 PM   #8625
vic2367's Avatar
Trader Rating: 14 (94%+)
Send a message via AIM to vic2367 Send a message via Yahoo to vic2367
anyone know of a good set of cvds and shocks for the tc4 ?need some bad....
vic2367 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
