Old 06-02-2006, 01:24 PM   #8536
Graphite Rear Hubs A-9847
Graphite 1/2 Deg Rear Hub A-9852
Graphite 1 Deg Rear Hub A-9853
Not sure whether they're xxx-s or jrx-s off hand, but those are the part numbers anyway. One main advantage of the losi hubs is that you can change the toe in on the outside of the wishbone instead of changing the arm mounts.
ralph_c is offline   Reply With Quote
Old 06-02-2006, 07:11 PM   #8537
dsm
dsm's Avatar
Hey yall,i have a tc4 with a bmi chassis and was thinking of changing the gears to 64 pitch,what size spur gear should i run. Thanks
dsm is offline   Reply With Quote
Old 06-02-2006, 07:46 PM   #8538
I like 96 but also run 100
DOTMAN is offline   Reply With Quote
Old 06-07-2006, 05:15 AM   #8539
DRAG_ON's Avatar
to all tc4 owner, i need help, it's about the rear hub for tc-4 how many type are they? i didn't mean the material, but shape??? I look at the thread and found 2 different kind of hub? One rear hub look like yokomo SD rear hub, the one i have is original carbon made by associated. Are they interchangeable ? thanks in advance
DRAG_ON is offline   Reply With Quote
Old 06-07-2006, 05:50 AM   #8540
S_fender's Avatar
There is only one rear hub for the tc4 made by associated.
The others hubs are losi hubs :
S_fender is offline   Reply With Quote
Old 06-07-2006, 09:28 AM   #8541
DRAG_ON's Avatar
S_Fender: Thanks for your info, as i just back from LHS and buy LOSI rear hub parts no: A-9853, once istalled i foud that the associated MIP CVD too short and won't reach the diff outdrives. I really need information, do i have to changes the LOSI MIP CVD as well. The reason i'm buying rear hub from losi because mine which is made by AE broken and the LHS stock for rear hub are empty and on backorder, therefore i give a shot using Losi rear hub.
Can anyone that use losi hub on their TC-4 help me please, once again thanks in advance.
Old 06-07-2006, 11:12 AM   #8542
S_fender's Avatar
I have tested the same rear hubs and there is no problem with it.
Old 06-07-2006, 05:13 PM   #8543
DaveW's Avatar
You may have gotten the offset Losi hubs that will move the CVD out further from the diff... you need the non offset 0 or 1 degree hubs from Losi. The two are very different in appearance. I added two pics of my car with the standard Losi 0 degree 0 offset rear hubs... hope this helps a bit.
DaveW is offline   Reply With Quote
Old 06-07-2006, 06:28 PM   #8544
stiltskin's Avatar
Trader Rating: 99 (100%+)
Are you STILL running that 3-wheel set-up? I never will understand you.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-07-2006, 07:43 PM   #8545
DRAG_ON's Avatar
DaveW: can you please tell me the losi rear hub parts number, yesterday i bought: LOSA-9854 (0 Deg Graphite Offset RR Hubs:XXX-S)
Old 06-07-2006, 07:47 PM   #8546
ford_racing's Avatar
Send a message via MSN to ford_racing
With the FT TC4 what is the largest size spur you can fit in? also what is the smallest?
Running 48 pitch gears.
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-07-2006, 07:49 PM   #8547
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
The following hubs are the non-offset hubs from Losi.
LOSA9847 0 Degree
LOSA9852 1/2 Degree
LOSA9853 2 Degree
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-07-2006, 10:02 PM   #8548
DRAG_ON's Avatar
Kraig: Thanks for your information, LOSA 9847--0 deg rear hub i think the one i 'm looking for, thanks mate
Old 06-09-2006, 09:09 PM   #8549
DaveW's Avatar
Yep, looks like you got the offset hubs on your car. Kraig hit ya with the correct part #'s. You should hit his website up and check out his deals... he is always on the ball!!
My apologies for such a slow response...
Old 06-09-2006, 09:44 PM   #8550
anthony390's Avatar
Send a message via AIM to anthony390
hey Davew, im just wondering what springs are those (the brand and what lbs)
thanks
anthony390 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
