Like Tree26Likes
Old 05-04-2006, 11:20 AM   #8446
Trader Rating: 17 (100%+)
Originally Posted by dr_hfuhuhurr
Associated's balls are steel
It's really not that big of deal.
arent the silver one made of alu???
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-04-2006, 11:25 AM   #8447
AM03GT's Avatar
all the ball studs are steel... an aluminum ball stud would probably snap every run...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 05-04-2006, 11:31 AM   #8448
sorry i idnt know ball stud are made of steel, i thoght they are made of alu (get the infor from towers)
http://www2.towerhobbies.com/cgi-bin...I=ASCC6276&P=7
Tamiya TB Evo 5
Old 05-04-2006, 11:42 AM   #8449
AM03GT's Avatar
interesting, they have the wrong info...
Old 05-04-2006, 12:17 PM   #8450
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
It's really not that big of deal which ballstuds you use. So long as they work with your setup (long neck vs short) use what you want.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 05-04-2006, 12:56 PM   #8451
AM03GT's Avatar
well yea, but he mentioned he was a noob, so im trying to help him save a few bucks since the performance of Ti ball studs isnt going to be any different than the stock ones he will get with his kit... if he wants to spend a few bucks he'd be better off buying some different sized ones (i.e. neck height and thread length) for tuning...
Old 05-04-2006, 01:14 PM   #8452
am3 how many ballstud it have for the tc4?, could u list them off. thanks again
Tamiya TB Evo 5
Old 05-04-2006, 01:47 PM   #8453
AM03GT's Avatar
4 - 3983 short neck black ball studs .300" (2 for rear hub carrier, 2 for vertical ballstud on steering block)
2 - 3981 short neck black ball stud .200" (servo arm/steering rack arm)
all other ball studs on the car are .300" long neck silver ball studs #6277
(4) - inner camber links
(2) - steering block/steering link
(2) - steering bellcrank
Old 05-04-2006, 03:20 PM   #8454
thanks for the info
Tamiya TB Evo 5
Old 05-04-2006, 03:39 PM   #8455
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Why some racers prefer Schumacher ball cups? Better than RPM ones?
Mike Schumacher is offline   Reply With Quote
Old 05-04-2006, 03:54 PM   #8456
volracer's Avatar
Send a message via ICQ to volracer
I orginally tried to use RPM ball cups, but because they are so long I could not get my camber and toe in right. I even cut some of the length off, but that left very little to hold the threads. I eventually went back to the Associated ball cups, but the ball cups from Lunsford, might work and be stronger.
Has anyone used ball links?
volracer is offline   Reply With Quote
Old 05-04-2006, 04:48 PM   #8457
scottwk1's Avatar
I have the schumacher ones. Definitely stronger than the associated ones. I haven't tried the other brands though.
scottwk1 is offline   Reply With Quote
Old 05-05-2006, 04:22 AM   #8458
Brent Owen's Avatar
I've been using RPM ballcups to help reduce slack the steering links. You have to cut about an 1/8" off the length and clearance around ballcup so they don't rub anything. Cut them down to the same length from ball center to the end of the cup as a stock associated ballcup and you should be ok as far as maintaining the same thread engagment.
Brent Owen is offline   Reply With Quote
Old 05-05-2006, 05:30 AM   #8459
Kevin Boyle's Avatar
Have you guys tried the AE B4/T4 ballcups? I have had no problems with the stock ones but, I have a friend that replaced his from the start and has had no problems. There again you would have to trim them down so they do not rub.
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 05-05-2006, 08:22 AM   #8460
RC Professor's Avatar
Can anyone tell me the internal ratio of the TC4, specifically the Factory Team version?
RC Professor is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
