Like Tree18Likes
Old 05-03-2006, 01:43 AM   #8416
Trader Rating: 17 (100%+)
Originally Posted by DaveW
The graphite servo mounts from the FT will fit the tub chassis IF you either cut off the centering tabs of the servo mounts OR drill the holes in the tub chassis for them to fit in. The shock towers (F/R) with the mounts will fit, and so will the top plate, with a slight bit of modification/spacing.
Dave could you post the whole car picture??? thanks
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-03-2006, 10:05 AM   #8417
Send a message via Yahoo to apexraceway
Originally Posted by khyron
Is anyone using MaxAmps lipo packs in their TC4 (with the tub chassis, not the FT or other graphite ones)? I'm looking for some feedback on fitment, what I'm hoping is that the larger 6000/8000mah packs fit okay. Any reccomendations on strap solutions for thicker packs welcome as well!
A good friend of mine uses a Maxamps 8K LiPo battery in his TC3 with great sucess. The battery is a little taller...but isnt a problem and is about the same weight as a GP3700. With 7.4V and a Team Checkpoint 12T double...that thing is sick!!!
Jeff
apexraceway is offline   Reply With Quote
Old 05-03-2006, 12:15 PM   #8418
khyron's Avatar
Send a message via AIM to khyron
Thank so much! That's precisely the kind of input I was looking for, and the weight and size are exactly why I'm interested in the 6000mah or 8000mah packs from MaxAmps (each on par or lighter than traditional cells, and, while taller, not wider or longer).
khyron is offline   Reply With Quote
Old 05-03-2006, 01:26 PM   #8419
Hi is the ft blue screw good or should i get stainless steel screw? thanks
Tamiya TB Evo 5
Old 05-03-2006, 01:51 PM   #8420
bummy's Avatar
Send a message via MSN to bummy
from previous experience, i seem to find the factory blue screw better. reason being i have a had a couple of stainless ones stip. then it makes it near in possble to get out. only the allen drive bit strips.
bummy is offline   Reply With Quote
Old 05-03-2006, 02:17 PM   #8421
AM03GT's Avatar
FT screws are good.
good price, cool blue color, lightweight
just be careful when using them, if you don't rush it, they don't strip and last a long time... i'm still on my original set of screws since the FT TC4 came out...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 05-03-2006, 03:37 PM   #8422
SweetRacing's Avatar
Trader Rating: 18 (100%+)
Looking for a little help on a pucs problems I am having with my TC4 on a dirt oval, high bite track.
I can drive hard inot the corner but about halfway through the corner and on acceleration, the car wants to climb the track.
I have tried changing springs, (currently silvers all around, except the right front I have a blue spring. 40wt oil all around as well.
Battery in the back.
Right side tires are -1 camber, left sides are at 0.....
I think that is everything?????
Any help would be appreciated.....
SweetRacing is offline   Reply With Quote
Old 05-03-2006, 04:49 PM   #8423
bukil's Avatar
Trader Rating: 37 (100%+)
Originally Posted by bukil
Has any of you guys use Tamiya shocks on your TC4? If so, how are they? Are they any better than the FT TC4 ones with the shock upgrade?
Thanks in advance,
Mark
Disregard the above post. The "Search" button lend me a hand or should I say a click?
bukil is offline   Reply With Quote
Old 05-03-2006, 04:59 PM   #8424
Great i am going to order one, do you guys know what the diffrence between tc3ft screw and tc4ft screw are they the same??? other than number of screw. thanks
Tamiya TB Evo 5
Old 05-03-2006, 06:22 PM   #8425
Super Moderator
Grizzbob's Avatar
So if I understand your situation right, you say you're turning in ok going into the corners but pushing coming out of them? If that's true then you might see what caster blocks are on your car now, when you have less caster, it'll tend to steer the way you describe(more steering into the corner, but less coming out), & with more caster, it'll have less steering going in & more coming out(plus it'll be more stable on a straight). Check & see which blocks you have on it now, & then try adding some caster to see what happens(so if you have the 2 degree blocks, try the 4 degree ones, & if they're already 4's, try the 6's).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-03-2006, 06:35 PM   #8426
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
i use the set from rcsrewz and i think its really good
imo
i_got_m8_4_$85 is offline   Reply With Quote
Old 05-03-2006, 08:05 PM   #8427
edracer1's Avatar
Originally Posted by dtam
Hi I'm a novice doing parking lot club races and want a critque of my TC4 tub setup...
Well that's a lot to address, but I'll give you my 2-cents,
Try the gold springs up front and silver springs in the rear. I use 35wt oil front and rear until it gets really hot outside then 50wt. For 19-turn I would use a 28 tooth at most, (but note the manual says 30 tooth, which seems way too much, try at your own risk). I have the same servo as you but run the Futaba S9451's in my nitro, they are much faster and my reactions seem to be faster also.
Oh yea, make sure you "end points" and "dual rate" on your radio are set out far enough, That is when you turn your steering the tires turn "out far" enough and both have the "same" turning distance for each side.
edracer1 is offline   Reply With Quote
Old 05-03-2006, 10:03 PM   #8428
also anyone know whats the part number for rpm ball end?
Tamiya TB Evo 5
Old 05-03-2006, 10:03 PM   #8429
forgot to add ball stud, what brand do you guys use?
Tamiya TB Evo 5
Old 05-04-2006, 04:29 AM   #8430
khyron's Avatar
73375 RPM Heavy Duty Rod Ends Yellow 4-40 (blue)
73378 RPM Heavy Duty Rod Ends Yellow 4-40 (purple)
73377 RPM Heavy Duty Rod Ends Yellow 4-40 (yellow)
73372 RPM Heavy Duty Rod Ends Yellow 4-40 (black)
Each package contains 12 ball ends, and RPM offers shock shaft bottoms and shock spring cups too - although I'm pretty sure those are just for matching looks and are not actually "beefier" than stock as the ball ends are, someone correct me on that?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
