Old 04-30-2006, 03:11 AM   #8401
Originally Posted by RH Customs
"Apex" The only dealer that has the Delrin Outdrives that I know of in the states is Speed Tech RC. Check this link out, http://www.speedtechrc.com/store/ebp...id=339&id=1033 , this is the link fo the black delrin outdrives. I hope this helps. Oh an also check out the aftermarket section, there are alot of other cool hard to find that stuff that usually has to be ordered from overseas.
RH
They're the outdrives I was talking about . I thought you'd be able to get them in the US. I only use them up front and havent had any problems with the back plastic outdrives even running 19t a couple of times (I expect they would wear quickly though using hotter motors often).
ralph_c is offline   Reply With Quote
Old 04-30-2006, 08:24 PM   #8402
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
I've seen people using the schumacher ball cups on their TC4's. Anyone know which part number those are so I can order some?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-30-2006, 09:07 PM   #8403
dtam's Avatar
Hi I'm a novice doing parking lot club races and want a critque of my TC4 tub setup. It's based on a mishmash from the rc10.com setups and mines. I think my problem is my turning radius is wide, steering is slow, fishtail a little and I need faster top end speed in the straight. I may try out 2 setups I found earlier in this thread with one guy from japan. When I built it I cleaned off all the flashing, nothing was binding and everything was free rolling smooth.
Do I really need a faster servo? What's the safest highest gearing for a P2K Pro with the stock 72T spur? People told me I should not use stick packs and buy 3800/4200 batts and a Monster or Colbalt motor. What gearing are good for those? Also where do you buy RP 30 tires?
I only have a MRC 969 charger that can only charge up to 4.5Amps. I like to get more serious with racing and I plan to buy an ICE charger, Novak equilzer tray with a radioshack powersupply.
I want to try the Spektrum telemetry lap counter so I can track my changes as I still have no clue what I'm doing mostly.
dtam is offline   Reply With Quote
Old 05-01-2006, 12:20 AM   #8404
Trader Rating: 17 (100%+)
Originally Posted by EngTat
Can anyone tell me that is the tc3 input shaft compatible with tc? i found the irs alu shaft but that for tc3
anyone?
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 05-01-2006, 12:36 AM   #8405
gacjr0's Avatar
Trader Rating: 15 (100%+)
anyone?
yes it is
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 05-01-2006, 12:49 AM   #8406
gacjr0's Avatar
dtam:
I would try going a spring softer and 10wt lighter oil all the way around;
maybe try a one way;
that servo is fine for stock
the manual has good starting points for gearing, go up/down teeth based on your speed, heat, runtime (well, this shouldnt be so true anymore)
At this point, it may be best to grab a good set up from somebody and practice and race with that for a while to concentrate on driving and learning what the car can do before getting too deep into tuning.
Old 05-01-2006, 02:35 AM   #8407
hmm anyone upgrade the input shaft? is yes what brand u guys usually use? thanks
Tamiya TB Evo 5
Old 05-01-2006, 07:01 AM   #8408
I tried the IRS input shafts on my TC3 years ago and didn't like it. They never stayed true for very long for some reason. I love IRS stuff for the most part but I never cared for the input shafts.
I thought TiR made some titanium ones but I haven't been able to find them anywhere.
Blake
Old 05-01-2006, 08:10 AM   #8409
scottwk1's Avatar
The Schumacher ball cups are U1704.
scottwk1 is offline   Reply With Quote
Old 05-01-2006, 08:49 AM   #8410
Blake
thanks, i might do some research for other brand
Tamiya TB Evo 5
Old 05-01-2006, 09:53 AM   #8411
khyron's Avatar
Send a message via AIM to khyron
Default anyone using Maxamps lipo packs in a tub TC4?
Is anyone using MaxAmps lipo packs in their TC4 (with the tub chassis, not the FT or other graphite ones)? I'm looking for some feedback on fitment, what I'm hoping is that the larger 6000/8000mah packs fit okay. Any reccomendations on strap solutions for thicker packs welcome as well!
khyron is offline   Reply With Quote
Old 05-01-2006, 11:50 AM   #8412
tallyrc's Avatar
dtam, start with 40 oil all around, and silver springs all around. also make sure you have good ride height, like 5.5mm front and rear.. stick with the diff for now, later go to a spool in the front, or lock the diff depnding on traction...
tallyrc is offline   Reply With Quote
Old 05-01-2006, 10:39 PM   #8413
bukil's Avatar
Trader Rating: 37 (100%+)
Has any of you guys use Tamiya shocks on your TC4? If so, how are they? Are they any better than the FT TC4 ones with the shock upgrade?
Thanks in advance,
Mark
bukil is offline   Reply With Quote
Old 05-03-2006, 12:42 AM   #8414
Default FT TC4 ITF CHASSIS
Has anyone tried the whole ITF chassis kit on the car on tarmac with rubber tyres?
Most people with an FT at our track found out that removing the spine plate made the standard car much better anyway
Over here (england) everyone has just bought the ITF top deck as the chassis does not look any different than the stock one, and nobody is running the spine plate anyway.
What's your thoughts, is it worth getting the whole kit?
mark240973 is offline   Reply With Quote
Old 05-03-2006, 02:06 AM   #8415
S_fender's Avatar
Yes i've try the whole ITF chassis and love it.
The ITF chassis does not look different but it flex more than the standard chassis.
The chassis stiffeness depends of the grip:
On a low grip asphalt i like the ITF chassis and top deck without spine plate.
On highest grip track i put the ITF spine plate and the car become more precise, sometimes i put the standard top deck with the ITF chassis and ITF spine plate.
S_fender is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
