Like Tree36Likes
Old 04-14-2006, 04:49 PM   #8311
Trader Rating: 17 (100%+)
sorry i mean all the range of oivot ball or only certain of them, BTW i dont have tc4 rite now accept for the cabon chassis set...planning to built it soon.
engtat
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 04-14-2006, 05:17 PM   #8312
DaveW's Avatar
You can use both the short neck black ballstuds, and the long neck silver studs, both are for the tub car and the FT... incidentally they also work very well on the AE offroad cars. The TC4 studs screw in with the 5/64ths driver now, not a nut driver as with the older TC3 ballstuds. You can/will use both types (black/silver) to tune your TC4... so you cant go wrong in getting both colors, and in varying lengths of thread.
DaveW is offline   Reply With Quote
Old 04-14-2006, 07:00 PM   #8313
Super Moderator
Grizzbob's Avatar
Originally Posted by DaveW
Ya beat me to it Ralph... BTW... the top plate on the car will fit with the (4) stock chassis braces... its tight... but it will fit. The only thing... swapping motors IS a bear.
Assuming you're talking about the FT car, there is a way around the motor thing, just cut a couple of slots in the motor plate(much like they are in the HPI Hara Edition Pro4), makes it SO much easier to change motors out, just loosen the screws a bit & it'll slide right out. I did it to my motor plate about a month after I bought my car(bought it in September), & it's worked beautifully....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-14-2006, 07:20 PM   #8314
ThyeSan is offline   Reply With Quote
Old 04-14-2006, 07:24 PM   #8315
Dave can give me the part number
Tamiya TB Evo 5
Old 04-15-2006, 12:56 AM   #8316
I found short neck black ballstuds at the back camber link with no washers helped the car get into the corners better (higher roll center). Might help someone else I guess.
ralph_c is offline   Reply With Quote
Old 04-15-2006, 08:33 PM   #8317
RCMits's Avatar
Trader Rating: 25 (100%+)
i use the short black studs in the rear with 1~2 washers depending on grip.
small question TC4 folks...
If I use a one-way in front, should i use steel outdrives or plastic outdrive in the FRONT with alum or carbon cvd's ?
If I use a one-way in front, should i use steel outdrives or plastic outdrives in the REAR with alum or carbon CVD's?
I was thinking,
front one way with steel outdrives and alum cvd's and rear with plastic outdrives and carbon outdrives to carry the speed? Hope I am thinking right here.
Thanks!!
RCMits is offline   Reply With Quote
Old 04-15-2006, 10:47 PM   #8318
bubbles's Avatar
I was thinking,
Thanks!!
I don't think there's a One-Way with anything BUT steel outdrives... And yeah, run aluminium TC4 bones up front. They're REALLY strong(what, 40% thicker than TC3 aluminium CVD's?). I've never been able to make carbon bones up front work. I end up snaping the bone and lose the outdrive. NOT GOOD! Hahaha.
For the rear, plastic outdrives will do find for months in stock. If you run carbon bones, then they'll shave some weight and lessen rotating mass. Plus, they're cheaper. =]
bubbles is offline   Reply With Quote
Old 04-16-2006, 12:10 AM   #8319
ford_racing's Avatar
Send a message via MSN to ford_racing
are you able to post a pic? this mod actually sounds like something worthwhile
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 04-16-2006, 09:52 AM   #8320
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can someone help me out... can you post either a picture or the instuctions to mount the Associated Motor Cooling Duct/Fan Kit. I have a kit, but I'm not sure how it is installed in the car.
bvoltz is offline   Reply With Quote
Old 04-16-2006, 10:37 AM   #8321
bhambrent's Avatar
Heres the hpi motor mount.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 04-16-2006, 01:21 PM   #8322
can tc4 use pro4 cvd set? fit?
thanks!
gtimax is offline   Reply With Quote
Old 04-16-2006, 02:00 PM   #8323
anthony390's Avatar
Send a message via AIM to anthony390
thanks!
i believe so
i also know that the pro4 uses the tc4 cvds so why cant the tc4 use pro4
anthony390 is offline   Reply With Quote
Old 04-16-2006, 10:49 PM   #8324
Castradamus's Avatar
Trader Rating: 53 (100%+)
Anybody that is interested in buying a FT TC4. I am selling mine
Here's the thread!
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 04-17-2006, 08:34 AM   #8325
AM03GT's Avatar
Front always use aluminum TC4 bone...
you can get away with plastic outdrives for stock and maybe19t if you drive clean...
one way only has steel outdrives...
for the rear same deal... plastic outdrives for stock/19t,... steel for mod...
this is almost a preference thing... the plastic saves weight, but the weight of the steel gives the car a different feel into corners...
you can get away with the composite cvd bones in the rear, even in mod... but they do flex just a bit, i use them at times, and sometimes the TC3 thin bones...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
