Like Tree26Likes
Old 04-12-2006, 12:46 PM   #8296
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
what does adding caster do to your car?
i_got_m8_4_$85 is offline   Reply With Quote
Old 04-12-2006, 07:07 PM   #8297
anybody????????
Old 04-12-2006, 07:14 PM   #8298
ford_racing's Avatar
Send a message via MSN to ford_racing
EFFECTS OF CASTER ADJUSTMENT
Less caster angle (more vertical)
Decreased straight-line stability.
Increased off-power steering at corner entry.
Increased suspension efficiency.
Decreased on-power steering at mid-corner and corner exit.
More caster angle (more inclined)
Increases straight-line stability.
Decreased off-power steering at corner entry.
Increased on-power steering at mid-corner and corner exit.
Makes the car more stable through bumpy track conditions.
from the hudy setup book
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 04-12-2006, 07:44 PM   #8299
thanks
Old 04-13-2006, 11:36 PM   #8300
Trader Rating: 17 (100%+)
hi everyone, can anyone tell me that which part is interchangeble from tc4 FT with the tc team kit which is tub chasis. for example can the alu pivot block of FT be use at the tub chasis. thanks.
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 04-14-2006, 06:12 AM   #8301
RH Customs's Avatar
Send a message via AIM to RH Customs Send a message via Yahoo to RH Customs
I know that that in addition to the aluminum pivot blocks, the graphite servo mounts, lightened steel out drives, I think that is all of the hop ups you can put on the Team kit from the FT Kit. I'm running the aluminum pivot blocks as well as the steel diffs, looks sweet, and performs a little more consistent.
RH
RH Customs is offline   Reply With Quote
Old 04-14-2006, 07:04 AM   #8302
DaveW's Avatar
RH
The graphite servo mounts from the FT will fit the tub chassis IF you either cut off the centering tabs of the servo mounts OR drill the holes in the tub chassis for them to fit in. The shock towers (F/R) with the mounts will fit, and so will the top plate, with a slight bit of modification/spacing.
Team Associated TC4-hybrid-1.jpg   Team Associated TC4-hybrid-3.jpg   Team Associated TC4-hybrid-4.jpg
DaveW is offline   Reply With Quote
Old 04-14-2006, 07:59 AM   #8303
Dave nice car, cant post the whole picture of the car? thanks
Tamiya TB Evo 5
Old 04-14-2006, 08:08 AM   #8304
Super Moderator
Are there any advantages or disadvantages in using the BMI TC4 conversion kit?
RH
The BMI Kit was designed to replace the Tub car, not the FT car. Comparing it to the FT car you will notice a few very large differences. My old TC4 was full BMI, even had the motor mount which does have the bearing support for the center shaft. What I can tell you about the car is that ALL the weight was shifted forward. Yes All. The motor, servo and battery slots are all further forward. The steering rack is so much further forward that you really can't run washers under the ballstuds. What this does is give you a car that is super aggresive. This can be good and bad. If you are a new driver then you will have your hands full. If you are a pretty good wheel, then you will find the car to be very fast. I loved my car because you were always in the the ball park for setup no matter where you went. Oh and if you don't have the motor mount you will blow through spurs if your center shaft bearings are worn, so watch for that.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-14-2006, 08:19 AM   #8305
Super Moderator
Here was my setup for med bite carpet.
Front
70 wt losi oil
2 piston
purple springs
inside on arm
2nd hole out on tower (laid down)
camber - 2nd hole out silver ball stud no washers
4 deg castor
5mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
Losi XXXS Zero deg hubs inside on hub no washers
no washers under blocks
5 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
BMI Chassis/top deck/ motor mount
Team Express C2 (19T) geared 35-104
Team Express IB3800's
Parma Alfa
Old 04-14-2006, 09:49 AM   #8306
http://www.rctech.net/forum/attachme...hmentid=106761
Found it on page 247 hehe
ralph_c is offline   Reply With Quote
Old 04-14-2006, 10:11 AM   #8307
DaveW's Avatar
Ya beat me to it Ralph... BTW... the top plate on the car will fit with the (4) stock chassis braces... its tight... but it will fit. The only thing... swapping motors IS a bear.
Old 04-14-2006, 11:43 AM   #8308
scottwk1's Avatar
What kind of ball cups is Davew using on his TC4? Sorry in advance if this has already been asked.
scottwk1 is offline   Reply With Quote
Old 04-14-2006, 12:00 PM   #8309
S_fender's Avatar
Schumacher ball cups
S_fender is offline   Reply With Quote
Old 04-14-2006, 04:46 PM   #8310
Originally Posted by ralph_c
thanks ralph. the aluminium pivot ball of FT can be used in tc tub chasis rite?
engtat
Tamiya TB Evo 5
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
