Like Tree59Likes
Old 04-05-2006, 09:56 AM   #8281
RH Customs's Avatar
Send a message via AIM to RH Customs Send a message via Yahoo to RH Customs
Another quick question, as far as spools go which is the best one or are they all the same? ( IRS, AE, ect)
RH
RH Customs is offline   Reply With Quote
Old 04-05-2006, 09:59 AM   #8282
AM03GT's Avatar
RH
they are a little different in their own right. they all function similar... aftermarket companie have aluminum ones that are lighter, but require the use of cvd bone pin cushions to keep outdrive wear low...
the AE steel spool, oneway, and steel diffs are all very durable...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 04-05-2006, 10:03 AM   #8283
RH Customs's Avatar
Ok, was not sure. I think I will get an AE spool just to keep everything matching.
RH
Old 04-05-2006, 10:46 AM   #8284
gone_wheelin's Avatar
I've got the thin black strapping tape too. I believe it is either Wolf or Racers Choice brand but not 100% on that since I got rind of the packaging after I got the tape. It has the fibers in it as well. I have only had a couple of problems with it tearing and it was a combination of not filing down the edges of the battery slots and impacting a board at the end of a straight in my oval car; broke a solder joint too. Since filing and gluing the edges I haven't had a problem.
Redwood Empire Ground Pounders ~ Team CFX ~ Jakes Performance Hobbies
gone_wheelin is offline   Reply With Quote
Old 04-06-2006, 08:49 AM   #8285
RH Customs's Avatar
Are there any advantages or disadvantages in using the BMI TC4 conversion kit?
RH
Old 04-07-2006, 09:40 AM   #8286
I like the BMI kit alot. The chassis plate and top plate are 3mm instead of 2.5 like the FT kit. Just like the FT kit you can dial in/out chassis stiffness by adding/removing stand-offs. Lots of attention was put into the design if the BMI chassis with input from the racer. The battery slots are beveled, there is a channel under the batter slots so that if you use tape, it will recess up instead of below the chassis. There are chassis balance holes milled into the chassis front/back & left/right so you can balance it using the Hudy balance tools.
The only disadvantage I see it having when compared to the FT kit (and it is a very minor one) is that you can not use the FT motor mount, you have to use the team kit mount. Not really that big of an issue though.
I got the kit at the end the outdoor season here so I have not had a chance to run it yet but I am very anxious to get it on the asphalt. The last two scheduled races were rained out.
But as with most things, you can ask 20 different people and half will say they love the FT kit more and half will say they love the BMI kit more.
Old 04-07-2006, 10:04 AM   #8287
RH Customs's Avatar
Cool
I was wondering, does anybody make a red or gun metal aluminum screw kit for the TC4?
RH
Old 04-07-2006, 11:54 AM   #8288
I like the idea of the recessed channel under battery slots. I've got the FT at the moment and it's fine. It probably doesn't matter which one you get.
There are two things I'd add about the BMI kit. I think they still come with a motor mount seperate to the spur/prop shaft bearing holder. Some people had problems with stripping spurs with hot motors as the motor mount can move a little away from the spur when the chassis flexes. BMI do offer a revised motor mount/spur gear holder which is fine. It probably wouldn't be a problem anyway unless you run modified (I havent got the kit so I'm only passing on other information).
Also, another difference between the kits is the BMI chassis sits the cells further forwards. This means you should get more aggressive steering. You can probably set-up either chassis to work for you anyway.
I don't know how many people have had the chance to try both kits, but I think you could get on well with either. Take your pick really
ralph_c is offline   Reply With Quote
Old 04-07-2006, 11:55 AM   #8289
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
RH
You can get some red screws here.
http://www.fastener-express.com/inde...S&Category=218
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-10-2006, 01:49 PM   #8290
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
how many people still run the tub chassis for the tc4, wether carbon or plastic, i was just wonderin.
i_got_m8_4_$85 is offline   Reply With Quote
Old 04-10-2006, 03:33 PM   #8291
TMHippo's Avatar
My boy's and myself all run the Tub chassis still, mainly because the LiPo's that I just bought are more secure then if I would use tape in the FT
rodney
TMHippo is offline   Reply With Quote
Old 04-10-2006, 07:42 PM   #8292
RH Customs's Avatar
I still run the tub in graphite. Runs great for me.
RH
Old 04-11-2006, 09:42 AM   #8293
I have a friend who beats nearly everybody with his tub car...he has spent hundreds of pounds on it though . He's using the carbon tub. It is still an ok car.
Old 04-11-2006, 11:04 AM   #8294
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
I still use a tub chassis on my TC3 or TC4 for asphalt racing. I like the flex that it provides. I also have a TC4 tub chassis that is custom made (true factory team), that is two to three times stiffer than the FTTC4 carbon chassis & top deck set up.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 04-11-2006, 11:27 AM   #8295
BMI made a while ago an upper deck for the TC4. That made it INSANE stiff.
Blake
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
