Like Tree43Likes
Old 03-29-2006, 06:09 PM   #8251
DaveW's Avatar
Even the o-rings will cause restriction with suspension arm movement. Take your shocks off of the arm, make sure the o-rings are installed, and move the arm up and down... the o-rings will act as a bushing and restrict the free up and down movement. You will see them pinch between the ballcup and the neck of the ballstud as you move the arm up and down. Take them off and do the same test and the restriction will be gone. What will happen is as the suspension is compressed through a corner (bound), the o-rings will resist compression, but the other side will fight against the spring (rebound) as the o-rings will limit downtravel. The car will feel as if it has less overall traction, and on a high bite surface, it can be very responsive and twitchy to drive. We used to pack the ballcups with AE black grease to damp the chatter caused by a sloppy front end, it worked well but was high maintenance. The rubber bands do the trick with little suspension restriction, and maintenance.
DaveW is offline   Reply With Quote
Old 03-29-2006, 07:17 PM   #8252
Send a message via AIM to ZER01
No restriction here using them with the new silver broached ball studs and AE ball cups-other cups I don't know. I have free movement on all four arms including steering. You only use so much travel in the arm where if there is any restriction, it's not in the travel you're using ie; 5-7mm ride height.
ZER01 is offline   Reply With Quote
Old 03-29-2006, 08:16 PM   #8253
bvoltz's Avatar
Trader Rating: 44 (100%+)
Does anyone know the part number to the Ball Studs that will allow for the o-rings to be used?
bvoltz is offline   Reply With Quote
Old 03-29-2006, 08:33 PM   #8254
Old 03-29-2006, 08:41 PM   #8255
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
You're also changing your suspension geometry by raising the ball height by using a longer neck ball stud.
something to consider before making changes.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-29-2006, 09:24 PM   #8256
AM03GT's Avatar
6277 broached silver ball stud is the stock ball stud...
i suppose used on the steering rack its going to change the ackerman a bit due to its added length... but you can probably equalize it using the inside hole onthe steering block...
personally i just give the rack a little tlc and it works fine with a small amount of slop...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 03-30-2006, 10:02 AM   #8257
on all parts minus the rear hubs and front spindles.
I like my rack tight with normal movement and no play. Hell, I just like racks!
Old 03-30-2006, 10:18 AM   #8258
Originally Posted by wyd
The slop in the steering rack isn't a huge issue as long as your rack works smoothly and your car tracks straight. Like AMO3GT mentioned you do need a little slop. If you take all the slop out of a car it will never track straight. Found this out years ago when racing dirt oval. I was really proud of mysleft for shimming all the slop out of my car only to find out that it would never track straight. Actually took a few shims out of the car to get some slop back and the car tracked perfectly.
With play in the ballcup/ballstud that would create toe-in or toe-out depending on whichever you have set at 0 degrees. If there's perfect 0 toe-in, 0 toe-out how can it not track straight(assuming we have a perfectly balanced chassis)?
Old 03-30-2006, 10:31 AM   #8259
AM03GT's Avatar
exactly what you just said...
assuming you can have perfect 0 toe in/out...
you'd need camber 101% equal left and right, ride height 100% equal all 4 corners, weight balance perfect left and right...
the real world says that this is basically impossible... and if you somehow got your car to be this perfect, all it would take would be a slight tap of a dot or board to get it out of perfect... an acceptable amount of play in all the components ensures that everything moves freely, and that the car has a small buffer for imperfections such as weight balance or setting differences +/-... under load everything basically "locks" into place anyway...
Old 03-30-2006, 01:44 PM   #8260
RaceAce701's Avatar
Trader Rating: 84 (99%+)
post removed due to spam
RaceAce701 is offline   Reply With Quote
Old 03-30-2006, 05:44 PM   #8261
Just getting back into on-road after a break and some offroad. What is the current hot-body for rubber tire asphalt racing?
Old 03-30-2006, 05:53 PM   #8262
bhambrent's Avatar
Thumbs up
For asphalt racing.
Protoform Dodge Stratus 3.0 all-purpoes body #1476-01,And takeoff cs-27
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 03-30-2006, 05:53 PM   #8263
Send a message via AIM to mush104
i think the best body is the mazda 6.
mush104 is offline   Reply With Quote
Old 03-30-2006, 07:57 PM   #8264
bummy's Avatar
Send a message via MSN to bummy
hey, guys iam looking to find, a rought guide for roll out for each turn motor, just like a general starting mark, if ya can help me that be good.
bummy is offline   Reply With Quote
Old 04-03-2006, 12:58 PM   #8265
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
does anybody have the ft tc4 conversion? if so how do you like it?
i_got_m8_4_$85 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
