Like Tree36Likes
Old 02-25-2006, 07:41 AM   #8011
i_got_m8_4_$85's Avatar
Send a message via AIM to i_got_m8_4_$85
wats a realy good stock motor?? thanks
i_got_m8_4_$85 is offline   Reply With Quote
Old 02-25-2006, 07:54 AM   #8012
i hear people say the epics are really good but witch one the binary 2 outlaw or the roar stock one ?? thanks
sorry for double posting
Old 02-25-2006, 08:15 AM   #8013
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
I love the new CO27 motor. Once you get the gearing right, replace the brushes and springs, it is insane!
XMSRacing is offline   Reply With Quote
Old 02-25-2006, 09:58 AM   #8014
ok thanks -still open for other sugestions
Old 02-25-2006, 10:00 AM   #8015
Super Moderator
Grizzbob's Avatar
Trinity does, just like the Epic Binary 2 & ROAR stock.
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 02-25-2006, 02:21 PM   #8016
bummy's Avatar
Send a message via MSN to bummy
what setting is your front ball diff on? asuming your using it? it might be to tight. you ever tried to drive a front wheel drive with bascially a locked front diff. it will never turn it. try and loosen it up, it helped mine turn in better, cheers.
bummy is offline   Reply With Quote
Old 02-25-2006, 02:42 PM   #8017
bukil's Avatar
Trader Rating: 39 (100%+)
I dont know if that was addressed to me but I'm going to answer anyway.
I am using one-way. I also tried the differential but I get the same results - wide turns.
Thanks,
Mark
bukil is offline   Reply With Quote
Old 02-25-2006, 05:27 PM   #8018
Default Just a thought...
bukil - How tight is your rear diff? I know when I tighten my rear diff up it does not like to turn in as well. I usually run mine about an 1/8th turn tighter than kit suggested.
Just something to think about.
RobertM is offline   Reply With Quote
Old 02-25-2006, 06:12 PM   #8019
bummy's Avatar
yeah sorry it was address to you, try different settins on your front and rear diff. normaly, if rear is to tight it will just drift. but front will tend to understeer if it to tight cheers. give it ago, just adjust your ball diff.s
Old 02-25-2006, 09:48 PM   #8020
bukil's Avatar
I have already ruled that out. I have mine on what the manual suggested. I also tried making it loose and tighter than what is in the manual. No luck. Anymore ideas guys?
Thank you for all the people who replied.
Thanks,
Mark
Old 02-25-2006, 10:43 PM   #8021
yeah try a new car and anything new the that pile
tc4isthebest is offline   Reply With Quote
Old 03-01-2006, 05:54 AM   #8022
DaveW's Avatar
Man that sure is a positive post.
I had a decent day of practice with my FT Sunday. I did quite a bit of changes, and found over half a second per lap. Irritatingly enough i found alot of consistency in the car by adding rubber bands to the steering rack/assembly in three places to tighten it up. The car felt alot better and really responded to suspension changes after that. It no longer felt numb. The rubber band trick isnt new by any means, its as old as R/C cars are, and has been used in off and onroad applications. I experimented with shock o-rings on the ballstuds, but they were too thick and restricted suspension action. The rubber bands did the trick. I got a few giggles and laughs at the track, but the lap times called were a far improvement from before, its getting better the more i work on it.
DaveW is offline   Reply With Quote
Old 03-01-2006, 06:17 AM   #8023
bhambrent's Avatar
Will you post some pic's? I would like to see this.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 03-01-2006, 06:18 AM   #8024
Default Rubber Band trick?
DaveW - What exactly is this rubber band trick? How did you implement it onto the car? Can you put some pictures on here of this trick? Sorry for the question, but I would like to know what it is and how its done. Thanks
Old 03-01-2006, 06:34 AM   #8025
DaveW's Avatar
Sure guys no problem gimme a bit to finish the other ballcups and check to see if the cam has good cells in it. I will leave the top deck off so it is easier to see everything.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
