Like Tree6Likes
Old 02-23-2006, 12:23 AM   #7996
S_fender's Avatar
Originally Posted by bukil
Sorry I meant to say: Refer to my previous post.
Front
Toe= 0
Caster=4
Rear
Toe= -2.5
Caster= 0
You have 100% on left and right turning on the radio but on the tracks ? The car turn in the same way on left and right ?
Personnally i'have 80% left and 100% right on the radio.
S_fender is offline   Reply With Quote
Old 02-23-2006, 06:27 AM   #7997
scottw's Avatar
I can't seem to get rid of my wide turn in my FT TC4. Anyone know how to fix this? Here are my specs:
Radio: M8 w/ Spektrum Module and reciever - D/R set at 85%; 100% on left and right turning.
Servo: Airtronics 94758z
Setup:
Front
Caster= 0
Camber= -1
Droop= 5
Springs= AE silver
Shocks Oil= 50wt.
Outer hole of the A-arm
Outer hole of the shock tower
Inner hole of where the camber linkages go
Rear
Caster= -2.5
Camber= -1.5
Droop= 4
Springs= AE silver
Shocks Oil= 40wt.
Outer hole of the arm
Second to the outer hole of the shock tower
Inner hole where the camber linkages go
Thanks,
Mark
that too is why I sold mine for the new xray t2. The TC4 would push no matter what I did to it. I got tired of fooling with it after I won the series with it. Just too damn much work just to try to go through corners. Best of luck with her.
scott
scottw is offline   Reply With Quote
Old 02-23-2006, 06:34 AM   #7998
Trader Rating: 21 (100%+)
Rubber or Foam? Carpet or Asphalt?
Setup:
Front
Caster= 0
Camber= -1
Droop= 5
Springs= AE silver
Shocks Oil= 50wt.
Rear
Caster= -2.5
Camber= -1.5
Droop= 4
Springs= AE silver
Shocks Oil= 40wt.
Thanks,
Mark
lotus1 is offline   Reply With Quote
Old 02-23-2006, 08:44 AM   #7999
AM03GT's Avatar
Originally Posted by roadrashracing
Hi I am looking for a base setup for a tc4 for rubber on carpet for my SRD thanks.
i don't think you're going to get much help here on an SRD, from what ive seen of it on a web picture or two, its got wider hinge pin locations, shorter suspension arms, short upper links... most likely the weight distribution is slightly different too due to mounting locations and such... with this much of a difference in the cars the setups will not translate over exactly...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 02-23-2006, 08:44 AM   #8000
AM03GT's Avatar
Old 02-23-2006, 08:48 AM   #8001
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
ok thanks!
Owning a lot of RC vehicles doesn't always mean a lot of knowledge.
roadrashracing is offline   Reply With Quote
Old 02-23-2006, 11:19 AM   #8002
bukil's Avatar
Trader Rating: 37 (100%+)
Rubber on asphalt.
Thanks,
Mark
bukil is offline   Reply With Quote
Old 02-23-2006, 08:47 PM   #8003
bukil's Avatar
Rubber on asphalt. Anyone know how to fix this (refer to my previous posts)?
Thanks,
Mark
Old 02-23-2006, 09:32 PM   #8004
Super Moderator
Trader Rating: 17 (100%+)
Front
70 wt losi oil
2 piston
purple springs
inside on arm
2nd hole out on tower (laid down)
camber - 2nd hole out silver ball stud no washers
4 deg castor
5mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
Losi XXXS Zero deg hubs inside on hub no washers
no washers under blocks
5 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
BMI Chassis/top deck/ motor mount
Team Express C2 (19T) geared 35-104
Team Express IB3800's
Parma Alfa
Tekno | BLOK | JConcepts | RRP | BOOM RC
Bob Barry is offline   Reply With Quote
Old 02-23-2006, 10:46 PM   #8005
bummy's Avatar
Send a message via MSN to bummy
MY NEW BODY NOT BEST, but good considering it my first attempt at more then one colour dont mind the bleeding but, i used masking tape
Team Associated TC4-img_0633.jpg   Team Associated TC4-img_0635.jpg   Team Associated TC4-img_0634.jpg
bummy is offline   Reply With Quote
Old 02-24-2006, 08:41 AM   #8006
AM03GT's Avatar
bukil: is your "wide turn" a low speed issue or a high speed issue? as for your setup i would first try a major step in either direction to get an initial feel for the direction you need to tune to. i.e. put a gold spring in the rear to stiffen the front and see what it does... then put a green in the rear and see what that does... these are pretty extreme changes and may make the car pretty crappy around the track, but wht you're trying to get out of it is a feel for the change in track feel when stiffening the front, and when making the rear softer. from this you should have a rough idea which direction will solve your issue and make smaller steps in that direction from your original setup...
Old 02-24-2006, 12:07 PM   #8007
bukil's Avatar
I have tried that setup before. Gold springs in the front and silver in the back. It was crappy. I had a very nasty oversteer. I also tried silver in the front and green in the back. It was better. So far, the best setup that worked on my track is the one that I posted here.
I get wide turn on low and high speed issue but mostly on high speed. Anymore ideas?
Thanks,
Mark
Old 02-24-2006, 12:13 PM   #8008
bukil's Avatar
Thanks,
Mark
I take that back. I get wide turn on low speed. Our track here has a lot of twisties.
Thanks,
Mark
Old 02-24-2006, 10:49 PM   #8009
bummy's Avatar
i got a problem with me tc4, when i go around a corner, it seems to flick the back around? any suggestions? l
Old 02-24-2006, 11:15 PM   #8010
bummy's Avatar
also i just purchased 2 sway bar sets for my tc4, do they make a difference?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
