Like Tree26Likes
Old 02-13-2006, 02:40 AM   #7966
DaveW's Avatar
Originally Posted by wyd
DaveW to bad you couldn't make it last night. I understand about the snow thats for sure. I live an hour away and the ride home took about 1 1/2 hours but the roads going towards Harrisburg where just barely snow covered.
Brian i really wanted to be there, but not at the expense of possibly getting snowed in or getting the car trashed in an accident. As it ended up, we only got rain wind and cold temps here... a few flurries but nothing stuck to the ground. I got to hit the rug locally, and had a decent day on a new layout with the FT... tapped/grazed a board in the main and broke the steering rack. The car was so decent though i didnt care... i was too busy smiling!!! Track time is helping too... Do you know if you are going to Frederick this Saturday? As long as the weather is good, i can run up there! LMK.
- Dave
DaveW is offline   Reply With Quote
Old 02-13-2006, 08:06 AM   #7967
imr
imr's Avatar
Some advice please.
FTTC4, carpet, rubber tires, after about 4 minutes I begin to loose my rear grip resulting in the tail sometimes breaking out.
My guess is that the rear tires are warming up to a point and loose their traction.
Otherwise the car is great with no binding and there is no tweak (even not after the race), so no problems there.
Got a control tyre (sorex 28) and control inserts and control wheels.
What can I try to not heating up the rear tires too much?
I tried stiffen up the rear springs, but that didn't help (began loosing grip earlier). Didn't went softer, but is there sometjhing else I can try?
TIA
imr is offline   Reply With Quote
Old 02-13-2006, 08:28 AM   #7968
S_fender's Avatar
Hello,
Try lowering your rear roll center, green spring on the rear.
Can you give your setup ? It could help to tell you more...
S_fender is offline   Reply With Quote
Old 02-13-2006, 10:58 AM   #7969
imr
imr's Avatar
19T
2 ball diffs (oneway or spool is not an option form me)
40 wt f/r
no spine plate
tight twisty track
FRONT
red spring
second hole from the outside on the tower
outer hole on de suspension arm
camber links second hole from the inner side, three shims
caster block 4
steering link mounted as in manual
suspension mount shims as in manual
o toe in/out
1 camber
droop n7
REAR
blue spring
third hole from the outside on the tower
camber links second hole from the inner side, two shims (tried 1 shim, not better, maybe three?)
inner hole on the hub carrier
2.5 toe in
approx. 2 camber
droop n 6
Guess thats about it.
Overall the car is awesome, just looking for that stability the whole 5 minutes.
Old 02-14-2006, 02:57 AM   #7970
S_fender's Avatar
Wov...
I always run with rubber and i've never run with so hard springs.
I don't tell you it's a mistake but it surprise me.
I run with Front : silver-blue, rear : silver-Green.
We only use odorless traction additive.
For the suspension mount, try to lower it on the rear drivetrain.
Old 02-14-2006, 03:15 AM   #7971
imr
imr's Avatar
isn't it too slow in reaction when going to soft on springs?
We drive short twisty track, response is important.
Do you drive on carpet?
Old 02-14-2006, 03:32 AM   #7972
S_fender's Avatar
Yes i drive on carpet.
We put lighter oil and bigger Hole (#1 pistons with 30 Wt as an example) and found that it give more traction.
May be your track is smaller than mine.
Old 02-14-2006, 06:37 AM   #7973
Patriiick's Avatar
if you run such very hard springs, it may not be surprising that you overheat the tires quickly..
If the suspension "works" more, this will take a lot of heat from the tires.
Did you try also drilling the inside of the wheels with a reamer, this might also help you cool the inserts and the tire in itself..
Patriiick is offline   Reply With Quote
Old 02-14-2006, 09:49 AM   #7974
imr
imr's Avatar
I will definately try to go softer.
Old 02-14-2006, 09:50 AM   #7975
imr
imr's Avatar
thanks for the input
Old 02-15-2006, 01:11 AM   #7976
S_fender's Avatar
Hello,
If you can make a feed-back after your tests. It could be interresting to have another point of view.
Old 02-15-2006, 03:27 AM   #7977
imr
imr's Avatar
you can count on it, my next run is no before end of next week.
Old 02-17-2006, 03:05 PM   #7978
Dadaman's Avatar
Trader Rating: 20 (100%+)
The conditions over here in Australia just don't let the FT TC4's unleash their potential. It sounds like that you guys are getting more from the car over there. I spose it doesn't help that one store in Sydney keeps all their associated gear upstairs where the customers can't view it on the shelf.
As a result, I do have to say that I am changing to a T2. How many others have made the change?
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 02-17-2006, 05:47 PM   #7979
scottw's Avatar
Need suggestions:
FT TC4 On a 90 foot oval. So we are small. I have a few of the new STOCK CO27 motors.
I need suggestions for Spur/Pinion, and color tires. I use Green on front and rear outside, and Orange/purple on inside front rear. I have the final race for points this weekend. I am 1st in sedan and want to win. I got second last week, I just didnt have the power.
Thanks in advance everyone!
scott
scottw is offline   Reply With Quote
Old 02-19-2006, 06:58 AM   #7980
ffiB's Avatar
Howdy guys. Quick question for the brains around here. I will be running the kits spur, 1 72 I think? What pinion should I use for a V2 10x2 on an assfault really big wide open track?
Thanks.
Biff.
ffiB is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
