Like Tree59Likes
Old 02-07-2006, 05:33 PM   #7936
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Im done building, I got it setup exactly to that sheet. Droop 5, and Ride height is going to be 4 all around (can't set it up until I get that steering rack tomorrow).
Hopefully all goes well tomrorow. I will keep you posted.
Later guys
-Mike
Michael Barch is offline   Reply With Quote
Old 02-08-2006, 09:36 PM   #7937
ford_racing's Avatar
Send a message via MSN to ford_racing
Originally Posted by AM03GT
FT TC4 or Team Kit...?
FT TC4 as stated in my original post
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 02-08-2006, 09:37 PM   #7938
FT TC4 as stated in my original post was considering moving the steering to the outward holes
ARC R11
Yokomo YRF001
AE B5m
Old 02-08-2006, 11:40 PM   #7939
TPhalen's Avatar
R/C Tech Charter Subscriber
I would say to go up on the spring rates. Blues on carpet just seems WAY to soft, especially without bars.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-09-2006, 12:58 AM   #7940
corradopsi's Avatar
Send a message via AIM to corradopsi
wow, blues are even too soft for the asphalt track i run on with rubber!
go stiffer dude, way stiffer. check out the setups on www.rc10.com to get an idea of what people are running on different bite carpet.
Mine: Nomadio Sensor; T2'007, Keyence, Express; ZX-5 SP, Mamba Max; XB8, OS V-spec and NR P5; ProBoat Shockwave 36
My Son: Futaba 3PM; T4 RS; Clodbuster; TT-01;Zig-Zag racer
corradopsi is offline   Reply With Quote
Old 02-09-2006, 05:54 AM   #7941
macnkitty2002's Avatar
what weight oil do you guys recommend for and asphalt, parking lot race track? it's a little bumpy too.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-09-2006, 07:16 AM   #7942
S_fender's Avatar
Rubber or Foam ?
Personnaly i found that te FTTC4 like soft setup, with rubber i often run with 20-30WT and #1 or #2 pistons.
S_fender is offline   Reply With Quote
Old 02-09-2006, 07:08 PM   #7943
Ok guys. I got a bit of a problem with my FT. I finally got it setup right, Im running on Ozite Carpet, with Rubbers, and this setup:
http://www.rc10.com/racerhub/setup/r...hamps_2005.pdf
The problem is I cannot seem to get it to stop having really wide turns. I have a Hitec High Speed/High Torque Servo, and it is brand new. My D/R is set fine and everything is good. It just will take wide turns, even when I cut corners tight.
Isnt this called "Pushing?" Im sorry Im new and don't understand everything at this point.
Im running Purple up front, Copper rear. I herd I should try running stiffer up front and softer in rear, I always myself thought it was oppisite. I tired the Blue up front and Sliver in rear like the setup sheet says, but it just was too loose for me. This seemed alot better, but still Im getting those wide turns.
What could it be? Im going about Full Rear with the Tire Compound, and about 1/4 front.
If I can figure this out by tomorrow that would be great because races are tomorrow night.
-Mike.
*EDIT*
Im also running no Anti-Roll Bars. This car has the Monster Pro motor, and AI Digital Super Reverse ESC, some cheap Airtronics radio. (It was the RTR TC4, but I bought the upgrade kit). My Ride height is 5 all around, like the sheet says, droop is setup to 5 too.
Since it was RTR I still use the RTR Shocks, Im not sure what weight oil they have in them but they seem alright according to some of the fast guys.
-Mike.
Old 02-09-2006, 09:11 PM   #7944
Oasis's Avatar
Trader Rating: 36 (100%+)
Why are you only puting 1/4 traction compound on the front tires ?
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-09-2006, 09:14 PM   #7945
Oasis's Avatar
I run sliver in the front and greens in the rear but i do use sway bars,This is with rubber tires(pit 30's)and I'm hooked up..
Old 02-09-2006, 09:17 PM   #7946
If I add more than 1/4 on front (inner) than the ass end will be sliding all over on turns. I talk to fast guys that run 19T Rubber and they said to put only 1/4 on inner front, before I used to put about half and it would just be soo bad with the sliding. Now its fine.
That is not my problem anymore, its about those wide ass turns...hmm
Old 02-09-2006, 10:18 PM   #7947
Jsaves's Avatar
Default Barry's set up
Michael,
If you look at that set up again, it sure looks like Barry is running a one-way in front. Now that does effect a set up.
I would try just changing the front springs to copper. That is a change, if you keep everything else the same, that might bring the car neutral in the corners. Try to change one thing at a time so you do not go to far.
There is also some good info in the manuals that Team Assoc. put in the kit for the FT TC4 on different things to change on the car and how the handling will be effected.
God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 02-10-2006, 12:32 AM   #7948
corradopsi's Avatar
-Mike.
*EDIT*
-Mike.
why are you running rubbers now, if you were running foams before? can you go back to foams? they would be more forgiving for you as you learn to control the car better.
if you can try this setup
http://www.rc10.com/racerhub/setup/r...r_iic_2005.pdf
Old 02-10-2006, 08:11 AM   #7949
Okay so try stiffer up front then? Copper in the front, Copper in rear? Or Copper/Purple...
Im running rubbers because there a cheaper solution for me.
Old 02-10-2006, 09:09 AM   #7950
imr
imr's Avatar
I run copper in front, silver in the rear.
Front and rear, the schocks on hole from flat on the tower.
imr is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
