Like Tree1Likes
Old 01-13-2006, 11:35 PM   #7651
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by cody1
Race on carpet with take off 27's and car seems to be real close to being set up correctly but seems to have a bit of a on power push.Does anyone have any ideas to help me out on this problem.By the way the area I most would be interested in would be the effects that caster or kick up will have on my problem .Right now I have 4 degree blocks and .o25 kick up.Plus any other suggestions.
Sound to me is your car front end is going up during on power ,try reduce the droop ....
kick up work great for bumpy track....if the track is smooth take out the .025 ....or try with the oneway diff
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-13-2006, 11:37 PM   #7652
OVA
OVA's Avatar
Originally Posted by Bob Barry
cody take all the shims out from the blocks...run the car flat. if you need more steering on power try 6 deg castor. Sounds wierd but try it. Also go to 2nd hole out for camber and no washers. That should add traction. If that doesnt work then stand the shocks up a little and try a little thinner oil with the same spring you are running. You should be somewhere near 30lb front 25lb rear for springs. around 50-70 oil in the front and 30-50 in the rear....depends on traction.
Bob
the more caster make the car coming out of the corner faster...but going in slower....
Old 01-13-2006, 11:42 PM   #7653
OVA
OVA's Avatar
I think I like my BMI TC4 for now.....
Old 01-15-2006, 11:13 AM   #7654
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Can someone tell me how can I get more coner speed entry and out from this damn TC4 ?
Roberto Falcon is offline   Reply With Quote
Old 01-15-2006, 03:31 PM   #7655
CristianTabush's Avatar
Run a higher roll center in the Rear that you do in the front. I experimented with this over the weekend (1st time out with the car) and it made the biggest difference of all the changes I did to the car. I was running 4 tabs in the rear (f/r) and 2 tabs in the front (f/r). I was running on a medium grip HUGE asphalt track, so fast corner speeds are needed. To get good exit steering on asphalt I also believe you need either a oneway or a spool (the latter being my preference).
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 01-15-2006, 04:17 PM   #7656
Derby Bros Racing's Avatar
-lower front ride height than rear (i.e. 4mm front, 5mm rear)
-tighten rear diff
-softer front springs or harder rear springs
-one way for improved getting out of the turn speed
-let of the throttle sooner
Derby Bros Racing is offline   Reply With Quote
Old 01-15-2006, 05:59 PM   #7657
Michael Barch's Avatar
Send a message via AIM to Michael Barch
This is the servo Im going to be picking up for my TC4. Im new to racing and RC, my RTR servo went...my shop says this is good.
http://www.larrysperformancercs.com/...m=669962320412
Yay or Nah?
Michael Barch is offline   Reply With Quote
Old 01-15-2006, 06:50 PM   #7658
anthony390's Avatar
Send a message via AIM to anthony390
Yay or Nah?
Yay or you can also get a futaba
anthony390 is offline   Reply With Quote
Old 01-15-2006, 10:23 PM   #7659
SA_Racer's Avatar
Unhappy
I have the same problem, I use to run foams and decided to change to rubber so had my first run on rubbers this weekend, with foams I was just as fast as anyone else through the corners but with the rubers (CS27) the car seeemed to scrub too much speed. only got 2 runs and then got rained out so didnt have much time to work on setup. I may be able to try some of the sugestions next weekend.
What made things worse is that I had so much traction on my first run that I would traction roll if I came through the turns just a little too fast. it was better on the second run but still had 2 traction rolls.
let us know how increasing the rear roll centre works out for you
SA_Racer is offline   Reply With Quote
Old 01-15-2006, 10:34 PM   #7660
SA Racer:
Raising the roll center should also decrease you traction rolling.
I have found that this car is most sensitive to roll center changes rather than spring tuning. I could not personally tell much change in corner speed changing to stiffer front springs or softer. The car was still very "locked in" It seems like the rear generates a lot more traction than the front. THerefore by decreasing rear grip when raising the rear roll center, it allowed the car to rotate better in 180 degree corners after highspeed short shoots (which at my local track means 60-80 feet).
By going to a softer front spring you might get more initial steering, but not increased corner speed, you also tend to lose exit steering by doing this, which might translate into equal or less corner speed.
Old 01-15-2006, 11:29 PM   #7661
beerbarron's Avatar
Hello, I am not a perfect driver by any means but I have spent a lot of time with the car lately and I can offer my experience. I have been racing on carpet but I think it will apply. I have been back and forth between rubber and foam on this car, and I have had traction rolling problems with each setup. The tracks I have been racing at get very grippy by the end of the day.
1. Don't put traction compund on the outside front of foam tires. Clean them and start over if grip is too high. On rubber I have seen, but not tried, the sidewalls have super glue applied to them. It wont stay on long but it seemed to work.
2. Reduce the camber up front.
3. Raise the roll center. Rubber needs weight transfer to work right but if you're traction rolling you have enough grip. IMO.
4. Try a harder compound tire.
beerbarron is offline   Reply With Quote
Old 01-16-2006, 12:06 AM   #7662
SA_Racer's Avatar
Cristian
Thanks for the info, ill let you guys know the outcome, what do you guys prefer on asphalt, foam or rubber?
also does anyone here have a good base setup for medium size, medium grip asphalt using rubber.
Peter
Old 01-16-2006, 12:11 AM   #7663
bummy's Avatar
Send a message via MSN to bummy
you guys might not agree but i really like the pro-line v-rage tyres. for carpet , i find them the best comprimise between foam and slicks
and the foam i used was fast tyres and slicks were take-offs 27s
just my 2 cent worth
bummy is offline   Reply With Quote
Old 01-16-2006, 01:03 AM   #7664
SA_Racer's Avatar
Thanks BeerBaron, I did find reducing camber helped a bit, im on 1deg al the way round. raising the rollcenter is what ill be trying next.
Old 01-16-2006, 04:11 AM   #7665
bummy's Avatar
not sure which Schottky Diode to buy? as in specs? if anyone can help me that would be great thanks
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
