Like Tree26Likes
Old 12-14-2005, 09:48 AM   #7321
Super Moderator
Trader Rating: 17 (100%+)
Hey MX try 2 teeth lower than you run your monster. See how that feels. Personally I run the same pinion on both.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-14-2005, 09:49 AM   #7322
AM03GT's Avatar
depends on the 19T...
i run Reedy Quad-Mag 19T at ~5.7-5.8 FDR
100T Spur i'd start with a 43T pinion
in general if i run a 2-magnet 19T like a trinity chameleon i start 2 teeth lower and work from there...
i know it sounds a bit crazy since ususally the lower the turn motor the smaller the pinion, but this is what works for me...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 12-14-2005, 09:57 AM   #7323
Super Moderator
Dude if he's geared right on his Monster then theres no way he is going to be running 40 anything. He said 33-100 which is a 7.575 fdr. Seems a little under geared but he might be running big tires. I always start at 35-100 at every track and adjust from there. If your tires are small then obviously you will be hanging a bigger pinion on there. Just last week I ran a 37-100 and should have probably been at 38-100. But that was with 53 mm tires. If I put my 57's on then I probably would have been at 35 or 36. You really want to find out the Rollout for the fast guys and try to get there. Once you are there, switching to a 19t should be no big deal. C2's are the lowest on the rollout chart. followed by Reedy and Atlas. TOP cans are somewhere in there as well.
Old 12-14-2005, 09:59 AM   #7324
mxracer23's Avatar
Thanks guys I'll try both and see what happens. I will be running a C2 we'll see what it likes best.
mxracer23 is offline   Reply With Quote
Old 12-14-2005, 10:01 AM   #7325
Super Moderator
How big are the tracks that you are running on? I have never ran a 40-100 on a C2. with todays batteries I would think that anything this high would come off the track at 300 degrees and would loose punch around 3 minutes
Old 12-14-2005, 10:27 AM   #7326
AM03GT's Avatar
hm mxracer23 doesnt have a location tag... i guess if its carpet racing then i'm out lol... i have no experience racing on the rug...
i've geared the way i mentioned everywhere i've raced 19T...
socal raceway in ca, mid sized high bite asphalt...
parking lot races, mid to large low bite asphalt...
tamiya facility/ko propo race/reedy race...
Old 12-14-2005, 10:31 AM   #7327
Super Moderator
yeah from what I understand tracks in Cali are nothing like we run out here in the North East. If a track hits a 80 foot straight that is considered wide open. You will come across tracks that say they are 90x60 or something like that but out of that 90 foot straight you are really only using 70 or so. To me the Tamiya track is huge. I would love to run on that.
Old 12-14-2005, 10:34 AM   #7328
AM03GT's Avatar
the Tamiya track is truly a treat
Old 12-14-2005, 10:37 AM   #7329
mxracer23's Avatar
Sorry Guys Here in Figid New England running on carpet.
Bob I am running 57mm tires with the FDR 7.3-7.5 and that is right on. I was told that you should gear a 19T really tall but I was questioning the advice so I thought that I would check here first.
Mark
Old 12-14-2005, 11:10 AM   #7330
Super Moderator
The C2 is close to gearing to the Monster. Start 1 or 2 teeth down and see where you are at. I usually run 19T outside with rubber tires, your rollout from what you just told me is 24.344. My rollout for 19 outside is usually around 27.5 (35/100) with a C2 but with the Atlas it will be up near 31. I believe the Reedy is up near the Atlas.
Old 12-14-2005, 11:35 AM   #7331
DaveW's Avatar
The highest gear i have run on a C2 is 39/100... its smallish indoor rug. Some people can run a bigger gear if the driving style allows them too. If you arent smooth and peg the throttle alot... you cant run a bigger gear... like Bob said youll smoke the motor... especially with todays batts. Stock is much the same but the wire diameter is alot smaller... and cant withstand the amp draw a larger gear can cause, so gear selection isnt as wide as say 19T.... in the colder months the motor may not burn up... but the comm will definitely discolor and youll burn the brushes up... unless you are running the XXX brush. Then youll just notice comm discoloration.. and the motor will smell like a small electrical fire. The Atlas 19 supposedly needs more gear than the C2... and i have never run a Reedy 19 to comment on that. For the Monster Stock i have run as low as a 31/96 but a good ballpark starter gear for 57ish sized tires is 33/100. As mentioned earlier... the smaller/bigger the tire, the ratio needs to be adjusted to compensate.
FFIB: Did you ever get your car worked out?
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-14-2005, 11:48 AM   #7332
Super Moderator
Dave, got your PM. tough luck...I actually have a spare in my box too LOL. My rollout this past week was 24.5 with a monster. Dave I want pictures You should really try my setup. That and possibly look into moving the steering rack and servo up closer to the front.(like the BMI) I think that makes a huge difference. My car is out of commission til middle of Jan now while I do the "overhaul" new gears, ball cups etc... I would like to get it nice and quiet as well. Now it sounds like a hoover vacuum coming down the straight.....oh wait that might just be my motor's
Old 12-14-2005, 01:47 PM   #7333
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Bob go to the bicycle shop and get yourself some White Lighting chain lube. Put a small coating on your gears and let it dry. It dries and leaves a nice teflon type coating on the gears and after a run or two the gears will spin like normal but the car will be alot quieter overall. You can recoat every few weeks as needed. You can also use the Paragon Liquid graphite type stuff on the gears in the same manor as the White Lighting. I used both and they work about the same. The WHite Lightning will be fairly easy to get from any good bicycle shop.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-14-2005, 01:50 PM   #7334
Soviet's Avatar
Honestly, who cares about noise?!?!?
I WANT the belt-driven masses to hear my banshee approaching and quake with fear!
The louder the gear whine the better in my opinion...
WheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeEEEEEEEEE EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE - SCREEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 12-14-2005, 01:58 PM   #7335
AM03GT's Avatar
lol werd.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
