Like Tree18Likes
Old 12-08-2005, 09:10 PM   #7291
superslow's Avatar
Originally Posted by rc10bob
Hi guys, have a question. I run a TC4 foam tires on a carpet track. My problem is the car makes a very very sharp left-hand turn. To the right it's OK but when I turned the car to the left the car turned very sharply for a steering server I have a 9000 JR I really would appreciate what to look for I am new but learning thanks any help
one thing you might want to check is the weight on one side of the car compared to the other. at my track the weight limit is 3.31 i add about 10 to 11 7gram lead weights to the passenger side of the car. what i do is the old el cheapo method of balancing. i use golf tees and put then where the spline plate goes just remove front and back screw. set it on something level and see what way the car tips. the battery a 3800 or a 3300 will weigh more that the components. so when you turn one way you will have a different weight shift. anyone have comments on this issue.
superslow is offline   Reply With Quote
Old 12-09-2005, 12:55 AM   #7292
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
Alright, so from what ive seen, the motor mount of tc4 is bolted on, fixing the problem of melted mount on tc3 chassis.
My question is, can i just simply mill out my tc3 chassis, drill holes, and mount the tc4 motor mount?
and if so, would the factory team mount work as well or only the team mount?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 12-09-2005, 06:39 AM   #7293
frog racing's Avatar
Send a message via AIM to frog racing
Default IB 4200's
Trinity has shown on their website what many have been waiting for.
http://www.teamtrinity.com/4200.html
IB 4200 cells plus a couple of motors.
Frogracer -
8IGHT-E 4.0 KIT: 1/8 4WD ELECTRIC BUGGY
Tekin RX8, Tekin 1900kv
Hitec HSB-9370T
www.whf-texas.org
frog racing is offline   Reply With Quote
Old 12-09-2005, 06:35 PM   #7294
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
i need a good carpet and on road setup for my TC4. I got it used, but have no idea how to set it up, as i am an off roader
losirunner is offline   Reply With Quote
Old 12-09-2005, 06:39 PM   #7295
Go to rc10.com scroll down to setup sheets then onroad then pick a setup!
MOJO is offline   Reply With Quote
Old 12-11-2005, 07:47 AM   #7296
DaveW's Avatar
Originally Posted by wyd
Dave a bumch of us are going to run at Frederick Dec 17th. I Mike Jr and Sr are going and bucnh of others if you get the asphalt bug. I will be running my new to me FT TC4. Hope to get it out to practice with in the next week or so.
Hey Brian... you guys still planning on running this coming weekend? Let me know...
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-11-2005, 10:41 AM   #7297
Super Moderator
Trader Rating: 17 (100%+)
Chad Phillips just posted that he and Blackstock will be running at Horsham on the same day....just a thought
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-11-2005, 01:38 PM   #7298
ffiB's Avatar
Default Hey guys!
This may have been covered somewhere in the 244 pages here, but Im lazy. I just bought the team kit and am really frustrated with the instructions. Ill post some pics. Obviously there are some mistakes, or Im reading them wrong. Odds are, the book is wrong.
And if yall have any suggestions as far as set ups go, must do's or anything else that will help an old timer out, is much appreciated.
Peace from Houston Tx.
Biff
Biff.
ffiB is offline   Reply With Quote
Old 12-11-2005, 01:44 PM   #7299
ffiB's Avatar
My bad. I was wondering why my pic wouldnt load, then I noticed a server upgrade notice.
Biff.
Old 12-11-2005, 02:11 PM   #7300
koabich's Avatar
Send a message via Yahoo to koabich
Biff
In mosts cases such as yours the book is usually wrong
What is your issue with the book? Was there an area you needed help with or were you just letting everyone know the book is incorrect? If you need help just ask!
Personally, I didn't have an issue with the book for either the Team or the FT version. But then again I am very familiar with the TC3 so I needed the book very little. But then again, Odds are the books was good!
koabich is offline   Reply With Quote
Old 12-11-2005, 02:37 PM   #7301
ffiB's Avatar
Man, I feel I just got smacked down!
I can see now that I will regret asking a simple question. I was going somewhere, but the my pics wont load. I was merely asking for help since the instructions are wrong. BTW, Im not a noob stirring the pot. This might be my first AE TC, but I have been racing for 11 years and I can tell when the instructions are wrong.
Dont ever assume the guy asking a question is a troll. Thats why the noobs quit the hobby and take up bowling.
Can someone else help me with the transmission drawings? The spacing, the shim placement is wrong in the book. I have figured out the rear end and pics are posted on my site, but I came here to ask the experts since my site doesnt get alot of traffic.
Since posting pics are not working right now, Ill post a link and any help will be greatly appreciated.
Thank you.
Biff!
http://2coolfishing.com/ttmbforum/sh...732#post355732
BTW, my handle is Gary.
Biff.
Old 12-11-2005, 03:21 PM   #7302
DaveW's Avatar
Far from a Pro but...
BIFF: Unfortunately there is no final answer on transmission shims. You are right, the instruction manual is a good starting point... but to be "just right" it needs a little "hand fitting". Most important to remember is a little blacklash in the gears... just as you would set your spur and pinion. No bearing should be so tightly shimmed that it is sideloaded, which could damage it in use. This also includes the main driveshaft. Make sure that the foam inserts in the cups are not pressing the driveshaft tight... this will sideload the bearings on the main layshafts in the tranny cases. The mainshaft and the tranny layshafts need to "float" a bit. I actually cut one of the cup foam inserts in half... half for each cup. Seems to be pretty close from kit to kit. Keep in mind that chassis flex while you drive the car WILL reduce the amount of play between the cups and the mainshaft, so there is going to be no perfect setting... but err on the loose side for the mainshaft, err tighter on the shims for the layshafts and diffs. If the tranny layshafts and diffs are too loose... the car will be excessively noisy and you will have premature gear wear. Hope this helps.
- DaveW
Old 12-11-2005, 03:22 PM   #7303
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
- DaveW
Hey Dave I will be their Sat the 17th at Frederick. I ran my FT TC4 for the first time at Frederick since the big race and I was pleasantly surprised on how the car worked compared to my non FT TC4 witht he BMI kit on it. I'm not sure why but the car was not too far off my RDX that I ran at the big race and I had no gear issues. I didn't get to run a one way like I did at the big race so I'm interested to see what times I can run once I get the one way since the layout is still flowing. I'm glad the car seems nice on asphalt for me because my shop has no problems getting Assoc. stuff so I hope to pilot this car all season.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 12-11-2005, 03:27 PM   #7304
DaveW's Avatar
Sweet Brian, im glad you had a good day with your FT! I was seriously considering a run up there... will there be enough of a turnout for a race? Ill be able to run stock and 19T. If so what class? I have a HD one-way in my box if you would like to try before you buy. Ill know more by wednesday on my plans. They do still have tires in stock right?
- DaveW
Old 12-11-2005, 03:35 PM   #7305
ffiB's Avatar
- DaveW
Thanks Dave. I wish the pics would load so I coud show what Im talking about. For example, Bag "E" Step 3. They show a shim and a bearing in front of the drivehaft coupling where the roll pin should engage insted.
I have that part figured out. Where Im lost is Bag E, transmission step 7.
Biff.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
