Like Tree38Likes
Old 12-01-2005, 10:58 AM   #7246
Originally Posted by tc4
hey i have a few questions about the tc4:
1. do they 3racing ssg chassis chassis braces fit onto the normal carbon tub chassis?
2. my steering has alot of slop and is very wobbly. would getting the aluminium steering set help solve some of this problem?
3. do the losi xxxs front hub carriers fit onto the tc4. i have heard in some places that they do but i just want to make sure?
4. can you get lightweight aluminium screw kits for the tc4?
thanks
The 3Racing alum. rack removed almost all the slop from my steering
DOTMAN is offline   Reply With Quote
Old 12-01-2005, 11:18 AM   #7247
Anthony.L's Avatar
Trader Rating: 36 (100%+)
So did switching to RPM ball cups and a few shims got rid of most of mine. So much so that I'm keeping the stock steering rack.
Anthony.L is offline   Reply With Quote
Old 12-02-2005, 05:01 PM   #7248
mo92's Avatar
Default tire rubbing
does anyone have problems with tires rubbing on the caster blocks?
mo92 is offline   Reply With Quote
Old 12-02-2005, 05:32 PM   #7249
beerbarron's Avatar
thanks
I have used a XXXS knuckle before and it worked out great. The steering tierod mount is further inboard and that changes steering geometry some. The good thing is that the knuckles have more material in them and look beefier to me, plus foam tires should'nt rub anymore. I was told the JRXS/XXXS cater blocks will work also. I am going to get a set of knuckles and caster blocks from a JRXS and run them for a while. I hit things a lot and beefier is better for me.
beerbarron is offline   Reply With Quote
Old 12-02-2005, 05:43 PM   #7250
rainman318's Avatar
How are the tires rubbing caster blocks and where?
rainman318 is offline   Reply With Quote
Old 12-02-2005, 11:56 PM   #7251
smac's Avatar
Do you mean rubbing the steering blocks? Because I did have to grind on mine a little to keep my Jaco foam wheels from rubbing.
smac is offline   Reply With Quote
Old 12-03-2005, 05:02 AM   #7252
Default problem i think
My FT TC4 handles ok but it sometimes doesnt grip on exit of a corner and when i put the power on coming out of the corner it feels like its not puting down the power like the diffs are slipping. Im running steel outdrives and the standard carpet setup out the book any help please would be really really helpful
Bitchmonkey is offline   Reply With Quote
Old 12-03-2005, 05:05 AM   #7253
sorry i forgot to mention im running on sorex 24 tires on carpet running tire additive
Old 12-03-2005, 06:50 AM   #7254
Super Moderator
Trader Rating: 17 (100%+)
If you are having tire rub then chances are you have too much steering throw dialed in. This will only slow you down and usually cause you to spin out through the middle of the turn.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-03-2005, 08:31 AM   #7255
mo92's Avatar
yeah it rubs the steering blocks. it rubs when the tires are straight. I am assuming i will have to grind them down a bit. I was just wondering if anyone else had this problem.
Old 12-03-2005, 10:59 AM   #7256
51
51's Avatar
You may want to give this setup a try.
http://www.teamassociated.com/racerh...hamps_2005.pdf
51 is offline   Reply With Quote
Old 12-03-2005, 11:04 AM   #7257
smac's Avatar
mo92- I don't know if it is the same for other wheels, but yes with Jaco's you do have to trim it a little. Try not to go too crazy and weaken the blocks though.
rainman318-Which lower shock mount hole are you using? If you are using the outer holes, then your wheel may get close to rubbing the shock. If you are using the inner hole and your wheel is rubbing, then you need to change your suspension setup to get the car to turn harder and dial out the steering travel! You will go faster that way!!
Old 12-03-2005, 11:23 AM   #7258
I am having the exact problem with the new Jaco two stage foams.........
Ginsu is offline   Reply With Quote
Old 12-03-2005, 12:01 PM   #7259
rainman318's Avatar
I would cut down the tires before i would weaken the steering knuckle by trimming it. I cut my fronts down to 26mm and that did the trick. I did see some hex spacers made by traxxas that looked liked they would give like 1mm more space out away from knuckles. I had pro camp hex adaptors on my car originally and they rubbed steering knuckles but i changed to the original plastic tc4 ones and that went away. My problem has been tires cutting in to shock parts under full steering but i know it is my setup more than anything. I have it on the station now and am making a few changes. I have putting it off because the car has been doing so well but i also know with this stuff rubbing it is only slowing me down. I have finished first in a stock two weeks in a row but only by the skin of my teeth
Old 12-03-2005, 07:22 PM   #7260
nwilcox88's Avatar
I was at the track today (only 2nd time running on-road) I am in need of some setup help. My current setup is http://www.rc10.com/racerhub/setup/r...r_iic_2005.pdf
The problem I am having is the backend, I can not get into the throttle like I want to. The rear of the cars wants to slide out me to much. I have placed the battery back to try and get some rear bite. My first thought was add anti-squat, am i right?
I do have 2 degree cast blocks, and to be honest not sure if I like them yet. I was running 4 degree but with the 2 degree I think it might be to "responsive" (will play with that though)
I am running Stock 6-Cell, the course is more on the "technical" side, there is only one spot to get into throttle full and even that is not a long time.
nwilcox88 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
