Team Associated TC4
#7186
hi guys,
I have a problem with my rear shock.it loses his oils from the shaft.
Any idea to solve my problem?
#7187
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by Bob Barry
Racing was intense this weekend. I tried a different setup each round and ended up going slower each time so next time out I will start out with the beginning setup and try something new each race. WYD where were you at on Sat?
Cool as you are trying new stuff on the car as thats the way to learn plus your having fun.
#7189
Tech Legend
Cool. Still no probblems with gears stripping? I would imagine not since you using a 2 diff setup on carpet. Gears getting the beat down normally happen with a spool in.
Did you ever get that new BMI motor mount for your car? My new carbon drive shaft and standoffs should be here by Wednesday from Erik.
#7191
Originally Posted by kflabouris
hi guys,
1)Replace the o-rings on the bottom of the Shock
2)Replace the shaft. If the shaft is no longer the same diameter, you can replace the o-rings all you want but it will still leak. Most damage occurs when using pliers to thread on the ball cups.
Personally, I would replace both the o-rings and the shock shaft.
#7192
Replacing the shaft as a matter of course is a good idea when you've had a leak like that. At the very least roll the plain shaft on a piece of glass to see if it has any runout. If it has ANY the shaft must be replaced or it will leak again in very short order.
Scottrik
Scottrik
#7194
I did get the motor mount but I had a hell of a time getting it to work. The tranny cases had to be shimmed as well as the motor mount. It took Fred a while but he got it. I couldnt figure it out. the only other complaint I had is in order to set gear mesh or move the motor for anything you have to loosen the screws holding the top deck and lift the top deck in order to access the screw. Didnt strip a single gear though and the tranny is extremely free.
#7195
Tech Legend
Well I don't think I need to do that to adjust my motor in the FT TC4 version. Hmmm I wonder why that is on your BMI setup. Can't wait to check it out and compare to my FT TC4 so we can get a good look at the differeances.
#7197
thanks scottrik and koabich for your help.i will check it.
#7198
Tech Legend
yeah im curious to compare them as well
#7199
Originally Posted by Ginsu
Thanks Dave,
Here is a question for you. My FT Tc4 arrived today. I guess I will try the foam carpet set up for now, since I will be running my first race with it at the birds....are you going?
Its 50/50 at this time. Its getting close, but time off from work is the issue. I really wanted to go and run mod this year... but i havent had near enough track time to feel competitive. I know alot of tricks used in oval will work on TC... mixed/multi-compound tires, mixed spring rates, etc. The FTTC4 could be fitted with an offset/slider battery tray... like an oval car. It would require a bit of dremel work... but i see it being a definite possibility. You arent going to get any runtime with the car before the Birds?
- DaveW
