Like Tree19Likes
Old 11-17-2005, 06:27 AM   #7141
mxracer23's Avatar
Default Team Associated TC4
Dave W.
I am giving your setup a try tonight. I just have a quick question about running the front arms on the rear of the car. Which direction do you mount them?
mxracer23 is offline   Reply With Quote
Old 11-17-2005, 10:48 AM   #7142
Default Hoping you can help
Hi Guys,
I have been looking for several days now for information regarding set up for my FT TC4 for oval. Unfortunately there is NONE! Is there anyone on this forum who could guide me in the right direction as far as set up for oval? I will be running 19t at the snowbirds and dont even know what gearing I should run 48 or 64P? Any thoughts on springs or tires would be appreciated. Also can you advise where to get two stage foams from? I should get my FT this week and will start to assemble it....if there is ANYTHING you can think of I should know while building that would be great. Thanks.
Ginsu is offline   Reply With Quote
Old 11-17-2005, 01:55 PM   #7143
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Thought somebody might be interested in this
FT TC4 plus many parts
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 11-17-2005, 02:53 PM   #7144
karter's Avatar
Send a message via AIM to karter
2 questions. I just picked up a tc4. Never owned anything AE before so not sure how much different it is. First question. I am having trouble bleeding my shocks. Any tips on how to do this? There is no like diaphram or whatever on the shock cap(I bought it used) is there suppose to be? Any other pointers on that would be awesome
2nd question. Is there any tips on rebuilding the diff? Like how far to back out the screw and stuff like that.
Thanks in advance guys!
Josh A.
karter is offline   Reply With Quote
Old 11-17-2005, 02:57 PM   #7145
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Nope - nothing in the shock.
Just fill all the way up,then put a couple of drops in the cap. Get everything ready, take a deep breath, recite 27 mantras (your choice) and then pop them together.
You can adjust a bit by loosening the cap and compressing the shock - a bit will bleed out (or some air if you have any in there).
One way you can bleed any air is to hold the shock at an angle so the cap is higher, leave it there for a couple of minutes, then loosen the cap and compress the shock. Since the air will be higher, and you've let everything settle, the air should squeeze out the gap nicely.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-17-2005, 02:58 PM   #7146
tc4kid191's Avatar
Send a message via AIM to tc4kid191
Josh A.
im not sure about the shocks...but as for the diffs, factory stock is about 2 1/2 turns from a locked diff
tc4kid191 is offline   Reply With Quote
Old 11-17-2005, 03:36 PM   #7147
Soviet's Avatar
My Factory Team TC4.
-Sean
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 11-17-2005, 04:03 PM   #7148
VERY NICE body on that tc4.....................looks great!
Old 11-17-2005, 04:37 PM   #7149
fathead's Avatar
-Sean
Got to love those Gulf colours
Slavich Design
fathead is offline   Reply With Quote
Old 11-17-2005, 08:00 PM   #7150
Mikey Hudson's Avatar
what other accessories do i need with this car? different toe blocks? where can i find the best setup for a mod tc w/ foams on a small tight carpet track (ozite)? dbl pink and dbl pink/orange are the best tires if that helps. thanks
Team Associated, Factory Team, XP Digital, Venom, Atomik, JConcepts, Lunsford Racing, Dibrino Designs, Kal-Gard Lubricants, Mayor R/C
Mikey Hudson is offline   Reply With Quote
Old 11-17-2005, 08:01 PM   #7151
Soviet's Avatar
BINGO!
Now if only I could find some Gulf Oil decals.
I try to build clean cars. I dislike cluttered looking paintjobs.
-Me
Old 11-18-2005, 01:21 PM   #7152
jland's Avatar
Trader Rating: 74 (100%+)
Default Carpet/Rubber ?
Hey guys, just got done building my FT. Went together great, just did alittle sanding on the front steering knuckles and rear arms to get everything free. I have a few ?
How much free spin are you getting on the drive train in seconds when new? I have about 2 sec. I broke it in for 1hr at 2 volts on the bench. Any tweaks to the drive train to get it any better, I didn't want to mess with the brgs, or is that about normal starting out?
I am running in the UK, Sorex 24r premounts controlled tires, stock on carpet. I want to run the one-way but I also have the spool. I have looked at the base set-ups, just don't know which to start out with. Any of you UK guys have a staring point? Any of you guys have any rubber/carpet experience? If so what set-up did you start with? Any recommendations?
Cheers for the help guys.
jland is offline   Reply With Quote
Old 11-18-2005, 01:28 PM   #7153
AM03GT's Avatar
you can always benefit from a free'er transmission and more free spin... but it isnt everything. as long as the transmission is smooth you are fine. spin the tranny up slowly and feel for any gear interference... if that checks out, and the tranny spins up and spins down slowly to stop, then put it on the track, its good to go.
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 11-18-2005, 01:32 PM   #7154
Take the shaft out and see if the front and back free spin equal. If not it gives you a place to start. 2 sec is not very long. You can also take the transmission out, cut the bell end off of an old dog bone, chuck it up in a drill, insert the dog bone in the input cup of the transmission and spin it up to break it in.
JWATT is offline   Reply With Quote
Old 11-18-2005, 05:37 PM   #7155
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
Hey Soviet,
Is that an American Flag AE sticker on the top plate towards the front of the car?? I havent seen those in a long time, since my old aluminum tub rc10..... If they are new, where did you get them?.
Thanks,
Mike
MikeDeadly is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
