Like Tree38Likes
Old 11-13-2005, 01:55 PM   #7126
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Losi parts
Anybody want to try the Losi 4 degree C Hubs, Losi Sterring knuckles, Losi Rear Hub Carrier on there Factory Team TC4.
I Also have a P-Dub Bumper 4 Sale.....
Send me a PM
Selling parts real cheap.....
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 11-13-2005, 10:28 PM   #7127
Trader Rating: 22 (100%+)
Originally Posted by runnin rc10
This is a FT setup right? If so, do you guys feel the stiffer chassis allows for stiffer setups? Im running a really soft setup comapred to what im used to in TC. I still have the all graphite tub, FT in a few weeks. If there are differences, what should I do different to the FT setups when I put them on my car.
Just transfer your tub setup onto the FTTC4 and I am sure you will be happy with it, then work from there.Thats all I did with mine and it now holds the track record in it's class. The cars are not to dissimilar the FT is alot more constant lap after lap.
bjspinner is offline   Reply With Quote
Old 11-14-2005, 03:16 AM   #7128
bjspinner
I found the 3 racing shock tower mounts bind the bearings as well. You need to grind short some screws to stop them binding up the bearings.
I am not sure if the 5 mount holes are any better than factory or not.
They seem to be in the wrong place, the mounts are in between the AE options and the front holes are quite a bit more upright than the rear shocks if you try to run the same hole all round.
I think I prefer the AE options for shock mounts, just feels the same on all four corners of the car.
However, the 3 racing camber link mounts I think are much better than the AE ones, because they are one piece.
You don't need four mounting options for the ball stud, never seen any body use the outer two anyway!
mark240973 is offline   Reply With Quote
Old 11-14-2005, 08:32 AM   #7129
Super Moderator
Trader Rating: 17 (100%+)
Hey guys finally got to work on my setup a little this weekend. Car was awesome, driver sucked LOL. Here's where I am at.
Front
70 wt losi oil
2 piston
purple springs
inside on arm
3rd hole out on tower
camber - 2nd hole out silver ball stud 2 washers
4 deg castor
4mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
camber all the way in black ball stud no washers
inside on hub (switched back to AE hubs)
no washers under blocks
4 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
Team Express Monster geared 37-96
Team Express GP3700's
Protoform stratus 3.0 carpet (Parma Alfa is the way to go though)
Next week I plan on trying to raise the rear roll center by .025 to get some more rotation.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-14-2005, 12:33 PM   #7130
DaveW's Avatar
Yes its a setup for the FT. The tub car will need softer setups. Chassis twist/flex will play a big role in the handling... or lack thereof... for that car. Stiffer setups in general work best on a stiffer chassis. You have to take into account roll center too... alot of people look at shock position and spring choice and instantly see "stiff", and dont take into effect the camber link positions/hingepin block shims.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-14-2005, 12:46 PM   #7131
Thanks for the insight guys. I hope to get teh FT conversion in a few weeks. For now Im going to grab a old tub setup from ae's site and start from there. Its the steve rossi setup. I chose it because is a tight track like man and he used jack the gripper instead of paragon which is the new rule here. I think its a great start. I'll keep you guys posted.
runnin rc10 is offline   Reply With Quote
Old 11-14-2005, 04:38 PM   #7132
Trader Rating: 68 (100%+)
What up guys just recently went back to associated,anyone have a base setup carpet foam?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 11-14-2005, 06:37 PM   #7133
Super Moderator
If you are running a FT car then try Dave's setup. If you are running a BMI car then you can try mine. I'm sure either will get you a good starting point. Hell try them both and compare
Old 11-15-2005, 06:41 AM   #7134
biker's Avatar
Hey guys,
Any info regarding availability dates for the FTTC4 conversion kit..and the best place to pick one up?
biker is offline   Reply With Quote
Old 11-15-2005, 10:06 AM   #7135
Soviet's Avatar
Originally Posted by biker
Hey guys,
http://www2.towerhobbies.com/cgi-bin...&I=LXLPG4&P=ML
Tower says late November.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 11-15-2005, 11:45 AM   #7136
sorry guys...got a great deal on a JRX-S today...I drove one last week, smooth as silk. So my tc4 is up for sale, if anyone is interested check the for sale forum.
Old 11-15-2005, 12:05 PM   #7137
They have been out for 3 or 4 weeks now. The local shop has had them also. Thats not saying they might be sold out at this time.
Check around, you should be able to find one.
Hey guys,
walterhenderson is offline   Reply With Quote
Old 11-15-2005, 12:14 PM   #7138
Super Moderator
Hey Walter, Have you ever tried running the outter hole on the steering knuckle? I want to angle the steering turnbuckles forward but I can't add any shims to my steering rack. The BMI chassis has the Servo moved forward so I can't do anything more than just a silver ball stud with no washers.
Old 11-15-2005, 02:00 PM   #7139
Super Moderator
If you wanna rub fenders with any of these guys check out the Express website for our NORTH SOUTH SHOOTOUT!!!!!
www.tmxpress.net
Express sign up list to date:
Touring stock:
Mark Painter
Mike Kling
Paul Buohl
Ron Binkley
Steve Walter
Sean Walter
Robbie Dodge
John North
Laurie Willis
Tyler Keel
Jason Schreffler
Mike Herald jr
Will Duncan
Billy Duncan
Larry Fairtrace
Guy Hood
Jon Williams
Jeff Cuffs
John Tag
Fast Freddy
Dan Hartman
Arron Sanford
Reggie Wade
George Rylas
Anthony Saunders
19T:
Ray Darroch
Robbie Dodge
Jason Schreffler
Larry Fairtrace
Dan Hartman
Keith Trapp
Craig Xavier
Billy Spence
Ike Peacock
Brandon Melton
Jeff Cuffs
Brandon Hess*
Mike Herald jr*
Touring mod:
Ray Darroch
Keith trapp
Reggie Wade
Justin Listard
Brandon Melton
Brandon Hess*
Jimmy Mac*
Minis:
Mike Kling
Andrew Tag
Ron Zelenka
1/12 stock
Steve Walter
Paul Buohl
Mike Herald sr
Mike Herald jr
Ron Zelenka
Fast Freddy*
Chris Cowder*
Mike Cummings*
Herb O'Loughlin*
Old 11-16-2005, 01:17 PM   #7140
AM03GT's Avatar
For those socal locals... there is a Socal Raceway setup posted on the AE site... for those who aren't local to the track, its a relatively unique racing surface but general speaking its high-bite asphalt.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
Farmer_John, rvrslt1
