Like Tree59Likes
Old 11-06-2005, 12:07 AM   #7081
DaveW's Avatar
Originally Posted by Number 11
That's funny Dave.
Surely you know i was serious.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-06-2005, 08:14 AM   #7082
As soon as you change the plastic outdrives to alu. you will not have it happen anymore. No clue why this is, but it worked for everyone at my track, only did the rear too....
runnin rc10 is offline   Reply With Quote
Old 11-06-2005, 10:19 PM   #7083
BatJam1's Avatar
I know i'm opening a can of worms here but i perfer the steel diffs stock and modified .I personally feel and, I may be wrong but I think the steel diffs even though they have more rotating mass, they provide more Enertia coming into the turn so it keeps corner speeds up,as with the plastic diffs and especially with a stock motor (more braking) I think it looses its enertia and corner speed suffers . My opion!
BatJam1 is offline   Reply With Quote
Old 11-06-2005, 11:18 PM   #7084
Fatboy Joe's Avatar
Does too much steering slop affect the car's handling and stability?
Fatboy Joe is offline   Reply With Quote
Old 11-06-2005, 11:47 PM   #7085
Trader Rating: 22 (100%+)
I totally agree with what you say I have used the IRS ali diff which I feel is smoother but as for feeling the corner speed steel diff all the way.It keeps the momentum higher through the corner, stock and 19t motors tend to slow down quicker than low turn mods so you lose corner speed.
As for bodies flexing in hits and getting caught many years ago I saw a world class racer from Japan with a 1/8th scale nitro body they had put shoe goo into the corners of the body to increase strength. since then I have done this on all scales of bodies along the front splitter also and dont have problems ever, and I get great life out of my bodies.
bjspinner is offline   Reply With Quote
Old 11-07-2005, 03:22 AM   #7086
Registered User
tomlau's Avatar
hi
i have been using the Square RC delrin outdrive on my tc4 for a couple of months now for racing stock. i am just about to start racing mod (with 12T motor limit) will they hold up ok of that? ive used delrin outdrives in other cars for mod so i would have though these would be ok too. anyone got any experience on these?
thanks tom
tomlau is offline   Reply With Quote
Old 11-07-2005, 04:33 AM   #7087
Hi guys! A question: better diff in plastic or those in steel? Thanks from Italy!
Mimmo is offline   Reply With Quote
Old 11-07-2005, 09:23 AM   #7088
warpig's Avatar
Delrin is super resistant to wear. I would make sure there are no jagged edges on the dogbone end of the CV shaft though. Steel will wear out before delrin will.
warpig is offline   Reply With Quote
Old 11-07-2005, 09:46 AM   #7089
Number 11's Avatar
- DaveW
Actually I thought you where joking. But that is even funnier now.
Number 11 is offline   Reply With Quote
Old 11-08-2005, 07:28 PM   #7090
BatJam1's Avatar
thanks for the back up! And i too have been using the shoo goo and wall re-enforcing tape to ensure long life to the front of my bodies for many years now ! Just have to watch the weight build up!put it up around the front wheel wells and the front bumper,after paint dried!!!!!!
Old 11-08-2005, 07:29 PM   #7091
BatJam1's Avatar
I perfer steel mimmo.They just keep momentum up in the corners with stock and 19 turn motors !
Old 11-08-2005, 07:33 PM   #7092
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Any one else having problems with the VCS bobbin not snapping down into place inside the shock? I've had two shocks begin leaking recently because the VCS bobbin doesn't stay in place snapped down into its groove. I have even tried buying the flat square shock part used in the older AE shocks that snaps down into the groove above the o-rings. I can not get them to snap down into the shock body. I am using the yokomo caps so I dont need the bobbin. I can't get the original bobbin or any of the lock washers I bought to fix this problem to seat and compress the o-rings like they should. Am I missing something? It almost makes me think the problem is the shock body groove not being small enough to hold the lock washer. I cant imagine the aluminum would wear at all.
Old 11-09-2005, 01:45 AM   #7093
DaveW's Avatar
The TC3/4 shock bodies (blue) have no groove for the bobbin to snap into. The offroad bodies (gray) have a groove for the flat "square" piece to snap into. Its a different setup. The TC3/4 bodies hold the bobbin in place with friction, and thats it. The 8 points on the bobbin force against the walls of the shock body to keep it in place. There is a definite "snap" heard when you install the offroad shock parts, but the TC3/4 parts just press into place. It is possible for the adonization to wear enough on the inside of the shock to make it hard to hold the bobbin in place... not through wear of the piston... seeing as it doesnt go down that far, but through consistent and often rebuilds. (i have an old TC3 set that are no longer blue on the inside... but mostly silver!) This however would be harder to happen (age) than say just forcing the bobbin in place and deforming the 8 points of the bobbin and making it harder for it to stay into place. If the bobbin "snaps" at the top of the shock as you insert it, then it is deforming the tips of the bobbin. Try inserting it at angles till it is in place with no "snap" at the top of the shock. Are you using the old skool AE shock tool to build your shocks? I dont know why AE doesnt include that simple tool anymore... it works great.
- DaveW
Old 11-09-2005, 05:52 AM   #7094
Thanks BatJam!
What do you think about a foam set-up tyres on carpet track ,whit 8 / 9 turns motors?
Bye!
Old 11-09-2005, 06:17 AM   #7095
I am not using the AE tool. I figure the bobbins just wore at the 8 tips becasue the shock body is SOLID blue all the way down. THe bobbin just slides down into place and has no resistance going into place or coming out. I guess I will have to try new bobbins. Thanks dave.
Andrew
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
