Like Tree38Likes
Old 10-31-2005, 08:05 PM   #6976
BatJam1's Avatar
change the caster blocks from 4 to 2 degrees even 0 for carpet.You might not scrub off speed in the corners so badly.I know it worked for me.
BatJam1 is offline   Reply With Quote
Old 11-01-2005, 12:31 AM   #6977
imr
imr's Avatar
with rubber or foam tires?
imr is offline   Reply With Quote
Old 11-01-2005, 12:44 AM   #6978
slippery49's Avatar
Default TC4 Shocks
I am having probs with shocks leaking, just about afer every race meet I have 1 or more that need to be redone,
Most probably it is my incompetence that creates this, but what are my other options for different shocks.
slippery49 is offline   Reply With Quote
Old 11-01-2005, 01:37 AM   #6979
Trader Rating: 22 (100%+)
Read back a few pages there is a post by Dave W there is some info on the shocks and what to possibly look for.
As for the car lacking corner speed I feel this is no problem with the FT TC4 the car is a pleasure to drive, turns in better more on power steering and better transition than the team kit.
bjspinner is offline   Reply With Quote
Old 11-01-2005, 05:11 AM   #6980
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
@Shock leaking-
Check to make sure the VCS bobbin is snapping down into the groove at the bottom of the shock. I had a shock recently that began leaking because of this. If the bobbin doesn't lock into the groove the two o-rings beneath it are not sufficiently compressed around the shaft which allows oil past the o-rings.
Old 11-01-2005, 05:25 AM   #6981
Trader Rating: 195 (99%+)
It seems with the FT. Less caster makes this car push more and loose corner speed.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 11-01-2005, 07:11 AM   #6982
On carpet we are running at least 4* castor blocks if not 6* castor blocks.
Walter
walterhenderson is offline   Reply With Quote
Old 11-01-2005, 07:14 AM   #6983
I have found the 6 degree work the best. This car may come around after all.
www.donatelife.net
Old 11-01-2005, 08:27 AM   #6984
imr
imr's Avatar
I'm driving with 4 castor blocks. Having a little problem with the rear, would going to 6 make the rear holding better when I turn in at the end of the straight?
Its just that little I'm searching to make the car perfect for me.
Old 11-01-2005, 08:58 AM   #6985
The 6 would not let the rear hold better. Change your rear camber rod length.
www.donatelife.net
Old 11-01-2005, 12:01 PM   #6986
Number 11's Avatar
Anybody know what the steering linkage length is? The manual only says SO what the heck is that?
Number 11 is offline   Reply With Quote
Old 11-01-2005, 12:29 PM   #6987
imr
imr's Avatar
It is now in the second hole (counting from the inside) and with 3 shims.
Do I have to go to the first hole, thus making the link longer?
Old 11-01-2005, 12:32 PM   #6988
Super Moderator
Trader Rating: 17 (100%+)
imr, just to give you a comparison I run the rear link as long as possible with NO washers and a black ball stud to lower it even more.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-01-2005, 02:04 PM   #6989
DaveW's Avatar
NUMBER11: SO stands for Setup Option... are you running the stock TC4 steering block, and if so, what hole is your link in? Closer to the tire... or closer to the chassis? The general length will vary... depending on this, and the amount of toe you want (other things too).
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 11-01-2005, 02:28 PM   #6990
gone_wheelin's Avatar
Default Steering Upgrades
I have been strugling with slop in the steering rack on the Team kit. I managed to take up most if not all with some shims but now the steering movement from side to side feels a little stiff, even after cleaning and re-lubing the bearings.
I have seen a few others post that they are using the Losi XXX-S dual bell crack instead of the Associated rack. I was wondering if anyone has tried the alloy steering rack from 3Racing in place of the composite stock (associated) piece? Also, the dual bell crack from Losi, is it a direct bolt-on? I also found that there is an alloy upgrade available for this as well. Has anyone used the alloy and, if so, how does it compare to the stock piece?
Thanks in advance.
gone_wheelin is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
