Like Tree19Likes
Old 10-27-2005, 09:45 AM   #6916
SA_Racer's Avatar
Are the composite cvd's alot weaker than the aluminum cvd's? Ive noticed the composites are about 1.5 grams lighter per cvd so thats 6 grams less rotational weight on the drivetrain, not sure if 6 grams will realy make a difirence but they look pretty strong ive just never used them so would be interested in knowing if anyone here has ever broken one, I also cant imagine them bending but I would expect a certain ammount of flex.
what are your thoughts?
SA_Racer is offline   Reply With Quote
Old 10-27-2005, 09:49 AM   #6917
Super Moderator
Trader Rating: 17 (100%+)
just get the Aluminum ones and be done with it.
Tekno | BLOK | JConcepts | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-27-2005, 10:40 AM   #6918
AM03GT's Avatar
the weight difference isn't going to do much. i personally run the composite ones in the rear, i do this only so that i have more spare aluminum ones for the front where they wear more often and take more abuse. I've had composite bones in the rear since May and they are still in perfect condition.
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 10-27-2005, 11:33 AM   #6919
Scottrik's Avatar
Trader Rating: 242 (100%+)
Reducing (or adding) rotational mass at the axis of rotation has realistically nil effect when you're talking comparatively small numbers (like 6g on a 1500g +/- car). It is certainly mass, no doubt about it but it doesn't have much effect other than between the ears, certainly no where NEAR as much (like, exponentially) as reducing mass toward the circumference of your tires/wheels, gears, etc.
Scottrik
Scottrik is offline   Reply With Quote
Old 10-27-2005, 11:42 AM   #6920
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
This is a discussion that comes and goes over time - accompanied by much argument.
There are two schools of thought regarding droop.
First is that it is not, strictly speaking, affected by tire wear because it is the AMOUNT of drop-out from the chassis to some point measured at the end of the suspension arm (AE Gauge method). Tire wear is completely irrelevant here since we're not measuring anything having to do with tires. This is the DIFFERENCE between ride height and the amount of down-travel each arm has - call it down-travel instead of droop (D-T). As the tires wear down (we're talking foams here) this will not change.
The Second IS affected by tire wear because it is measured as an absolute value. It is the measurement, with the tire on the ground, of how far UP the chassis will travel. Use a RH gauge, hold the tire to the ground, and measure with the chassis lifted as far up as it will go - measure at all four corners. This IS affected by tire wear simply because the tires ARE a measure. Call it full-extension-RH (F-E-RH).
so, which is right? Again - different schools of thought.
Personally, I think the second is more important. Essentially, it's the RH at full extension. If, as you wear your tires, both your RH and full-extension-RH decrease, your handling is going to change, then you must make adjustment for it by adjusting BOTH your RH AND your F-E-RH. But you really need a base setup to begin with - that should include a starting tire-size, standard RH and D-T (which will establish a beginning F-E-RH) - then throughout the day you can adjust the F-E-RH and RH as needed.
I hope this made sense. I'm NOT dogmatic about it, I'm just trying to digest a LOT of previous argument into a short, explicit little blurb. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-27-2005, 11:42 AM   #6921
I started with the RTR so all I had was the composite CVDs. As a beginner, I put the car through quite a torture test. I did manage to break one of the front CVDs, but not until I had a horrible crash that broke the front suspension arm and the steering hub and bent the hinge pin and the bolts that hold the steering hub in place. Given all the other damage, I was not surprised that I also broke the CVD.
The composite CVDs have survived slightly less dramatic crashes, including one that broke the suspension arm.
Thus, my conclusion is that the composite CVDs are quite tough. They are not as pretty, but I would not hesitate to use them. I was actually disappointed that my LHS did not have the composites, so I had to get a pair of alu CVDs to replace my broken one. Now I run alu front, composite rear.
Ira
iblumberg is offline   Reply With Quote
Old 10-27-2005, 11:44 AM   #6922
Boomer's Avatar
Scottrik
I think you're right - but you might use a different number. Not all of the car rotates, so you'd be looking, more realistically, at 6g on a rotating mass of 150g (or whatever the drive-shaft, gears, dogbones, and tires would total - it'll be more significant than as compared to the entire car, but still small. . .)
Old 10-27-2005, 03:41 PM   #6923
AM03GT's Avatar
someone asked me through PM to post pics of the shock upgrades and the battery strap. not the best pictures but i hope they suffice.
Old 10-27-2005, 04:09 PM   #6924
BlackKat's Avatar
Thanks Boom,
So, two different concepts. Downtravel and Full Extension Ride Height...Downtravel is changed as tires wear and ride height gets reset to maitain the same full extension ride height. I get it!
A downtravel number for a foam setup seems irrelevant unless your going to run tires exactly the same size. Too bad the AE crew doesn't do what the Losi drivers do and write down what the full extension ride height is instead of the downtravel ("droop") number
BlackKat is offline   Reply With Quote
Old 10-27-2005, 05:32 PM   #6925
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
AM03GT-
hey what online shop can i get that battery brace from? thanks man.
-joe
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 10-27-2005, 06:00 PM   #6926
beerbarron's Avatar
Is there a difference between carbon and non-carbon parts? Other than $$$, I cant't seem to tell them apart.
beerbarron is offline   Reply With Quote
Old 10-27-2005, 06:03 PM   #6927
Andrew Selvaggi's Avatar
So two different schools, 2 different methods...............1 simple solution........RUBBER
Thats what we have done down here in aus, at most major events we are now got a controled rubber tire, the tire war as we call it was just getting too big. But this is coming from an off roader who has just started onroad
I should get my FT TC4 on monday, man i cant wait, ive gone full out on starting to race onroad. new car, tire warmers, setup bored and all that TC crap you use. But i will forever think that Off road is where the racings at
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 10-27-2005, 07:09 PM   #6928
koabich's Avatar
Send a message via Yahoo to koabich
Non-carbon parts are darker than the carbon parts. Carbon parts have lighter colored composite fiber through them.
Non-carbon is also less brittle but also not as stiff as their carbon based counterparts.
koabich is offline   Reply With Quote
Old 10-27-2005, 07:19 PM   #6929
Trader Rating: 21 (100%+)
Originally Posted by S_fender
Correct me if i'm wrong :
X 2.5 + square = 2.5 ░ toe in
X 3.0 + "O" = 1░ toe in
it could be the reason of your problem??
Just saw this.Not sure of the total with the "o" block.If your right I would imagine that at least is a factor.I was just wondering if that amount of wear could be considered normal or not.The car drives awesome like this,so if it's normal I'll deal with it.Just got home from practice,haven't measured anything yet,but the car was handling great.Set the front ride height to 4.5mm and got my low speed steering.The track was also warmer too.Thanks for all the help,Mario.
lotus1 is offline   Reply With Quote
Old 10-27-2005, 07:29 PM   #6930
Jsaves's Avatar
Dave W.
This guy knows what he is talking about. Use it and see.
God Bless
Bryan
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
