Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 10-20-2005, 06:30 AM
  #6811
Trader Rating: 22 (100%+)
March taking out all the shims will change the roll center on the car.
Bob Barry is offline
Old 10-20-2005, 10:21 PM
  #6812
beerbarron's Avatar
I was going to replace the pivot balls soon, any recommendations? I have seen some delrin and flouride coated or should I just stay with stock? Also, where is a cheap place to buy?
BTW, still love driving the car- 3rd in A again.
beerbarron is offline
Old 10-21-2005, 01:09 AM
  #6813
Does someone know when the FT Conversion kit will be available???
Can't wait anymore!!!
canto54 is offline
Old 10-21-2005, 05:26 AM
  #6814
It is available now.
Old 10-21-2005, 05:27 AM
  #6815
Where?? I can't find a webstore that sell it!!
canto54 is offline
Old 10-21-2005, 05:44 AM
  #6816
Trader Rating: 208 (100%+)
Anyone come across some oversize pivot balls. These do get some slop.
dodgeguy is offline
Old 10-21-2005, 07:11 PM
  #6817
Jsaves's Avatar
Default Bumper
hey Guys,
I got one of those parma ultimate bumper. It is much wider than the stock foam one. I did have to play with it a little to get the good fit. It is dense foam does a nice job.
God Bless
Jsaves is offline
Old 10-22-2005, 07:02 PM
  #6818
i_got_m8_4_$85's Avatar
are the lightened steel diffs anygood??
i_got_m8_4_$85 is offline
Old 10-22-2005, 07:33 PM
  #6819
koabich's Avatar
The steel diffs are way too heavy, even for mod in my opinion. Also, the diff rings on the steel outdrives are round (not the D-rings that the plastic diff uses or like those of almost every modern car out there) and this could cause the diff rings to slip. If you are running stock, stick with the plactic outdrives. If you hit the alls alot and run stock, use the IRS Aluminum outdrives in the front and the plastic in the back. If you run mod, I would run the IRS aluminum outdrives all around. They are extremely light and almost as tough as the steel outdrives. If you use dog bone pin cushins, they will last forever.
koabich is offline
Old 10-22-2005, 08:48 PM
  #6820
J_P
J_P's Avatar
Here is another oppinion. They are great.Basically, it is the same diff that is a legend in Off-Road. Different diameter, but same concept. The car is way under weight, so to make weight, it doesn't hurt. Plus it is very low in the car. I know, but it is rotation weight, and lighter is better. Yes, on acceleration. But the weight also keeps things rolling, and seems to carry more through the corners when you are rolling through. Plus, they are very durable.
J_P is offline
Old 10-22-2005, 09:00 PM
  #6821
koabich's Avatar
Personally, if the car was underweight, I would rather add the weight to the chassis and not to the drivetrain. But that is my preference...i'd rather keep the rotating mass as light as possible.
koabich is offline
Old 10-22-2005, 09:56 PM
  #6822
What do u guys like better, 64 pitch or 48? In a tc4 of course...
MarchTC3 is offline
Old 10-22-2005, 11:00 PM
  #6823
koabich's Avatar
I like 64 pitch. Most say that it will quiet the drive train down a little but I have never noticed that on any of my cars. I like it becuase it offers a finer selection of gearing.
koabich is offline
Old 10-23-2005, 01:13 AM
  #6824
The circular diff ring was something I was wondering about the other day. Surely this would not work properly as with a D shaped ring that clips into place for example. One of my friends got a ball diff for a cheapie academy car with circular diff rings and it would not stop slipping. We tightened it till the diff screw broke to try and get it to stop...
ralph_c is offline
Old 10-23-2005, 02:25 AM
  #6825
Scottrik's Avatar
Trader Rating: 261 (100%+)
Default Believe it or not...
...once upon a time ALL diff rings were round.
Everybody who remembers supergluing rings to hubs raise your hand. The one that ISN'T stuck to the back of your RC12i...
Scottrik
Scottrik is offline
