Like Tree19Likes
Old 10-15-2005, 07:30 PM   #6751
Trader Rating: 194 (99%+)
Originally Posted by gonzo416
not a good idea to take the seals off the bearings because it makes them fragile. if you hit something it will destroy the bearings.you'll be replacing bearings like crazy, i know
Taking the seals out do not make the bearings any less fragile in crashes. The seal only float between the cups.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-15-2005, 09:20 PM   #6752
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
can someone please post the foam setup that comes with the FTTC4 kit, mine is MIA and it's not on associated's site
I wouldn't worry about the kit carpet setup, I'd just go with Barry's from Vegas. Its going to be a lot better and more up to date.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 10-15-2005, 10:52 PM   #6753
Trader Rating: 18 (100%+)
could anyone post a setup for socal raceway in huntington beach? I just switched to this car and would like to go out it a good starting setup. I am going to be running stock.
Chris Brown is offline   Reply With Quote
Old 10-16-2005, 02:29 AM   #6754
Originally Posted by koabich
If you buy the FT TC4 Conversion, to upgrade your TC4 tub chassis, you will still need to buy several items to have a car identical to a Factory Team TC4. Stuff like the plastic outdrvies, Carbon parts such as A-Arms, Steering and hub blocks, sway bars, blue aluminum screws...etc. If you want a car identical to a Factory Team TC4, it may be cheaper to just buy the Factory Team TC4.
And yes, you will have the tub and shock towers and misc. other stuff left over from your other car that you'll probably never use.
Very true, not to mention the bearings. Does the FT TC4 come with Teflon sealed bearings like the FT TC3 did? They are a big improvement over the stock associated bearings. I used my old ones from my FT TC3 in my TC4.
TC4 Rider is offline   Reply With Quote
Old 10-16-2005, 09:52 AM   #6755
macvolcom's Avatar
Send a message via AIM to macvolcom
Look in the so cal section on this forum. I posted it in there.
macvolcom is offline   Reply With Quote
Old 10-16-2005, 11:34 AM   #6756
Super Moderator
Grizzbob's Avatar
Yes, it does, & you're right, they ARE indeed smoother & more friction-free than the rubber-sealed ones....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-16-2005, 02:39 PM   #6757
frog racing's Avatar
Send a message via AIM to frog racing
Would like to know how one may go about protecting the graphite chassis of the FT TC4. I see AE sells a plastic film Associated Factory Team Chassis Protector 6.5x18" RC10 is this recomended? I would really hate to mess up the underside of this car. I will be running on concrete and asphalt. Any insight to other similar type products welcome.
Thank you,
K
Frogracer -
8IGHT-E 4.0 KIT: 1/8 4WD ELECTRIC BUGGY
Tekin RX8, Tekin 1900kv
Hitec HSB-9370T
www.whf-texas.org
frog racing is offline   Reply With Quote
Old 10-16-2005, 03:27 PM   #6758
That stuff has been around for years. Back in the day with the colored RC10 chassis.
www.donatelife.net
Old 10-16-2005, 03:48 PM   #6759
koabich's Avatar
Send a message via Yahoo to koabich
Thank you,
K
The off-road guys use it on their chassis to help reduce the friction of when their chassis bottom out.
You can try to use it but for me it's more trouble than it's worth. First, it's very expensive. Second, it can be difficult to use. You either build the car and put the cover protectant on the bottom of the chassis. Or you can put it on a bare chassis and cut out all the battery slots and screws holes so you assemble/dissamble the car with the film in place. If you do not, you have to remove the film to take apart or work on you car and then you have to buy new stuff to replace it since it's not resuable.
Believe me I tried it when I first got into the hobby and then after fighting with it for some time, I realized that not matter what I do, I will not be able to stop the bottom of my chassis from scratching.
koabich is offline   Reply With Quote
Old 10-16-2005, 06:48 PM   #6760
Fatboy Joe's Avatar
Default Drescher Reedy Race 2005 Setup
Hi, Im looking for Craig Drescher's setup in the 2005 Reedy Race of Champs. Anyone can help? Thank you very much
Fatboy Joe is offline   Reply With Quote
Old 10-16-2005, 08:59 PM   #6761
You could try clear duct tape.
Chris Reilly is offline   Reply With Quote
Old 10-16-2005, 10:21 PM   #6762
newera152's Avatar
I whent to socal looking for this setup and didnt fint i found your post but not the set up,whats it called.
newera152
newera152 is offline   Reply With Quote
Old 10-17-2005, 06:32 AM   #6763
mxracer23's Avatar
I am looking for some setup advice. I tried walter's setup at my local track and found my car was really loose it pushed mid corner through and then it hooked and got the rear loose. I am convinced that our track just doesn't build enough traction to support it. Does anyone have any setup advice for a club/ lower traction carpet track?
THANKS
mxracer23 is offline   Reply With Quote
Old 10-17-2005, 06:52 AM   #6764
THANKS
I have been having the same type of problem. I am starting to get it worked out. Here is my set up.
Front
Purple springs
2 piston
55 wt oil
Short wheel base front
black sway bar
outer hole on the knuckle
3 washers both inboard and outboard ball stud on steering
Camber link in the 2nd hole from center with black ball stud and 1 washer
shocks mounted inner hole lower 3rd hole out on top
1 shim under both arm blocks
2 degree of caster
BSR double pink/orange tires
Rear
Gold springs
2 pistons
55wt oil
O front block in the rear.
3.0 rear toe block
1 shim under front block
2 washers in front of arm
camber link mounted 2 hole from center with silver ball stud and 1 washer
rear shocks mounted outer hole bottom 2 hole upper
BSR double pink tires
I used Niftech traction compound. A monster geared 1.0 for roll out
The car still has a little on power push but it is getting better. I would like to have the car rotate more. My XXX-S rotated very well. I just wish I can get this car to do the same.
www.donatelife.net
Old 10-17-2005, 07:04 AM   #6765
mxracer23's Avatar
Thanks Dodgeguy, I will give it a try
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
