Like Tree59Likes
Old 10-12-2005, 06:59 PM   #6691
beerbarron's Avatar
What spur/pinion brand would you guys suggest for stock on my FTTC4? The 48p make way too much noise for me.
BTW, I just ran my FT TC4 at a club race ( first time driving the car) and lucked into third in the A. Up until last week I was a first in the B guy. I practiced some today with the car and it feels and looks so much faster than my XXXS. It got a few people to question if the motor was stock, which it very much is.
beerbarron is offline   Reply With Quote
Old 10-12-2005, 08:14 PM   #6692
newera152's Avatar
Talking
what spur are you using with the 48p
newera152 is offline   Reply With Quote
Old 10-12-2005, 08:22 PM   #6693
newera152's Avatar
Talking
Bob is that a 64 or 48 pin to run the 100 spur, I have a 108 spur which I think would use the 64 pin.and that will give me more speed.also shock how should I use them, harder the spring the better the tracion. Thanks
Old 10-12-2005, 08:23 PM   #6694
koabich's Avatar
Send a message via Yahoo to koabich
If you are worried about noise, you picked the wrong car. Shaft drives are always going to be loud and gears will only help that to a certain extent. I use 64 pitch in all my cars and the difference in noise is barely noticable...if at all.
I like the new PRS gears or the white KW gears for spurs. I use the Titanium Racing pinion gears.
koabich is offline   Reply With Quote
Old 10-12-2005, 08:27 PM   #6695
koabich's Avatar
100 tooth would be a 64 pitch.
If I understand your shock question right, a harder spring will yeild less traction so you only use a hard spring on tracks that have high traction to begin with. Bottom line is if you need more traction, use a lighter spring. If you have too much traction, use a heavier spring.
Keep in mind you should try to balance spring and oil. You don't want a shock with a 10 pound spring and 100 weight oil.
Old 10-12-2005, 09:29 PM   #6696
Super Moderator
Trader Rating: 17 (100%+)
it is 64 pitch...not sure if a 108 fits never tried anything that big.
shocks...everyone has a theory. Basically you need to insure your car has balance. This is done with angles, spring rate, oil and pistons. If you are running on a track that is very tight you will want to have your car react quickly. this can be done by going to a lighter oil or stiffening up the spring one step OR standing the shock up. If your car is going into a turn and the rear inside tire lifts, then stiffen up the front. remember small changes. Big sweeping tracks require stability. That means slower reacting suspension, thicker oil for more dampening. I know theres a few sites you can go to that will give better explanations.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-12-2005, 09:47 PM   #6697
newera152's Avatar
Lightbulb
I have the shocks setup on the first inside hole (F-R), with blue shocks (R)40wt oil and red inthe front with 40wt oil.and the car seem to slide. good info, whats the web site I can goto for more info
Thanks newera152
Old 10-12-2005, 10:28 PM   #6698
Super Moderator
are you running carpet? right now I have purple fronts and gold rears with 60/40 and 2 piston try that for starters.
Old 10-12-2005, 10:54 PM   #6699
newera152's Avatar
Talking
Im running carpet,Im running purple in front and red in back and foam tires plaid in front and purple in back .I'll try diff shocks with 60/40 oil.
Old 10-13-2005, 12:17 AM   #6700
kflabouris's Avatar
hi,
yesterday i took my ft and i see the manual that say to use the steal outdrives the kit have and the plastic...i put the steal...it is wrong?
kflabouris is offline   Reply With Quote
Old 10-13-2005, 05:07 AM   #6701
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default need a little help
Need a little help.
I noticed that the front right cvd on my FT is very close to the coming out of the outdrive cup.
Do I need to shim the diff to get this to move more into the outdrive cup.
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-13-2005, 05:31 AM   #6702
dawgmeat's Avatar
What part of Conn. are you from?, I'm stationed at the subase in Groton, racing at Rcmadness 2nite
dawgmeat is offline   Reply With Quote
Old 10-13-2005, 06:42 AM   #6703
Super Moderator
There ya go you might be able to hook up with Dawgmeat and work on setups. Thats the best thing to do. each of you try something a little different and then compare.
Old 10-13-2005, 09:47 AM   #6704
newera152's Avatar
Talking
I live in hamden CT, and I race at hobby chamber 2nite. there a guy name stan thats from groton that races here to. Thanks for the offer.
Old 10-13-2005, 10:27 AM   #6705
CellBoy77's Avatar
Originally Posted by RED-LINE M03
Need a little help.
Thanks,
E
The directions for the Steel Diff is wrong. Note the directions for the plastic diff....I do believe that the Diff spring goes in first then the thrust baering set-up I might be wrong though
CellBoy77 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
